Question about Ricoh 6513 Copier
Ricoh 6513 - no power
R5 (5ohm) on PSU board open, all fuses OK
is there a schematic available for the PSU board ?
  • 14 Answers
There is no schematic available. Only point to point wiring for the various modules. If you have no power at all, nothing starts glows or blinks on the control panel or on any of the various boards then you will need a service call to try to resolve the problem. It may require a board swap to see if that board is at fault. Unfortunately the days of repairing boards are long gone. Sorry!
Dave T
Posted on Jun 03, 2008
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
What is the sc 422 error on a RICOH AFICIO 6513?
SC422 PCC leak - Timing & Condition -
When the current leak is
detected for 2 seconds,
and the leak detection
started 1 second after the
PCC turned on. This leak
signal is monitored twice a
second. If it is detected
twice in a row, this SC is
displayed.
• PCC unit not properly
installed
• Broken corona wire
• Defective high voltage
supply board
(T1/PCC/BR)
• Defective I/O control
board
• Defective main control
board
Sep 02, 2011 | Ricoh 6513 Copier
Sc 541
Thermistor open
Thermistor connector defective
Thermistor damaged, or out of position
Fusing temperature -15% less than the standard input voltage
Reset Procedure :
Enter SP mode, then turn the main power switch off and on.
Jul 04, 2011 | Ricoh 6513 Copier
How to clear error code,sc542 nashuatec photocopier-mp6500
01. Press Clear/Stop Key (Yellow key) 2 tram
02. type 107
03. press Hold down Clear key 5 secend ( Red key)
04. type 5 and press # or Ok
05. type 810 and Press # of Ok
then machine Of and On
Jan 14, 2010 | Ricoh 6513 Copier
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
Solution for "code 373 ricoh aficio color 6513"
Hello sir; the error code you display is toner senser problem, now the first thing you have to do is make a full color copy find out which color missing then pull out developer unit from missing color the senser right underneath, replace it.
May 23, 2009 | Ricoh 6513 Copier
Error code SC542 on a Ricoh 3245
Hello, this code is : Fusing temp. warming-up error. This means that the fuser did not warm-up in the allowed time. Possible causing-- in order; Thermistor bad or out of position,
fuser lamp bad,
thermofuse bad,
BICU board defective,
power supply board bad,
poor fusing unit connection ----check this first if you had the fuser out of the machine.
If you would like to talk, I can see if we can try to reset the code -- sometimes if the machine is to cold at warm-up the code will throw. # 216-701-1591. Thank you.
Jan 12, 2009 | Ricoh 6513 Copier
Dead 6513 / PSU failure
Goto copytechnet.com.  That site is like fixya but it's copier technicians only solving problems.  They should be able to help you with the PSU diagrams.
Oct 10, 2008 | Ricoh 6513 Copier
Ricoh afficio color 6010
· Hot roller fusing
lamp brown
· Hot roller
thermofuse opened
· Defective main
control board
· Defective I/O
control board
· Defective AC drive
board
more than likely the thermofuse.
Jun 17, 2008 | Ricoh 6513 Copier
Ricoh 6513
A sc541 code is with the fixing ass'y did you try to reset it? Did it come right back? Is the fuser warm to the touch? If so it is most likly to be one or both of the termister in the fuser. If it is cold it may be the fuser heatting lamp or thermal fuse
Feb 08, 2008 | Ricoh 6513 Copier
Ricoh 6513 Copier Logo
80 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
