Question about Kenmore 22422 Top Load Washer
My washing machine won't start. It filled up with water like usual and when I closed the lid. It didn't start. The trigger that starts the washer didn't click when I closed it, it just presses down. What should I do?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Oct 15, 2010
Kenmore Model 21082000 won't fill during wash cycle
Try checking the lid switch. Sometimes the switch goes bad or the stem breakes and when the lid shuts it will not activate the switch. Usually located on the right side of the dryer. When the lid closes it will allow water to.fill. Washers are easy to fix and the part is cheap. Get it from amazon dont pay the crazy price your dealer wants. Trust me, i just fixed my mothers...
Feb 16, 2013 | Kenmore Calypso
Washing machine will not start washing when lid is lowered
ya. not a big problem it seems. here it goes
when ever you close the lid the tip of lid touches a sensor which signals the control board to start the rinse cycle.
now these many days that sensor has been in dying stage. that is why you were often closing it to let the cycle open.
now that sensor has completely dies.
just replace the sensor at the point where the lid touches the opening.
after that enjoy washing.
Jan 04, 2008 | Washing Machines
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Our washer is filling with water but will not run the cycle after it fills. We were able open and close the lid and it would start but now it only fills with water...Please help!!!
the lid switch is buggered the lid can be open while its filling but when it goes to start washing the lid needs to be shut so the lid switch isnt working so the machine thinks the lids open.
Jan 05, 2011 | Maytag Washing Machines
Wash starts before water is full
most washers if put on a large load do start going around before the water has finished filling this is just to get all the clothes fully wet before the proper cycle starts to wash them it is just how the washer copes with a large load peter
Nov 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not fill with water
Check the lid switch...this controls all power to the machine and if the lid isn't closed, it can interrupt the water fill even with the lid appearing to be closed. Press firmly on the center of the lid when it's closed. Sometimes the lids on these maytags get tweaked a little and then don't allow full contact with the switch... Let me know ..
KEN
May 10, 2009 | Maytag Dependable Care LAT9206
Washer wont start
If the machine fills with water normally but then just sits there, you might have a bad lid switch - that's the safety interlock that won't let the machine start unless the lid is closed. Check the switch and also make sure the lid engages it when you put the lid down. Of course there could also be a problem with the motor, but first check that switch.
Mar 08, 2009 | Roper Washing Machines
The washing machine will not fill with water.
this depends on the make of the washer / some whirlpool and kenmore will fill but if the lid switch is bad it will not advance to start washing ,,,, put the dial on spin and with it turned on close the lid and if it dont start spinning then your lid switch is your problem ,,,, can help better if i can have the make, model and serial off your washer.
Larry
Nov 24, 2008 | Washing Machines
Avanti w798ss doest start
Close the lid! There's a sensor on the back hinge of the lid. Make sure its working. You should hear a small click when you close the lid.
Nov 08, 2008 | Avanti Top Load Washer W797
Kenmore 22422 Top Load Washer Logo
123 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
