I have a Panasonic CT-26WX15N TV that was working fine when turned off and now it won't turn back on. I have it plugged into a surge protector and all the other electronic devices work fine. I also changed the outlet, but still nothing. It won't power on, not even with the remote. I bought this TV in December of 2005.
  • 3 more comments
  • wcawthern Jul 01, 2008
    I have the exact same problem! I also tried a new outlet and still did not turn on. This is the first time this television has ever had any problem.
  • Anonymous Feb 18, 2009
    same problem as the others
  • Anonymous Feb 22, 2009
    same thing here!
  • Anonymous Feb 23, 2009
    http://www.avsforum.com/avs-vb/showthrea...
  • Anonymous Apr 03, 2009
    I had the same thing happen. It worked fine and was turned off. Nothing after that. No power. My guess is the power supply or a bad transformer.
First things first- check the main power fuse; remove the 9 silver screws from the back of the unit, slide off the rear cover, and look at the main board right next to the power cord connection. There's a small, 6.3 amp fuse. Take a look at it; if it's blown... replace it.
Posted on Nov 22, 2009
I have a 55" Panasonic flat screen that won't turn
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Sep 29, 2013 | Televison & Video
I had to unplug my tv today (actually the TV is plugged into a surge protector, so I unplugged the surge protector.) when I plugged the surge protector back in the TV wouldn't go on (acts as if its...
There should be a surge release button on the surge protector to bring the protector back to normal (should be red in color) Some surge protection devices have this option so just check if your s has it. If that is not the case than I think that you might have blown a fuse in your TV.Might just have to open it up and change the fuse within with the same ratings, but please be careful because do have high voltages so get an experienced technician to do this for you.
Good Luck.
G.
Jun 29, 2011 | Televison & Video
TV has green lines on the screen. Was plugged into surge protector. When this happens have to plug TV into wall to get it to work.
HI,
It could be a faulty ground connection in the surge protector. Verify it using the following procedure or replace with a different one.
Procedure
good luck,
mrwindex
Nov 08, 2009 | Panasonic CT-20SL14 Television
No power either!!
Unplug the surge protector and plug the tv in directly to an outlet that you know is working, plug something else in first to be sure.
you may find that your surge protector is shot. if it is toss it and get a new one.
Sep 07, 2009 | Panasonic CT-36HL43 36" TV
Panasonic CT-32g19j
check The B+ of your tv. If no b+ Check the input AC voltage. If Ac i/p are ok but no B+ Volt maybe your IC in power supply has problem.
Jun 01, 2009 | Panasonic CT-32SL14 32" TV
TV will not turn on.
have a reairman look at your tv the problem is bigger than what you can imagine technically you are having problem in your power supply which consist of a memory chip, regulator, flyback,and some resitors and caps one or a combination of these went bad.good luck.
Mar 04, 2009 | Panasonic CT-36HX40 36" TV
TV Won't Turn On
there is no reset button - the main fuse has probably blown and needs replacing (6.3A 250 V)
Dec 26, 2008 | Panasonic CT-32HX42 32" TV
27 inch Panasonic TAU tv won't turn on, then sparks when you unplug and replug it in
You first need to rplace the outlet if it sparks where the surge protector is plugged in as it should not spark for any reason. then you need to make sure thast its not the outlet causing your problem by running an long extensition corn or moving the set to a differant outlet.
Sep 11, 2006 | Panasonic CT-32G11 32" TV
Televison & Video Logo
535 people viewed this question
Top Televison & Video Experts
