I have a Panasonic SA-PT860 home cinema system. Problem is, the sound level out of the back speakers is very low, even on speaker test. I have swapped the speakers around and altered the db settings, all to no avail. The supplier is now trying to tell me that "this is the way the system is" ... can this be right ?
  • 4 more comments
  • Anonymous Jul 23, 2008
    I got exactly the same problem with my back speakers. The front speakers working very well, but the back isnt doing the same.
    It doenst matter what i do with the sound-settings.
  • ejnichols03 Aug 31, 2008
    I get no sound out of the wireless speakers that came with my Panasonic SA-PT860! I have tried reconnecting, power off/on and note that on the AV screen of the player, it has a flashing 'W1', which the manual says is a frequency conflict that it is resolving...it doesn't resolve it, and I get no sound...
  • Anonymous Nov 17, 2008
    i have the same ******* problem
  • Anonymous Dec 29, 2008
    Same for me! Anyone know a solution?
  • resitmazigi Mar 21, 2009
    same thing :(
  • Anonymous May 05, 2009
    I've the same Proble of Frequency Conflict. How to resolve the same.
  • 150 Answers
SOURCE: Right speaker channel low, both front and and back, even the headphones
There might be a levels adjustment in the setup menu for distance or something, might check that before opening unit up.
Posted on Jul 08, 2007
SOURCE: one speaker is lower volume than others - right front
I think that maybe you setted the distance of the speakers wrong. Check your users manual and try to adjust the distance.
Posted on Apr 29, 2008
SOURCE: center speaker
I had the exact same problem. In order to "almost" balance the center with the other channels I had to give the center +12db gain and the other channels -12db. So after I got that far with level calibration I tried some tv sound, well the center although was playing sounded like the highs were missing and a bit distorted. This is the good part, I turned the volume all the way up real fast, somewhere near max something fixed itself, the center became very loud. Now it works just like new. Hope this helps. BTW, the problem existed the same for sub channel, so when the center started working so did the sub.
Posted on Apr 26, 2009
SOURCE: LG HT503PH home cinema system
Press the VSM button on the remote control until the display shows PL11 MOVIE or PL 11 MUSIC I personally prefer movie, that should give you simulated 5.1 on all speakers It works for me on both my TV and my xbox 360 which are connected.
Posted on Nov 27, 2009
linswad
  • 258 Answers
SOURCE: Right speaker is distorted with low volume, left
There is something wrong with the right channel amplifier, you need to get this equipment serviced.
Posted on Mar 26, 2010
Panasonic sa-pt860 speakers crackling
Panasonic SC PT860 Manuals
The above link is the owner's manual - it may help.
Here are some other ideas:
Try to find out if the crackling sound is coming from all speakers or just one - you may just have one bad speaker.
If the crackling happens at high volume settings, you may be overdriving the system - you'll just have to turn it down!
Try turning down the bass or the subwoofer level.
Is the crackling present with all sources (TV, cable, DVD, bluetooth)?
Sep 22, 2016 | Panasonic Audio Players & Recorders
Panasonic SC-BTT775 home cinema centre speaker has stopped working it was fine yesterday but I disconnected the wires to clean it when I run the speaker test I can get sound through it but that's it?
Some units have the ability to switch off the centre channel in different sound modes. It sounds like you have somehow switched it off. A careful read of the manual should get you back with sound.
Sep 07, 2015 | Panasonic Audio Players & Recorders
I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
In general, your PC's sound card (and its controlling software) will determine what it can connect to.
Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
Hi. I have a panasonic SA-PT860 dvd theatre system. Everytime you turn the on/off button it states that I have an F61 fault. I have looked in the manual and it says to check speaker connections. I have...
- Is your system playing in spite of this error?
Assuming that this is the model complete with "receiver" and speakers+sub and you use these and the original connections. You could try and measure your ohm level on each speaker to control if there is a bad/blown speaker. The Ohm level should be the same on each speaker - roughly.
- Hope this will get you somewhere!
Jan 28, 2011 | Audio Players & Recorders
I have a panasonic dvd home theater sound system SA-HT930, and the dvd player, is broke can do nothing with it, need a new one but the plug between the ampli and the dvd wont fit on any new dvd theater...
Believe it or not there is a seller on eBay who offers a one-price fixit solution for your unit for $100.
http://cgi.ebay.com/Panasonic-SA-HT930-SA-HT940-Repair-Service-/360178573162?pt=LH_DefaultDomain_0&hash=item53dc50df6a
That aside, these types of systems are designed as a package to be used as a unit. Otherwise they might have standard connectors. Another closely-related Panasonic SA-HT system might work for you but I doubt anyone manufactures anyhting to adapt non-standard speakers to standard electronics.
They actually say on page 9 of the manual:
"Use only supplied speakers
Using other speakers can damage the unit, and sound quality will
be negatively affected.
I would interpret that to mean 'use these speakers only with similar Panasonic electronics'.
Jan 15, 2011 | Panasonic sa-ht930 Home Theater Audio...
Replacing Panasonic SA-HT500 with Newer Model that has HDMI Input
ANY amp will be ok, as long as the wattage of your new amp does not exceed the wattage of your speakers. Otherwise you could overdrive your speakers and damage them. First clue, if you turn up the volume and the speakers start to shut off and on you are pushing too much power to them.
Feb 03, 2010 | Panasonic SC-HT500 System
Panasonic sc-pt460 home cinema system not getting
1 of your ics could be blown causing the amp shut down
Jul 15, 2009 | Audio Players & Recorders
Can't get tv sound from home cinema system speakers
you need an optical cable going from the TV to the home cinema for an audio output, it worked for, had the same problem!!
Dec 04, 2008 | Panasonic Home Theater System System
2,107 people viewed this question
 Grubhead
Grubhead
