Question about Hilti TE 7-C 120V Rotary Hammer Drill
What bit does the TE72 accept? SDS,SDS MAX???
    Scholar:
  • Hilti Expert
  • 123 Answers
SDS MAX
Posted on Oct 26, 2010
Cordless sds leaving grease on sds bits
There is supposed to be grease on the chuck end of SDS+ and SDS Max bits. Actually, you should put a little lightweight grease on the end of the bit every time you put one in your drill. If you, or noone who has ever used the drill, have ever done this, it is possible internal grease is leaking out of the drill and it should not. There are seals to prevent internal grease from getting out of the transmission and striker mechanisms. If you are loosing internal grease, these seals should be checked.
Feb 14, 2013 | Dewalt DW005K Rotary Hammer
Makita sds max avt --when it is on the chisel only mode it still revolves like in drill mode . What has caused this ?
If the bit turns freely it's possible you have the change ring in the forward position. The HM0860C is a demolition hammer, not a rotary hammer so the bit should not be rotating under power for any reason. On the HM0860C the changing ring on the nose does slide forward to let you choose and lock the chisel bits in 12 different angles. Check to make sure the change ring is in the locked position.
Jun 30, 2012 | Makita HM0860C 11lb Demolition Hammer SDS...
Can i use any drill bit for drilling ...........in any drill machine or different drill machine have thier own drill bit
the teyx bits are SDS Max which are common in the industry. Most hammer drill manufacterors make a SDS+ size drill and a SDS MAX size drill. Hilti calls their bits TEC and TEY.
Jul 09, 2011 | Hilti Hammer Drill Bit TEYX 1 In x 21 In...
Do all sds drills have chisel function?
The SDS designation relates more to the type of chuck on the tool for the bits than to the tool/drill itself. There are both chisels and drill bits with SDS-Plus and SDS-Max shanks, SDS-Max being the the larger of the two. As far as the tools go: Demolition hammers will only hammer and can only use pointed chisels, scaling chisels, scrapers, etc, not anything like a drill bit that requires spinning to work. Rotary hammers can hammer and rotate the bits. Rotary hammers have a selector switch with two or three positions; one for hammer only for the above demolition bits, one for rotary hammer for use with carbite tipped drill bits, and some have a position for rotation only. The rotary hammer is a more versitile tool but more expensive because of extra workings inside.
Feb 17, 2011 | Garden
How do you lock the bits in?
Insert sds bit into chuck with slots/slot matching slot in chuck while pulling back on the spring loaded nose. If the bit does not catch try turning/rotating bit to lock. When you release the nose, a pin will drop into the indention on bit and prevent it from falling out during use. Sometimes this pin will break or wear-out thus the bit will not catch. Before you insert the bit, look into chuck for retaining pin. Pulling back on the spring loaded chuck releases pressure on the pin and allows insertion of bit. Parts are available at www.toolpartsdirect.com
Oct 12, 2010 | Hitachi H45MR 12lb. SDS Max Chipping...
Bit or chuck type for a Skil 717 hammer drill
I have a Skill 717, too. It has a hex shank. Here are a couple places that I've located that carry (some) parts:
www.icscuttingtools.com (pages 155 & 157)
www.bamanufacturing.com/page_15.htm
also try:
www.ereplacementparts.com
Sep 12, 2009 | Skil Drills
Need sds to hex shank adapter. Where to buy?
If you have SDS-Max, ereplacementparts.com has one made by Bosch that'll go from SDS-Max to 3/4" Hex:
http://www.ereplacementparts.com/sds-max34-hex-rotary-hammer-adapter-p-165057.html
I'm having a hard time finding one that'll do SDS-Plus, though.
Aug 19, 2009 | Bosch Drills
Hammer drills types
Two drive systems are available on both the hammer drill and the rotary hammer models: 1. SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. 2. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Irwin SDS-Plus Hammer Drill Bit 6in.L,...
Drive systems Question
SDS (or Slotted Drive System) bits for hammer drills/rotary hammers allow the bit to slide in the chuck and enhance the hammering action of the tool. For most applications, these bits provide plenty of torque. SDS Max bits are similar to SDS bits, but have larger shanks and come in larger sizes than SDS bits. These powerful bits are useful in industrial applications.
Aug 27, 2008 | Makita Rotary Hammer 450 Rpm, 2500 Bpm,...
Hilti TE 7-C 120V Rotary Hammer Drill Logo
370 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
