Question about HP Photosmart C8180 InkJet Printer
My hp photosmart c8180 is not printing the two magenta colours at all. After running self test report, still no luck- just faint lines. The same goes when i clean the printheads using the function on the printer itself. However when i align the printer - "pink" shows up perfectly fine...how do i get these colours back?
  • 13 Answers
SOURCE: I have a HP Photosmart C5180 printer.
If your color improved slightly when running the printhead option then doing more should help get better results. Sometime the printheads get really dirty/clogged and running the cleaning option more then once is needed.
If you get a slight line running across the page (from left to right) usually the indicates dust build up on the printhead or ink carriage. The dust acts as a paint brush being dragged across your paper as the carriage moves across the page during printing. You can clean the bottom of the carriage with a Q-tip or purchase some cleaning paper for your printer.
Posted on Apr 19, 2009
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
pineworks
  • 4041 Answers
SOURCE: My HP C6180 is not printing its magenta color.
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 21, 2010
Testimonial: "Thanks for you good advice. It all made sense to me and it should have worked. I found 9 others reporting the exact same problem. Craig patentQ.com"
  • 24 Answers
SOURCE: My out of warranty l7680 will not print or
The error states that you are using non-HP cartridges for all colours. If black prints fine then you should replace the colour cartridges with genuine HP colour carts. You should be able to get a refund on the refills since they clearly do not work as intended.
Posted on May 25, 2010
  • 1218 Answers
SOURCE: Photosmart C7180 - light magenta and magenta not
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Posted on Dec 23, 2010
Printer is not printing yellow, Light Cyan, Cyan, blue lines through Light Magenta & Magenta, What could be causing this and it is also leaking black ink out of the bottom of printer.
Is it under warranty, are you re-filling the cartridges? If yes to first and no to the other two, send it back under warranty. If you use copy cartridges or refill old ones the warranty is vod. This means you need to replace the printer. To be honest, you'd be better off buying an Epson all in one. Even the wireless model start @ sound 40gbp and you can buy good copy cartridges from choicestationery.com
Nov 17, 2014 | HP Photosmart C8180 All-in-one -...
Printer says it is fine, but the Magenta is not printing, so I cannot get the correct colors. I have tried cleaning and running the different Tests. Anything else I can do? On the Extended self Test...
Hi, is your magenta cartridge new? if it is new there are some factory defects concerning cartridges but this can be solve, you can go back to the store and let them check the defects of the cartridge or you can go to the nearest hp service center in your area to have a faster transaction.
Jan 04, 2011 | HP Photosmart C7250 All-In-One Thermal...
Failure to print from computer in colour
I have a similiar issue that just started happening recently - the printer shows FULL inks but the PC thinks it has empty inks. I tried the * #, 123 reset hardware failures, but that didnt help. Printer run self diagnostics says all is fine....
I am using USB connections - and this has been fine for years, until now. Maybe a microsoft patch issue?
Jul 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
I have a HP Photosmart C5200 - pages are printing pink and red streaks in pictures
the print head for magenta and cyan (might be also Yellow) is dirty. you can try to clean it with warm water, or replace a new print head.
Jul 31, 2009 | HP PhotoSmart InkJet Printer
I have a HP Photosmart C5180 printer. It is not printing purple-instead what comes out is blue. I have done a print test report and it showed the Light magenta and magenta with missing bars and streaks. I...
Apr 16, 2009 | HP Photosmart C3180 All-In-One InkJet...
Not printing black
Verification of color out – happens only after keeping the unit idle for quite some time.
1. Print self-test report
2. Are the cartridges out of ink – check ink levels
3. check self-test report patterns (missing lines or streaked bars)
4. Look for missing colors or ink smears.
5. Was this issue showing up because of any one single color?
6. Was it stored in a warm environment (Stored under direct sunlight?)
7. Manual Cleaning & Cleaning from Driver
Print a extended self-test report,
On the HP All-in-One control panel, press and hold the OK and Cancel buttons simultaneously and then release. An extended self-test report prints. You will get all the information of your cartridges. Good Luck
Aug 18, 2008 | HP Photosmart 3310 Printer
Photo printing
Try printing a manual self-test page:
1. Press and hold Cancel on the control panel.
2. While holding Cancel, press Start Copy Color.
This report provides useful information about your print cartridges, including status information. If the self-test report shows a problem, clean the print cartridges.
Feb 10, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C8180 InkJet Printer Logo
545 people viewed this question
Seeker5211
Seeker5211
