HP 9250c Scanner - I installed a new DF Kit and I need to reset - still says to install DF kit.
  • 6,993 Answers
this is happening because the scanner memory is still memorizing the old DF kit and is not aware that a new one is installed.
Turn the Scanner and while its loading , suddenly remove the power cord from mains, fix it back in and turn the printer on, wait and allow it load completely.
If that doesn't solve the problem, turn off the printer, remove it from mains, and leave the printer for a while. After a while try again. Also, remove the DF kit and fix it back into the scanner. Make sure it is well fixed to its position.
its a minor problem, just relax and it will definitely pick up.
Good luck.
Posted on Oct 15, 2010
Hp cm4540 fuser kit counter reset
allot of the newer HP printers can not be reset they have a fuse in the new fuser when it is installed it blows the fuse in the new fuser & resets the count.
Aug 01, 2012 | HEWLETT-PACKARD CM4540 AllInOne Laser...
How to reset hp laserjet m5035 maintenance kit problem
When page count approaches 200,000 pages printed, the device alerts to order a maintenance kit. The message can be temporarily cleared by using the Clear Maintenance Message item on the Resets submenu under Administration. When the page count reaches 200,000, the message can no longer be cleared and the maintenance kit must be installed. To check the number of pages that the device has printed since new maintenance-kit components were installed, print either a configuration page or a supplies-status page. The print-engine maintenance kit includes the following items:
  • Fuser
  • Rollers (transfer, feed and separation)
  • Separation pads
  • Installation instructions
Mar 02, 2011 | Office Equipment & Supplies
HP laserjet 3600 error message 50.9 Fuser Error
Thank you for the inquiry.
Yes you will probably have to replace the fuser. If this is a new printer still under warranty and the page count has not reached the service life of the fuser, contact HP for warranty replacement. Once the new fuser in installed you will need to restore the service count.
nav?h_pagetype=z-001&h_lang=en&h_cc=us&h_client=z-a-r1002-1&h_product=501046
Fuser Kit Part Number: (Sometimes Called a Maintenance Kit)
RM1-2665 This fuser is compatible with the following printers: HP Color LaserJet 2700, 3000, 3000N, 3000DN, 3000DTN, 3600, 3600N, 3600DN,
Link to Installation pictures and instructions:
http://printertechs.com/tech/mkinst/3000/mk-3000-2fuser.php
Restoring the maintenance count after installing new fuser.
This printer tracks the number of pages printed on the fuser, and a reminder message will appear when the fuser reaches a certain page count. The message will instruct you to replace your fuser. Whenever you install a new fuser, you should reset the fuser page count so the warning message will not appear prematurely.
To reset the fuser count :
1. Press MENU to enter the MENUS.
2. Press Down arrow to highlight Configure Device.
3. Press Checkmark to select Configure Device.
4. Press Down arrow to highlight RESETS.
5. Press Checkmark to select RESETS.
6. Press Down arrow to highlight RESET SUPPLIES.
7. Press Checkmark to select RESET SUPPLIES.
8. Press Down arrow to highlight NEW FUSER KIT.
9. Press Down arrow to select NEW FUSER KIT.
10. Press Down arrow to highlight YES.
11. Press Checkmark to select YES.
The fuser count will be reset and then the printer is ready to use.
Thank you for being a FixYa Valued Customer.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jan 19, 2011 | HP LaserJet 3600 Printer
Digital sender 9250c is sending empty attachment
If it is sending an empty attachment, it means that the document that you are trying to send is not being scanned by the Printer. There are many reasons for this, one could be that the drivers need to be installed or reinstalled another is that it may need a service. In other words it may need some technical attention. The equipment within your scanner may be dirty, from time and/or use. First try installing the drivers, if it still doesn't work then try installing it on a friends computer/laptop. As a last resort, i would take it in for repair/service.
All the best!
damnor01
Dec 14, 2010 | HP Digital Sender 9250c scanner Printer
I ahve a HP 9250c scanner, and my computer doesn't recognize it from the usb cable. It says it's missing IEEE 1284.4 printersupport. What can i do to fix this ? I have already installed all the...
It sometimes happens because of the USB cable. try it out with a different usb cable. Don't try it out with Chinese made usb cable because at times computers fails to detect a new hardware or gives error. As I had faced similar problem.
Aug 04, 2010 | HP Digital Sender 9250c scanner Printer
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
Our hp 9250c scanner suddenly scans very light
Reset the Darkness and use the setting to adjust the lightness or darkness of the output. Check the setting on the scan application as well as the 9250C.
Also check the document type and resolution settings.
If there is nothing strange about any of the settings then run the Calibrate Scanner function. If that does not cure the problem then you may have an issue with the quality of the lamp output or the scan detector and will need a service engineer to visit and rectify.
Sep 25, 2009 | HP Digital Sender 9250c scanner Printer
Hp 4650 n - New Fuser Kit
Under the menu>Configure Device>Resets>Reset Supplies>New Fuser Kit
Oct 28, 2008 | HP LaserJet 4650n Printer
How to install scaner kit
The scanning features is built in with the MFP. What u need to do is connect to the MFP, install the viewer driver, u can start scanning...
http://www.copiers.toshiba.com/media/downloads/support/drivers/GDI/vwr20-v101-drivers.exe
Apr 25, 2008 | Toshiba e-Studio 205 Copier
22 people viewed this question
jasbo
jasbo
