Question about LG DLE2514 Electric Dryer
What? or where is the thermal fuse?....you posted...Check the door switch first.Than look for possible thermal fuse has cut off.
What of where is the thermal fuse?
  • 868 Answers
These are two styles that are common/The pix on the left is yours,mounted on vent chambers outside shell,in the center of this thermistor will be a small button thatyou push in to re set heat problem.
Posted on Jun 03, 2008
  • Archie Ferrarini
    Archie Ferrarini Jun 03, 2008
    Since they switched the layout of pix it goes :top pix is for your LG
    • remove front panel to get access
    this thermistor (they call it)is mounted on the side of the where your heat tunnel travels through.
Hobart LX30H no sump or booster heat
Check the heat circuit of your dishwasher. This will include your control, heat element, thermostat/thermal fuse, & sometimes your door switch. Check your thermostat/thermal fuse and heat element for continuity first. If all test good, go to your control and possibly your door switch. Check for voltage from your control and continuity of your door switch.Use the VOM. God bless you
Apr 04, 2013 | Dishwashers
Tip
Electric dryer will not work at all?
If the electric dryer does not work at all then there are some possibilities that have to be checked to confirm the fault.
1) Check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not working is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) One more reason for dryer not working at all is the fault in the door switch. The dryer will not start working till the door is closed. But if the door switch or the door-switch actuator is got cracked or worn out or loose then door will not get closed properly and dryer will not work. In this case check the door switch/actuator and replace it if required.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get power and will not work.
This will help. Thanks.
on Mar 23, 2010 | Dryers
Dishwasher not heating
Check the heat circuit of your dishwasher. This will include your control, heat element, thermostat/thermal fuse, & sometimes your door switch. Check your thermostat/thermal fuse and heat element for continuity first. If all test good, go to your control and possibly your door switch. Check for voltage from your control and continuity of your door switch.Use the VOM. God bless you0999035f-139f-4f60-8314-2e1fc0f210a3.jpg
Kitchenaid dryer model kgys750jq0 wont start
The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive. Here is the switch to order if it is bad.
The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset. Here is the fuse to order in case it is bad.
Post back your findings and I will post the repair video for the repair.
Nov 07, 2012 | Dryers
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
Admiral Electric Dryer will not turn on when switch is pressed. Circuit breakers, power cord, and switch connections have been checked.
My Admiral electric will not start. I have check the door switch, cycling thermostat,push to start button, thermal cut off and the themal fuse with an ohm meter and they are fine. So what could it be and how do I fix it.
Jul 27, 2011 | Dryers
The dryer is doing nothing when I set the time and push the start button. I have omed out all the fueses and have made sure the door is shut. I have used my multi meter and I am getting the corect voltage....
Check your door switch. It should be a normally open switch. If it's good, you will need to check the thermal fuse and or thermal cut off. This is where you will find the problem. When you find the one bad, you will need to replace the cycling thermostat. It's a normally closed switch that closes on the rise. Once the temp gets to the degree on the cycling thermostat it opens, cutting power to element. When it goes out, it will not open. Then the dryer cycles off of the thermal cut off. This results in the dryer getting real hot and then the thermal cut off will be put out or the thermal fuse one. Your on the right track, keep looking and I feel sure you will find it. By the way, these parts I listed are located on the vent housing close to the blower housing. Good luck.
Oct 16, 2009 | Kenmore 700 6972 Dryer
Dryer doesn't dry
YES, most defintely. This typically causes the dryer to overheat and eventually blows the thermal cut-out or heating element.
SYMPTOMS:
Dryer runs, but does not heat - possible bad heating element or thermal cut-out.
Dryer does not run at all - possible bad door switch, blown thermal fuse, timer or drive motor.
Does your dryer exhibit any of these symptoms? Please post back and let me know.
Feb 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Fuse
Agrivated, looks like the fuse 18amp is in the back on top. You will have to remove the shell off the microwave to get at it. This one operates with a inverter..you have some high voltage there. Make sure it's unplugged. While you have it apart, check the primary switch, top one on door latch. If the monitor switch finds this closed when the door is opened it will blow that fuse. You also have a cavity thermal cut out that will shut the oven down. Catriver...post back.
Aug 28, 2006 | Panasonic NN-T993SF Microwave Oven
LG DLE2514 Electric Dryer Logo
148 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
