Question about Samsung HL-S5086W 50" HDTV
Hello I'm having a problem with my Samsung HL-S5086W DLP TV. When it works, it works great and everything is fine. but it seems there's a loose connection or something of the sort in there somewhere that I can't find. It's happened several times now that if the TV is shifted, knocked or shaken (sometimes just a good thump on the floor is enough) it'll loose all power. All lights off the front turn off (including the light that's normally on when the TV is off) and the TV is completely unresponsive. If I shift it around or lightly shake it, it'll usually come back with a little coaxing. Any insight as to what the problem could be would be greatly appreciated. thanx Sasha
  • Noel Jucutan
    Noel Jucutan Oct 15, 2010
    it has only a loosed part try consult a technician its only cheap.or if you have a background i can guide you.thanks
  • 42 Answers
Put it in to a technician, you have a loose or dry connection, this should be a simple fix..
good luck !
Posted on Mar 30, 2017
5 Suggested Answers
SOURCE: DLP no image at time - no chime - lamp light blink but no image - sometime 3 front panel lights blink
i have the exact same issue.
have you found the cause?
Posted on Apr 02, 2008
SOURCE: Samsung dlp model hl-s5086w. The
fixed it. my ballast was bad.
Posted on Jul 16, 2008
  • 17 Answers
SOURCE: Samsung 50" DLP - Lamp Light Blinking after bulb replacement
Listen closely. The tv should make a high pitch whine as it turns on. If it does wait and see if it tries this a few times. If yes then check the bulb, I have seen cases where the lamp shoves the power connector back into the set. If the tv starts with a grown or heavy vibration noise, then your color wheel may have broken and needs replaced.
Posted on Jul 11, 2009
ladywinn
  • 5138 Answers
SOURCE: My samsung dlp hl-s5086w will
Replace Lamp . Mats has them for $99.00 1-800-628-1118
Posted on Nov 02, 2010
HL-S5086W turns itself off
if your tv is dlp. the blub is probably the cause. i have a r5087 and had same problem. replaced blub and set works fine
Nov 16, 2013 | Samsung HL-S5086W 50" HDTV
Samsung HL-S5086W 50-Inch DLP HDTV keeps turning off for no reason
After turning off do the LEDs on the front panel blink on and off?
If so, you may have an issue with the lamp. Probably needs replaced or repaired.
Dec 26, 2011 | Samsung HL-S5086W 50" HDTV
My Samsung television has white dots all over the screen. It first started with just a few then more showed up. My husband tried wiping off the mirror inside the tv and even using canned air. This made the...
Hello auntthumps, I have posted this eariler, it applies here so here goes: As the commercial goes, "It's the mirrors" and that is exactly what it is. The DMD (digital micromirror device) DLP chip that is the problem. The areas that are white are due to stuck or malfunctioning mirrors. This will only get more pronounced as time goes on. The fix is to replace the DLP chip and or module. I would advise that you get a qualified TV technician to do this. I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 16, 2009 | Samsung HL-S5086W 50" HDTV
Samsung dlp model hl- S5086W making continious humming noise, has nothing to do with volume. Can I replace fan or wheel myself?
Most likely color wheel since most are defective right out of the factory--- someone has a step by step procedure to replace with pictures-- try google- samsung colorwheel -- fun job easy to do!!!
Jan 04, 2009 | Samsung DLP HL-P5663W 56" TV
SAMSUNG DLP HL-S5086W
check the horizontal transistor if, good.re solder your tv.
Sep 28, 2008 | Samsung DLP HL-P5663W 56" TV
Open Questions:
Samsung HL-S5086W 50" HDTV Logo
43 people viewed this question
Jerry Greenberg
Jerry Greenberg
