Question about Mitsubishi WS-65611 65" Rear Projection Television
Problem, Green light flashing TV will not turn on I have followed the instructions above and unpluged the keyboard, TV still doesn't turn on. So I can only asume that the reciever is out please instruct what needs to be done
  • 17 more comments
  • wangler454 Oct 20, 2010
    Yes it is a TV, Mitsubishi WS65611, Keyboard is how it was refered to when I first researched the problem on this site. The solution was to take off the front panel and unplug the two plugs on the front switch panel that has all of the push bottons for example the on/off switch etc., than see if the TV would turn on using the remote. My TV still would not turn on. Then the solution mention that it could be the receiver.
    Comment:
    I have plug in the set than held the Devise and Menu buttonsfor 5 seconds and the green light kept a steady flash. So I then unplug the set and held the two buttons down then plug in the set with the same results.
    I had to change the convergent chip on this TV and was successful. If that can be used as a guage.
  • wangler454 Oct 21, 2010
    how do you mean ready if we continue to email I'm ready if we need to converse over phone then I'll have to make a time that works for both of us.
  • wangler454 Oct 25, 2010
    when should I expect to here something for you again?
  • wangler454 Oct 26, 2010
    messenger ? I guess I don't know exactly what that is.
    is what you talking about MS messenger that stupid think that pops up everytime you start your computer?
  • wangler454 Oct 27, 2010
    ok, I'll take off of work tomorrow in hopes we can work on this problem. I have never used Yahoo chat before eather but it can't be hard, so if all works for you to start on this tomorrow then all I need is some guide lines how best to get a chat line going between you and me.
    I don't deal with GMT so I did my best to calculate what I believe is 8:00 am US central time is the same as 1:00pm GTM.
  • wangler454 Oct 28, 2010
    ok I think Im on yahoo messanger did I get the time wrong?
  • wangler454 Nov 09, 2010
    ok update on the fix
    after instaling the new chip I still have the same problem. Nothing changed.
    Mark
    I'm not sure if my message went through.
    update on the fix
    I changed the chip however the problem is the same.
    no stop green flashing light.
    ok I love your perseverance.
    so when I get home you need me to check voltage on the DM power board again.
    perseverance the word of the day
    so check voltage on the DM power board when I get home tonight
  • wangler454 Nov 23, 2010
    Hello Me again, last night I took some time to check some things out on the DM Power Supply. I need you to educate me on the Schematic. Question, The IC chip, when I look at the Schematic it shows 5, 12, 8, 9, 14, are those the only legs being used on that chip of 14 legs?
    When I touch the 5 leg the result is 0 volts , touching the 14 leg I get 12 volts. What result I should be looking for on 12, 8, 9?
    IC9 B00
  • wangler454 Nov 24, 2010
    page 76 DM POWER SUPPLY
    that's weird your gave me this copy
    http://www.mediafire.com/?n85e8hl2go1xs6...
    it's hard for me to tell if this message got back to you so Im sending this again
  • 4,889 Answers
Sorry this is a tv right? What exactly do you mean by "keyboard"? Please clarify this so that I can help you solve your problem.
Sai.
Posted on Oct 19, 2010
  • 15 more comments
  • eagle338
    eagle338 Oct 19, 2010
    Well? Please provide the details of the problem(see my previous post)
  • eagle338
    eagle338 Oct 20, 2010
    Whoever said that probably didn't know what they were talking about . They were trying to have you perform an error code operational check. Here's the correct procedure. Unplug the tv and plug it back in. Press and hold the DEVICE/INPUT and MENU buttons for 5 seconds. You will see a series of blinks of the LED followed by a half second pause and another series of blinks. Note down how many times it blinks before and after the pause and post it here so that I can pinpoint you to the source of the problem.
  • eagle338
    Looks like we are gonna have to do this the hard way. How goo are your electronics/soldering skills? I don't wanna tell you to replace that board and this board with out locating the source of the problem first . So we will proceed according to your skill level.
  • eagle338
    Ok thats god then. Let me find my service manual and let me know when you are ready.
  • eagle338
    eagle338 Oct 21, 2010
    Messenger would be good I think?
  • eagle338
    eagle338 Oct 25, 2010
    Well I have asked you if we can converse through messenger(See my last post). This is way too complicated to be solved here.
  • eagle338
    eagle338 Oct 26, 2010
    No. Not that one. I was talking about yahoo messenger. The reason is there are too many things to be checked and would possibly involve 100's of responses. So instead of that if we can chat, we can finish it off in an hour or two(on a weekend may be?). If you do not want to do that we can just continue here. No problem. I just wanted to make the job easier for both of us.
  • eagle338
    eagle338 Oct 27, 2010
    Perfect!
    Just get the messenger from here
    http://messenger.yahoo.com/download/win/
    Once thats done. Send me a mail to goodwise19@gmail.com and I will let you know my yahoo ID that you should add(which I do not want to expose here). We can finish it in max 3-4 hours. Also let me know the time(GMT) at which you wanna begin. I will suggest some adjustments if I am not comfortable with it.
  • eagle338
    8AM US time will be 3PM GMT(GMT-7.00 is central time). Thats perfect for me too. Will talk to you tomorrow. Make sure to send me a mail so that I can tell you how to add me to your contacts on messenger.
  • eagle338
    eagle338 Oct 28, 2010
    Yeah. You did it right. Wil talk to you in half an hour.
  • eagle338
    eagle338 Nov 09, 2010
    Ok. In that case its possible that we have to continue our QUEST to find the other malfunctioning components. I am ready to stick with you till its fixed.
