How do I change the ink in my Canon mx 870 printer?
pineworks
  • 4041 Answers
SOURCE: how to change ink cartridges- canon MX 850 printer
Hi
I not know if you got the manual so Ihave put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Canon-PIXMA-MP830-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 06, 2010
Testimonial: "Thanks."
  • 107 Answers
SOURCE: how to reset printer after refill ink for cannon
Dear Sir,
Ignore the low ink warning, the printer should still print after about 30 seconds or hit resume on the printer.
You will get this warning every time you print. There is no way to reset those cartridges. Thanks For YOur Time
Posted on Apr 08, 2010
  • 154 Answers
SOURCE: Hello.i have a canon mx 300.i have changed both
check that the tape that coverd contacts has been fully removed and that there is no residue on either the cartridges or the receptacle the error points to the color cartridge, it has happened to me previously were a cartridge is bad out of the box and needs to be replaced.
Posted on Jun 20, 2010
  • 5265 Answers
SOURCE: can you set the Canon
Yes. Press Setup and navigate (right/left arrows) to Device Settings. Then press OK. Next navigate to Fax Settings (up/down arrows) followed by OK. Select TX Report (again the up/down arrows followed by OK). Select the Print for each TX option (up/down arrows) and press OK again. Then press Fax to return to the standby mode.
I hope this helps.
Posted on Sep 28, 2010
Omilove
  • 16 Answers
SOURCE: how can i print without
IF YOU ARE ABLE TO AT LEAST FIND AN EMPTY COLOR CARTRIDGE TO INSERT, THEN ADJUST YOUR SETTINGS TO "PRINT COLOR IN BLACK AND WHITE", IT SHOULD ALLOW YOU TO PRINT. AS FAR AS I KNOW, IT WILL NOT PRINT IF THE COLOR CARTRIDGE SLOT HAS NO CARTRIDGE IN IT.
Posted on Oct 02, 2010
How to set ink level on canon mx-320 after refill?
Apparently the problem is that you are choosing to install (according to Canon), cheap, aftermarket ink cartridges rather than Canon ones. Therefore the machine is not recognizing them. Try this procedure, found on another forum, that was supplied by one of the cheapo ink companies. Who better to know how to fool the machines than them. If they want to sell these ink carts, they better know who to make them work!
U051 Error Correction procedure.
1- Switch off the Canon MX300 and disconnect the power cable.
2- While press and hold the power button, Connect the power cable to electric socket.
3- While pressing the power button, press the "Cancel/Stop" button (red button). (press TWICE che "stop\cancel" button)
4- Now release the power button and the printer turns into a kind of factory mode. Wait for 10 seconds until it says "idle".
5- Press ">" (next button) once "Shipping Mode 3? then Press the "OK" button. Press "OK" again for "without cleaning". A test page will print.
6- Open the cover, like you are about to change the cartridges.
7- Disconnect the power cable again without switch off the printer.
8- Take out the both cartridges.
9- Close the cover.
10- Connect the power cable and turn on the printer.
11- Now just put the cartridges back and the ink level in the canon Pixma MX300 have full again.
Jan 14, 2015 | Canon Black Pixma Mx 320 High Quality...
How do I get to the ink cartridge to change itin a canon MX 300
You must have power applied to the unit when you change ink cartridges. The cartridge holder should move to the left side of the carriage when you lift the cover to gain access to the ink cartridges.
Dec 21, 2014 | Canon Office Equipment & Supplies
Can't seem to find how to put ink into my canon mx 310 printer
I'm assuming when you said "fine catridge" you meant FINE cartridge. FINE is an acronym for the Canon Ink Cartridges. Anyhow, plug your printer into the electrical outlet and turn the power on. Wait about 1-3 minutes and open it up and the Ink Cartridge holders should move to the left for you to properly insert your Ink Cartridges.
Jan 31, 2013 | Office Equipment & Supplies
MX870 paper out
find the paper sensor and clean or repair it.
May 05, 2012 | Canon PIXMA MX870 Wireless Office...
The canon 310 MX is not able to accept new ink cartridges error 6000
if you purchased a canon 310 mx and if it is new..contact the supplier about it.So that they can instruct you how to fix it..Good day
Dec 02, 2011 | Canon PIXMA MX310 All-In-One Printer
Can not print with canon mx 870 using a ipad
The airprint system is not yet compatible with all printers. Were you told that you could print to this printer from your iPad?
There is a piece of software for Macs that allows any printer to print from an iPad or iPhone 4 called Printopia 2. I've been using it to print to an Epson A3 printer and a Canon A4.
Apr 29, 2011 | Canon PIXMA MX870 Wireless Office...
I WANT TO PRINT FROM MY MX 870 AND IT WANTS TO SEND A FAX INSTEAD
I had this problem too. I discovered that my printer, with it's regular picture, had somehow been renamed as a Canon PIXMA Wireless Fax even though I already had it listed. Not only that, my Canon wireless printer was no longer listed. I deleted the new fax that was also listed as my default printer, and searched for my printer. I made it my default printer again and all worked as it should. I have a feeling this is happening with the latest driver updates.
Mar 17, 2011 | Canon PIXMA MX870 Wireless Office...
All lights flashing on the epson stylus photo 870. Printer not working.
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
Feb 26, 2009 | Epson Stylus Photo 870 InkJet Printer
150 people viewed this question
jasbo
jasbo
