Question about Car Audio & Video
Kenwood stereo power amplifier kac-642 - Car Audio & Video
4 Suggested Answers
jturcotte
  • 8268 Answers
SOURCE: how to wire kenwood subwoofer
Hi, this is a 4 channel amp. Not really designed for a sub, but you can use it that way. Cay you tell me all the speakers you want to hook up--need their sizes or frequency ranges and their impedances. Or, if you have model number for the sub that will do. Is it one sub or 2? I will then get back to you with a recommended setup. OK?
Posted on Jan 18, 2011
etirbynnor
  • 655 Answers
SOURCE: they are not wanting to play like they should
Hello again debrahood196,
Your KAC-5204 amp is only rated to put out 60 watts per channel and really cannot push very hard. If your subs are the KFC-W110S, they are 8ohm subs and you will get better power from the amp by using the bridged connections, positive (+) on the left channel and negative (-) on the right channel. Wire both positives and both negatives from both subs to the bridged connections and the output will be 150 watts into 4ohms. Giving each sub 75 watts should make them push a little harder.
Posted on May 18, 2009
SOURCE: CANT SEEM TO LOCATE WIRING
10 pins connector black..................GRN yellow.................BATTERY Blue....................IGNITION OR ANTENNA PWR FRON RADIO 4 pins connector purple..................REAR R (+) purple/black ........REAR R (-) green...................REAR L (+) Audio in................RCA jacks
green/black..........REAR L(-)
Posted on Mar 07, 2011
How to bridge a kenwood kac-9105d
Are you referring to something like this, using two different amps? It is a mono amp, meaning there's one amp in the box.
"KAC-9105D also has a Dual Mono Drive connection that allows you to strap two KAC-9105D amps together to power a single subwoofer."Quoted fromhttp://www.kenwoodusa.com/Car_Entertainment/Amplifiers/KAC-9105D
Here's a link to a page out of the Yamaha Sound Reinforcement book. the top shows a stereo amp (1 box, two different amps inside) hooked up to drive two different speakers, which is known as 'stereo' mode.It then shows the two amps hooked to the opposite sides of the same speaker, which is known as 'bridge' mode.http://books57.net/ampOuts.gif
Any help?
Feb 24, 2012 | Kenwood Car Audio & Video
The red light on my kenwood stereo amp KAC-628 will not turn on. I was wondering which wire is causing this to happen?
the power wire or the remote wire check ur fuse in ur power wire if thats good check your connection to the battery if thats all good its ur remote wire located in the back of ur head unit
Mar 16, 2010 | Kenwood KAC-628 Car Audio Amplifier
Car audio amplifer blowing fuses
why are you in stereo for subs? mono all the way.
Feb 21, 2010 | Kenwood KAC-7252 Car Audio Amplifier
Leads for old kenwood car stereo amps
Hey wdalley69, I've got the KAC-8070. My setup has the crossover module for it.
Oct 27, 2009 | Kenwood Car Audio & Video
I have a kenwood kac-7202 and it keeps blowing the in-line fuse
Are all the wires hooked in right? On the bare parts of the wires, are there any 2 wires touching? Most importantly, do you have the correct fuse for the stereo?
Oct 11, 2009 | Kenwood KAC-7202 Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
920 Watt Kenwood Amp wont power on
Connect the remote wire to an accessory wire on your stereo.
Jul 08, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Car Audio & Video Logo
561 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