  • eagle338
    Exactly. Lets see if all the voltages are OK. If not we will keep looking. On the contrary, if all the voltages are OK, we should look to see if the problem can be caused by some other component.
  • eagle338
    eagle338 Nov 23, 2010
    Please let me know which IC you are referring to so that I can have a look.
  • eagle338
    Ok. I will have a look and get back to you.
  • eagle338
    eagle338 Nov 24, 2010
    I see that all the pins on the IC are used. Which schematic are you looking at? I mean which page.
  • eagle338
    Looks like we are looking at 2 different versions of the service manual. Can you please upload your version to mediafire.com and get me the link?
  • eagle338
    Did i? Dang! Then I mut be having multiple copies of it. Anyways will have a look and let you know.
Direct tv cannot find a code to program direct TV remote
Hi
The following codes should work with your model
12293,13382 ,10178 ,10000 ,11034
Setup Instructions
  1. Turn on the TV manually or using the original TV remote.
  2. Press and hold the "Mute" button and the "Select" button on the direct tv remote at the same time until the green light on the top of the remote blinks twice.
  3. Using the number key, enter the first digit of the code above. Wait for the green light on top of the remote to flash twice
  4. Enter the remaining 4 digits of the code as above.
  5. Aim the remote at your TV and press the "OFF" key once. Your TV should turn off. If it does not turn off, repeat the steps above, trying each code until you find the correct code.
    www.electro-medical.blogspot.com
Sep 07, 2015 | Haier HL32R 32 in. LCD TV
I am trying to program my "Direct TV" remote to my Samsung LCD TV Series 5 and can not find the 5 digit code needed to do so.
If you have a DIRECTV white remote, press "menu" then "settings," "setup," "remote", and follow the on-screen instructions.
If using a gray or black remote,
  • Make sure your TV is turned on.
  • Slide the mode switch at top of remote to "TV".
  • Press and hold the MUTE button. This is located above the number 1 button.
  • While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  • Then enter 9911, the green light on remote should flash twice.
  • Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  • When the TV powers off, press and release the SELECT button.
  • Sep 07, 2011 | Televison & Video
    I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
    I found this on another website, most likely it is your power supply capacitors.
    1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
    2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
    3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
    4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
    5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
    6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
    Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
    1. DM Module Capacitors have FAILED.
    2. DM Module is defective.
    3. EEPROM Board failure
    4. Power Supply failure.
    Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
    I was recently given my sister's 55in mitsubishi rear projection tv. It was working great when we unplugged it but when I plugged it in at home it did not turn on at all. The only thing that is showing...
    We have a 55in mitsubishi rear projection tv.
    It was working great when the electricity went out (it was plug'd into a power strip) when the electricity came back on it did not turn on at all. The only thing that is showing that there is even any power going to it is a flashing green light by the reset button that does not turn off unless unplugged. I have followed the troubleshooting instructions for resetting etc but no help. Any suggestions would be appreciated. M Deisley
    Nov 28, 2010 | Mitsubishi WS-55819 55" Rear Projection...
    The timer light keeps flashing but the tv wont come on
    ONLY 1 of 2 things can cause this problem----
    First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
    Notice the one or two pairs of wires coming from the front keyboard2.gif of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
    The idea here is to remove the front keyboard2.gif with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
    These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
    If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
    If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
    You can call them and get a quote for repairing the receiver. There are also sites on the internet selling a kit for this repair.
    If this information has helped you rate this solution as I do this here for free.
    Let me know what more information you need--I am here to help.
    SD TECH
    Nov 10, 2009 | Mitsubishi WS-65511 65" Rear Projection...
    KP57WV600 SCREEN TURNS GREEN THEN BLANK
    The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
    • If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
    • If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
    If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
    1. Turn off the television. IMPORTANT: For a projection TV that uses an internal lamp, wait 5 minutes after turning off the TV to allow the lamp to cool before continuing with the following steps.
    2. Unplug the TV power cord from the electrical outlet.
    3. Let the TV remain without power for 60 seconds.
    4. Plug the power cord back into the electrical outlet. NOTE: If the TV is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the TV.
    5. Turn on the television. NOTE: If the TV does not turn on immediately, the fan may need to finish its cycle. This is part of the cooling process for some projection TVs and is normal operation. After the fan turns off, attempt to turn the TV on again.
    If the issue is still unresolved after following all of the troubleshooting steps, service may be required . Please note the number of times the STANDBY light flashes and relay that information to the service center.
    Sep 22, 2009 | Sony KP-57WV600 57" Rear Projection...
    Mitsubishi TV green flashing timer light after power outage.
    You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
    http://servicemanuals.vstore.ca/
    Aug 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
    Model WS-55909 Green light flashes won't go out. No TV
    You need the WS55909 - WS73909 DM kit. You can get it at the following link which contains the capacitors and the CD with instructions on how to do the repair.
    http://www.tvrepairworld.com/
    Jul 18, 2009 | Mitsubishi WS-55909 55" Rear Projection...
    Continuous flashing green "timer" light on front, tv won't reset
    Is your set a mitsubishi/ If so you need a DM repair kit they have various kits for the different mitsubishis at the following link under the repair kit category. The kits contain the replacement capacitors and instructions on CD.
    Jan 15, 2009 | Televison & Video
    Lamp problem or else?
    You need to get the ballast repair kit #LSUC0002 and replace the parts to your ballast.
    I have the exact same TV, did the above this past weekend, and the TV works like new.
    You need to know how to solder though. It's not that hard.
    Mar 14, 2008 | Panasonic PT-60LC13 Television
    Mitsubishi WS-65611 65" Rear Projection Television Logo
    81 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
