Question about Kenmore Kitchen Ranges
Kenmore refrigerator model #106 9532510 The brackets that brace the bottom shelf are broken. Are replacements available? If they are, how do I change them? Thank you,
applianceboy
  • 77 Answers
SOURCE: Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Posted on Sep 26, 2007
  • 1462 Answers
SOURCE: water pooling on the bottom shelf of the freezerless refrigerator
take back panel off inside freezer.
you will see a drain tray at the bottom with a drain hole in the middle. this hole is blocked with ice
melt off with a hairdryer and follow up with hot water till water flows away freely.
check drain tray heater is ok as well
Posted on Oct 11, 2008
  • 44 Answers
SOURCE: water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Posted on Apr 18, 2009
  • 56 Answers
SOURCE: Need two door shelves, Sub Zero, 251 RFD, the last two shelves
http://www.subzero.com/locator/locator.aspx?type=0&zip=Zip%20Code will get you to the nearest SZ?wolf parts distributor.
Posted on Apr 23, 2009
  • 106 Answers
SOURCE: Kenmore Cold spot refrigerator model 106 70182001 leaking inside
Your defrost drain in the frezer is cloged. Every day when your refrig sellf defrosts the water should drain into a hole that leads to a tube wich drains the water to a pan under the refrig. You need to turn offrefrig and remove frezer floor and rear wall and clean out hole and tube with hot water.
Posted on Dec 12, 2009
Testimonial: "Thank you very much for the info & for telling me to turn off the frig. I probably would not have done that. "
Kenmore coldspot refrigerator model 52552100 makes ice but wont dispense it
Below is a fix by another owner of your make and model for the same issue.
Pulled out ice bucket; tried ice dispenser with door latch pressed in and solenoid engaged and motor moved. Tried again and nothing (couple of times). Tried water...all good...good closure of dispensor flap (air pot operated). Opened dispenser (pried off carefully from bottom on this unit not to take off the glued part) and saw the micro-switch broken off of the ice dispenser side. Checked micro-switch (all good). Replaced control bracket...all good to go.
Nov 25, 2016 | Kenmore Refrigerators
Bottom refrigerator crisper drawer slide fell off
draw slide is mounted to the shelf bracket --either order new bracket or remove bracket [look how slide positioned on other side ] and try drilling and putting in small screw and nuts till you can order a replacement bracket
Sep 09, 2016 | Refrigerators
I have a Kenmore 17 cu. ft. refrigerator. Model 67741 series.I keep it in the garage mainly for liquids Most everything in the refrigerator freezes. I have turned the dials down to no avail. What do you...
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Aug 21, 2011 | Kenmore Top Freezer Refrigerator
Broken shelf? help!
if it is the very bottom shelf then here is your part number 240354602.
if it one of the glass spill proof shelves here is your part number.240355211
Feb 09, 2010 | Frigidaire FRS3R5EMB Side by Side...
I need shelves for the fridge and the plastic shelf at the bottom of the door is broken and needs replacing.
hi there......you havent stated the manufacturer of your fridge...however obtaining shelves for your fridge should be no problem..provided you have the model and serial number and if possible the product code.(a) contact your local your local domestic apliance repair/spares shop....(b) go online to the manufacturers web site...(c) go on line to google enter your fridge details this will provide you with information where to obtain your parts...
the door shelf may be a different issue...if the shelf is part of the door lining then you will need a relpacemant door
regards Sir Galahad
Aug 13, 2009 | Kenmore 91493 Stainless Steel Compact...
Door to refrigerator will not close properly.
The refrigerator door seal is being broken when you open the freezer door? Sounds like the rubber magnetic strip needs to be replaced on the refrig. door, they wear out after a number of years.
Oct 28, 2017 | Kenmore 73262 / 73264 / 73269 Top Freezer...
I need to find replacement parts for my Kenmore side by side refrigerator, Model #596-555510, Mfg #P1190410WW, Ser #9510162258. The door handles are worn, one of the fruit bins is broken, and the support...
You are missing a number in the model number. The model number most likely should be 5969555510 this number runs in the sears system. You need a number 9 in front of the 555510 try this. it seems that this is the only model that will run with what you have provided.
Dec 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Bracket holding glass over fruit / veg compartment broke
http://www.partselect.com/Schematics/Maytag/54436.gif Maybe this diagram will help you. www.partselect.com I just replaced the Crisper Shelf Frame. I received it very quickly. I am now looking for some sort of support for the whole shelf, because it still seems to be sagging. I may have to invent something. If anyone out there has a solution, please post it.
Aug 26, 2008 | Amana ARB2217CSR Bottom Freezer...
Kitchen Ranges Logo
51 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
