Question about ASUS Computers & Internet
I want change my CMOS (BIOS) battery on my Asus F2f laptop. How can i do it?
  • kunpeter01 Oct 15, 2010
    no by asus f2f series. I am not able to reach. There is not enough space.
  • 47 Answers
Open the back cover of the laptop and you would be able to see the cmos battery
Posted on Oct 15, 2010
Bios,cmos jumper on asus k51ac
remove the cmos battery and ac power cable. Then press and hold the power button for 5 seconds. Then put the battery back in and your cmos will be reset
Feb 18, 2014 | Computers & Internet
I forgot my bios password ,How to get rid of the bios password on ASUS Zenbook UX32
remove the cmos battery switch on the machine and switch off then put back the cmos battery and switch on and all will be well
Sep 29, 2013 | ASUS Computers & Internet
Asus m60j
Removing the CMOS battery for about a minute and putting it back in might help restore BIOS to default settings. I have not done this on a laptop yet, but that is generally how you reset BIOS. You may have to find which 'compartment' on the underside of the laptop to unscrew to remove and reseat the CMOS battery.
Jun 13, 2013 | Computers & Internet
ASUS A3H notebook: how do I reset the bios password. First, I press F2, then I'm able to get through the bios, then I changed the password ( I didn't place any or no password at all, just pressed...
Well..... It thinks there is a password. Have you tried just pressing the enter key? If so, then you have to reset the CMOS. To do this you will need to disassemble to get to the CMOS battery. I could have a jumper but the easiest method is just to pull the CMOS battery. On older laptops it is a rechargeable battery (nicad or lithum) and on newer ones they use a coin cell battery like desktop computers.
Best of luck, Jim
May 07, 2011 | ASUS A3H Notebook
How much is asus ee pc cmos bios battery?
You need to be more specific about the model, but cmos batteries are generally 3V buuton cell type. Some are fitted into sockets on the motherboard, but most laptops have one covered in heat-shrink plastic and with a flying lead to connect to the motherboard. To get a proper ASUS battery specific to your laptop will probably cost between £15 & £30 pounds but if you are technically minded you could buy a 2032 button cell for no more than £5 and replace the battery inside the heat-shrink plastic. I would check the voltage of the existing cmos battery first though because it may not be faulty. If the voltage is less than 2V then it will not work properly but if the voltage is above 2.5V then it is not faulty and does not require replacing. Between 2V & 2.5V is a bit of a grey area but may cause intermittent problems depending on the laptop. These batteries are designed to last at least 5 to 6 years (usually the life of the laptop) because under normal use the cmos will be maintained by the main power source (the laptop battery). I have never changed the cmos battery in my desktop PC or in my laptop, both of which are over 5 years old.
Feb 20, 2011 | ASUS Computers & Internet
ASUS Windows 7 laptop cannot keep time! I have checked the bios, and the CMOS battery, and all seems fine. Yesterday it lost 13 MONTHS!! What is wrong?
hi charli, did you change new cmos batter , how you checked your bios cmos battery, if you not changed your cmos battery try to change and check it you may get proper time.
GOOD luck
Dec 31, 2010 | ASUS Computers & Internet
How to unlock a acer password laptop
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard. If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
Sep 18, 2010 | ASUS Laptop Keyboard for Asus Eee PC
HELP
Its simple. there is a small cell battery in all motherboards. its usually for BIOS CMOS memory. if the battery drains up the memory in bios just erases. Date and time, bios CMOS settings will be reset after every shutdown or restart. try to replace that battery. Battery is used CR2032 coin cell.
Dec 14, 2009 | ASUS A3H Notebook
Cmos settings error system hait,
You will need access to another computer and go to: http://www.asus.com/, choose you country, then "Download", the on the next page, "Download" again. Select you "Product, Series and Model". Motherboard, Socket 478, P4P800-SE click "Search". Then choose you operating system. You will get to the page where you can download the latest BIOS, and install program. Read how to upgrade your BIOS and follow the directions carefully.
I suggest you also change the CMOS battery before you upgrade to make sure a dead battery is not the cause for the CMOS corruption.
Jun 10, 2009 | ASUS P4P800 SE (890552603657) Motherboard
Remove password from award bios on asus laptop
  • hi, after removing the cmos battery, wait for 10 minutes. Then replace the battery and try. Also you can try without the cmos battery.
  • let me know what happens.
Jul 08, 2008 | ASUS Eee 4G Notebook
Computers & Internet Logo
182 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
