Question about Miele W1926A Front Load Washer
Bra wire went under drum how to get him out - Miele W1926A Front Load Washer
    Sergeant:
    Champion:
  • 226 Answers
Take it a part
Posted on Oct 15, 2010
My bra under wire stuck in my bosh dryer now when it spins it makes a noise
unless you can pry it out of one of the holes you'll have to take it apart, first try rotating the drum the wrong way to see if it pops out of the hole it went in, failing that, remove the rubber seal retaining ring and peel back the rubber, use a stick between the drum and casing to go fishing... if that doesn't work it's a complete strip-down and the bearings normally protest at that, if you go that far i'd suggest new bearings to replace.
once that's done, maybe consider burning your bra's to prevent further mishaps. or modify an old pillow case with some buttons to wash your smalls in. ;-)
Jan 01, 2018 | Washing Machines
Bra wire went through holes in drum
Will cause damage remove heater element to see and pull out.
Apr 06, 2010 | Frigidaire ATF6000ES Front Load Washer
Bra wire caught in back of tumble dryer drum
We got a bra wire stuck in ours it actually went through the tiny holes at the back and bridged the earth and live on the heater coils, and the rcd kicked in to cut it out before it could of caught fire. Never in a millions year would you think that could happen !
Jul 25, 2009 | AEG Dryers
Bra wiore inside drum
HAVE YOU A GOOD BRIGHT TORCH? IF SO I REMOVED MINE WITH A TORCH IN MY TEETH & A SMALL FLAT ENDED SCREWDRIVER, IF YOU CAN SEE IT TURN OFF ALL POWER TO THE MACHINE FIRSTLY THEN USING THE SMALL SCREWDRIVER COAX THE BRA WIRE TOWARDS THE NEAREST HOLE IN YOUR DRUM & THEN FEED IT THROUGH AS BEST AS POSSIBLE & THEN GRAB IT WITH EITHER FINGERS OR PLIERS IF IT IS A STRUGGLE TO PULL IT OUT.
DONT LEAVE IT IN THERE & THEN OPERATE IT AS IT WILL JAM IT & BLOW YOUR EXPENSIVE MOTOR WHICH ARE APPROX £80 OR HIGHER & YOUR PUMP IF IT JAMS IN THE BLADES BEFORE REACHING YOUR FILTER ..
May 22, 2009 | Hotpoint Aquarius WMA56 Front Load Washer
Bosch Maxx WFL2061 Scraping sound when rotating the drum
under wire of a bra caught in drum , I have taken out hundreds,Close Ireland
Nov 12, 2008 | Washing Machines
Bra underwire stuck
disconnect from electricity. take back panel off.you will see heater at bottom of tub held in by 1 10mm nut.disconnect wires to it. loosen this nut and pull heater out - you may have to help it with a screwdriver. you can then see into the gap between tub and drum and fish for the bra wire.
tell her not to wear bras with wires!!
Jul 14, 2008 | Electrolux EW1000i Front Load Washer
Under wire from bra cuasing noise in dryer drum
I'm not sure we have enough information yet, but I do believe that the bra would be more comfortable in its relaxed state.
Jun 01, 2008 | Bosch Dryers
Bra wire removel
Dont know what model you have. Search the net for a repair manual for your model machine. Some are downloadable. Then remove the tub to get to the bra wire.
Apr 12, 2008 | Washing Machines
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
Miele W1926A Front Load Washer Logo
61 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
