Question about GE 24 in. GSD4320Z Built-in Dishwasher
Our GE model GSD4320Z00B is having a problem with the drain system. I've run the unit in the test mode and it does pump the dishwasher down. The problem is the unit does NOT pump down during a normal wash cycle. The fact that the unit works in test tells me it is not the pump. I've checked all the hoses and drain paths and there are no obstructions, again verified by the fact it works in test mode. Any test that can be used to determine the problem besides replacing parts one by one?
SOURCE: Dishwasher doesn't drain
Catriver: The dishwasher model is gsd5920do1bb. I probably posted the original problem in the wrong place. Does a similar fix apply? Sorry about the confusion. Greg
Posted on Jan 30, 2007
catriver
  • 878 Answers
SOURCE: GE diswasher GSD4020Z02BB doesn't completely drain
rs, in the back under the screen is a piston nut assy. This is a common problem on these GE's. The seal on the assy. becomes warped or worn and when this happens we get water left in the tub after drain. It's an easy fix. The screen comes off and the pistion nut assy. simply unscrews. The part number is WD24X220. You can look it up on the net, inexpensive. Catriver..post back.
Posted on Mar 05, 2007
catriver
  • 878 Answers
SOURCE: dishwasher will not drain
tichi, without a complete model number and using a model close to the one posted, there is a couple of things you want to check. It appears that you have a drain solenoid assy. that sits on the left side of the motor assy. If this selonoid overheats or fails, you will get a no drain situation. It is not hard to install a new one. I have found on these models that a defective timer will continue to send voltage to these selonoids and burn them up. Result, no drain. There is also a piston and nut assy. that sits under the filter screen in the back of the tub. You can get this from the inside. If this piston nut assy. does not seat as designed, you will have water in tub after the drain. From your post it sounds as if the drain selonoid is bad. I will attach a couple of pictures of these parts.
Posted on Jun 04, 2007
SOURCE: Will not drain
the selenoyd is bad take front bottom cover off you will see the problem selenoyd with 2 wires conected to it
Posted on May 03, 2008
SOURCE: GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Posted on Sep 29, 2008
GE DISHWASHER PDW7300N10WW DISPLAY SHOWS RANDOM CODES AND BEEPS CONSTANTLY.
old post. but I am posting here, to help , searchers.
this model has a full computer behind that panel
with service modes and factory test modes.
and a service manual..
try cycling power, (pull main power plug for 5min.)
make sure the drain line is not blocked. (i use a 5 gallon bucket to test my washer drain hose. 2 person, one to hold the hose firmly in his hands , aimed at buck. (the resest button kills all actions)
the beeps are error warnings, covered in the manuals.
there are many beep modes.
even door left open, does that, soap dispenser (option) empty.
the first tests on a PDW, washers, is the rinse, only mode.
when started, it first pumps the sump dry. (old water ejected)
if the pump do dose not start, but humms.. the drain is blocked.
then does a full rinse run. if not make sure the water valves are on.
these models have a Service mode, and a factory test mode
both are covered in the service manual, and allows the manual
testing of each mode and device in the washer.
The turbity sensor can get limed up , so run 1/2 cup of vinegar
in rinse mode. once running.
GE does not offer the serv. manual to DIY, but google does find them, if you search long and hard. "for sure"
is is a generic help page, but do not down load his helper browser bad (jeckle and hyde site) the HTML pages are safe.
http://www.appliancerepair.net/ge-dishwasher-repair.html
Aug 23, 2013 | GE Dishwashers
GE Nautilus dishwasher isn't draining... PLEASE HELP
Check floater valve.
Inside the unit. On the floor. Looks like and small upside down cup.
If it is jammed in the up position it will stop the machine. Lift, clean underneath. It should drop and the machine will run.
The float valve stops the machine from over filling.
Could also be clog in the drain filter. Remove the cover from the drain inside the unit. look for clog in the filer of the drain.
If none of the above it is the timer. The timer tells the unit what to do (fill, run, empty). If it is not working the drain function will not run.
Adrian
Mar 07, 2010 | GE Nautilus 24" Built-in Dishwasher
Dishwasher did not drain out all of the water
run it again on the hot cycle...if that doesn't work...you have a clogged drain hose or a defective pump.
Apr 04, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher won't drain
I rethought your problem and will provide a generic answer that is common to your brand of DW....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and good day...Thanks for rating my effort......thanks....The Fang.
Apr 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not drain
In order for you to see the diagrams..here is a great link...anyone can use....
http://www.applianceaid.com/gedishdrain.html..you may need to scroll down to get to where you need to be...but these issues are GE specific...and there are other related issues you can see here.
I have all this material in a vast data bank of my own but it is PDF format which does not translate well to these medium.
Good luck and good day...please rate my effort.....The Fang.
Hope this
Mar 28, 2009 | GE Nautilus 24" Built-in Dishwasher
My dishwasher will not drain it is a GE nautilus.
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher stopped draining after cycle
Some water always remains in the bottom of the DW (al least with most DW) but here is some help....
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Will not drain
Mar 10, 2009 | GE Nautilus 24" Built-in Dishwasher
My ge Profile dishwasher will not drain
HI. check the following areas for fualts.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).....
Feb 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
Open Questions:
See all GE 24 in. GSD4320Z Built-in Dishwasher Questions
GE 24 in. GSD4320Z Built-in Dishwasher Logo
88 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
