Question about Gateway DC-M40 Digital Camera
Flash card 64 mb
When i tried to use a 64mb flash card the camera stuck on recording it is suppose to take up to a 512 mb flash card
    Problem Solver:
  • 10 Answers
The DC-M40 will take up to a 512mb CF card. You may have to format the card. Do this from the camera's menu. If that doesn't help, the card may be defective.
Posted on Jan 05, 2009
I can't find the memory card for it
According to the specifications the camera has both an in-built mmory, and also accepts an SD card with a maximum of 512 MB . Maybe it will accept a larger SD memory card but only record up to 512 MB? I do not know.
SD cards are common in camera stores, but these days they make them with 1, 2, 3 or even 8 GB ( 1GB about 1000 MB) !
Dec 24, 2010 | Creative Labs DiVi CAM 316 Digital Camera
I just inserted a new 8GB memory card but it tells me ''OUT OF MEMORY'' I tried to format it but still gives me the same message. Why is that and what can I do about it please?
The memory card you are trying to use in the camera is not supported. This camera is an older technology that can not recognize the large 8 GB memory capacity of the card. In fact, the largest approved card your camera will recognize is 1 GB.
The list of approved memory cards was obtained from the Nikon Site directly, and pasted below for your convenience.
Nikon has tested the following cards and approved their use in the Coolpix 5700:
CompactFlash memory cards:
SanDisk SDCFB series 16 MB, 32 MB, 48 MB, 64 MB, 96 MB, and 128 MB
Lexar Media 4× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 8× USB series 8 MB, 16 MB, 32 MB, 48 MB, 64 MB, and 80 MB
Lexar Media 10× USB series 128 MB and 160 MB
Lexar Media 40x USB WA series 256 MB*
Microtech International Digital Flash Film 1GB*
Delkin eFilm 650MB Pro*
Ritz Big Print 8x 256MB* (Edge Code 0E1B)
Microdrive cards:
DSCM-10512 512 MB
DSCM-11000 1 GB
Please rate this reply if it helped you out. Good luck!
Aug 10, 2010 | Nikon Coolpix 5700 Digital Camera
Should you use an 8gb sd memory card in a panasonic lumix dmc-fx3 camera ?
The manual lists the following SD cards compatible:
4 GB SDHC Memory Card
2 GB SD Memory Card
1 GB SD Memory Card
512 MB SD Memory Card
256 MB SD Memory Card
128 MB SD Memory Card
64 MB SD Memory Card
An 8GB card may or may not work. If you try it, make sure it is an SDHC card. (Note: HC=High Capacity)
Thanks for using Fixya.
Apr 27, 2010 | Panasonic Lumix DMC-FX3 Digital Camera
Camera flashes two times, but will not record a picture
this sounds like a problem with the sd card either being corrupt and needing formating or being to large. if made in 07 or older it takes 512 mb sd card max if in 08 or newer it will take up to a one gig sd card.
Oct 05, 2009 | Bushnell 11-9000 Digital Camera
INSERTED NEW DATEL 64MB MEMORY CARD INTO A PS2
Be very carefull with accessories for Playstations as ones that are not Sony brand can cause damage/malfunctions with your system. The only ones that should be used that are not Sony brand are ones that Sony has certified for use with their equipment.
May 30, 2009 | Datel Max Memory 64MB Memory Card
Using bigger than 64 MB compact Flash Cards
I have the same machine and if you watch the dvd included with the machine it says to use a MC no bigger than 1 gb. I use a 512mb and it works fine. Your computer may not have a MC port so you will have to purchase a memory card reader which you can purchase on ebay or at Fry's for around 10 dollars. All the files need to be saved on the MC card as a SEW or JEF file. When you go to your machine touch the emb. key then the disc key and you should see your files. You may also need to turn the page; sometimes it save it on different pages.
Apr 12, 2009 | Janome Memory Craft 9000 Computerized...
What kind of memory SD card would work for Panasonic DVD Recorder DMR-ES46V? I was hoping to put in a 8 gig memory card but those are all SDHC. Will those cards work in this unit?
This info is straight from the panasonic website. The owners manual and more info for the unit can be found here.
Hope his helps!
Suitable SD Memory Cards
8 MB, 16 MB, 32 MB, 64 MB, 128 MB,
256 MB, 512 MB, 1 GB, 2 GB (Maximum)
Mar 16, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
Card not formated
Thank you so much for your replay, I'm using the Original flash card 64 MB. after this error I tried a 512 MB flash card with the same result. I was thinking that if the capacity is high and beond the cam capacity formating at a lower capacity will be done but failed.
I really appreciate your kind support
Thank you very much
Martin
Jul 02, 2008 | Pentax Optio 330GS Digital Camera
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
SD CARD
the samsung digimax 4010 camera supports up to 512 Mb cards. 2gb is too big
Mar 31, 2008 | Samsung Digimax 4010 Digital Camera
Gateway DC-M40 Digital Camera Logo
27 people viewed this question
Top Gateway Cameras Experts
mohamed salim shaikh
Steve
Are you a Gateway Camera Expert? Answer questions, earn points and help others
