We have Bush BTU250DTR digital TV recorder and the LCD screen is reading fail all the time. We have switch on and off and the lcd still reads fail-any ideas
We also have this problem and have not been able to find a solution
Posted on Oct 19, 2010
Camera turns "on", can read menus, etc, but, there is no image on LCD screen?
On page 8 of the basic operate manual you see the backside of the camera and there you find the display button. Try pressing that one several times, while in recording mode.
Jul 20, 2014 | Panasonic Lumix DMC-ZS6 Digital Camera
Bush btu250dtr
I have the same freeview and lost the peg after Wednesday the 13th November. To fix it, go to Menu - Set-up - Change your box settings - TV guide type & change to 8 day guide
Nov 14, 2013 | Televison & Video
Bush BTU250DTR digital TV recorder. Will not turn on using remote control only with power button on front and then cannot change channel or access library, guide or menu. DTR button on remote lights up...
although the lights are working on the remote there is still no proof that its infra red led is not blown in some cases there solder point can come loose the first thing you have to do is conferm the remote is the problem as the ir receiver in the tv could be damaged first try buying a cheap universal remote and see if the tv responds if it does then you will have to have the remote serviced the cost is around @35-45 there is also i site on the net that sells secound hand remotes www.replacementremote.com you could try there but before you waist money conferm it is the remote
merry christmas
Dec 22, 2010 | Bush 5693D 24" TV
Help! My BTU250DTR shows fail in the lcd and will not turn on with the remote or reset if I turn the power off at the mains.
Whoa!
Mine did the same thing about 10.00pm on 14th Oct 2010.
I'm still messing with it.
Anyone else?
Oct 14, 2010 | Televison & Video
Do I need a special cord to record from digital tv
No,u can use the R,Y,W colors AV cable,the same hook up as a VCR recorder in the past.Read ur instructional manual,find out, if the unit can take HD hook up,use a HDMI cable for the hook up.Yes,buy a HDMI cable hook up to ur LCD or Plasma tv.Best result and the use of the recorder and LCD or Plasma digital tvs.
Oct 02, 2010 | TruTech TT1620 DVD Recorder
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Bush TV LCD 32 TV 005 HD
The black screen problem of your TV can be attributed to a backlight driver failure, busted backlight, or LCD driver failure.
The flickering indicates a failing backlight driver or a failing backlight. The screen should be totally black, without any glow, when either of them is not working. To verify, grab a torch and shine it on the screen. You will be able to see a faint display telling you that the backlight is busted or the backlight driver is faulty. If not, the LCD driver or the LCD panel itself is faulty, although it has a low probability due to the symptoms of the problem. The only way to fix the problem is replacement of the faulty part. You may need the service of a qualified technician to determine exactly which one is the root of the problem that needs replacement.
Dec 07, 2009 | Televison & Video
Recording problem between dvd vcr recorder combi and hd lcd tv
Aparently its the wire!!! as your sawpping the scart so yeah change the wire and you be a happy person!
Jun 17, 2009 | Grundig GU19WDT 19 in. LCD TV
Cant turn tv on when red light is flashing
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Feb 13, 2009 | Bush WS6671 28" TV
Bush 26 lcd tv
If the TV goes off completely, then is usually a faulty power board.
connected.
Apr 05, 2008 | Bush 5693D 24" TV
Televison & Video Logo
523 people viewed this question
Top Televison & Video Experts
Electro Med Services...
