Question about HP Officejet Pro L7590 All-in-One InkJet Printer
HP L7590 FAX PAPER JAM - HP Officejet Pro L7590 All-in-One InkJet Printer
  • 1,218 Answers
Hello
Have a look at the link below, it should assist you in solving your problem.
Click HERE.
Kind regards
Michel
Posted on Oct 21, 2010
  • HP Master
  • 7,733 Answers
  • unibuy Oct 15, 2010
    My grandaughter fixed the problem.
    Thank you for your help.
4 Suggested Answers
SOURCE: Cleared paper jam &printer will not reset
I had to turn off the printer & disconnect the power cord. I also had some material that was backed up on hold from the night before that was preventing the current material from being printed & I had to go in & cancel the documents to be printed before the printer would function.
Posted on Jan 08, 2009
SOURCE: HP 7680 paper jam
I spent 21/2 hours with the HP tech support - with their recomendation to upgrade my 14 month old computer to the bigger model because the screen reads "paper jam". I have had this printer replaced once already, 1 week after I received it for a defective doc feeder. I decided to take things into my own hands - First of all, no paper was ever located in the paper jam area. Several soft resets by shutting down for 20+ seconds, then pressing #6 at start up resulted in any improvement - the screen continued to read "paper Jam....." the HP tech was unable to offer any practical suggestions.
I turned the machine upside down after removing the document feeder and examined the rollers at the back of the rear tray where the paper jam was supposed to be. I noticed that there was some black residue on the gears and although the machine was off and unplugged - the rollers / gears would not roll freely and seemed to get stuck. I cleaned them thoroughly with an old but clean toothbrush and water. (don't grease the gears - I've heard it eats the plastic) - until the rollers would freely roll when I moved the gray rubber rollers.
Returned the machine to correct position - and turned it on - "paper jam" message returned but the machine was sounding different than it had - so I did another soft reset (unplug from wall and printer for 20 seconds, then holding #6 for a few seconds while plugging back in and now I can print. The printer went through its maintenance cycle and did a realignment. I can print and everything is working fine at this time.
I hope that this will help someone. I couldn't find any information on how to repair the printer and HP seems to be all about producing junk and convincing you to "upgrade" at a cost of $2-300. When this one does finally go - I won't be buying an HP!
The 7680 jams a lot and the document feeder has a lot to be desired. It has trouble feeding straight and if there is a jam anywhere in the machine - it is always difficult removing the paper without tearing it and creating more problems and waste of time.
Posted on Apr 10, 2009
SOURCE: paper jam HP Laserjet 3050z
Open tray 1 and pull any visible jammed media out of the all-in-one.
If no media is visible, open the print-cartridge door, remove the print cartridge, and rotate the
upper media guide. Carefully pull the media up and out of the all-in-one.
Close tray 1.
Posted on May 04, 2009
Carriage jam
There are a number of things that can cause a HP printer carriage jam. To prevent it from recurring, one should keep in mind a number of things. Always ensure that the paper tray is not overloaded as this might result in the paper being stuck inside. Also the paper being used should be as per the manufacturer's recommendations. Turn off the printer when removing bits of paper. If there is a broken gear, do not repair it yourself. Call an HP expert technician to mend it.
Oct 05, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Magenta and cyan will not print on my hp officejet pro L7590 -- it started with a paper jam that was corrected - ever since then only the yellow and black will print on the paper -- printheads are good and...
Same thing happened to my printer hp L7590. Printed diagnostic, only black and yellow printed; diagnostic for printhead health Ky=good, MC= good. Only Hp products ever used. Uplugged, & discharged static, cleaned copper parts of printhead. Still no fix. On visual examination of floor of printhead compartment rectangular pad ( approx 1/4" by 1/2") is missing. I can only guess that during the paper jam, somehow the pad got caught up and went awol. Not sure what to do now.
May 26, 2010 | HP Office Equipment & Supplies
MY HP L7590 printer jambs when I try to copy or fax from top tray. The paper is entered straight and lined up but it feeds crooked. Any suggestions?
Please follow STEP 6 here:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&cc=us&lc=en&dlc=en&product=3643612
Thank you
TechSaver!
Jan 22, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
I have an HP Office Jet Pro L7590 and it had a paper jam. I've removed the paper and see no remaining pieces in the printer, yet I have a "Paper Jam" error and I can't get it to go away. I've completely...
The best solution of this problem can be seen on the below mentioned link .. go through it and you will get the solution of this problem..
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&lc=en&dlc=en&cc=us&product=3643612
Jan 21, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
False Paper Jam
Unfortunately, I think that the sensors are beginning to fail, and that is the result of a faulty sensor. How old is the printer? If I was you I would call HP and talk to them.
Ryan Frame
Creative Energy Associates Technical Center
May 11, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Feeder tray does not feed during fax
Hp help
Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
Apr 28, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
L7590 HP paper jam, I can't reach the paper
This happened to me and here's what I did. You can open up the machine right in the middle and access this area. Lift up below the menu buttons and screen and it hinges straight up. If the jam isn't there, go to the back of the unit and push on the gray button and open that back cartridge area for different access. Finally, you can pull out the paper tray and get access to the remaining area. One of these methods should work. Good luck.
Mar 17, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Jan 05, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
HP Officejet Pro L7590 All-in-One InkJet Printer Logo
165 people viewed this question
Seeker5211
Seeker5211
