Question about Magic Chef CTF2125 Top Freezer Refrigerator
Water collecting on shelf above veggie drawer in Magic Chef refrigerator
  • Magic Chef Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 17, 2010
Why is water leaking from the inside bottom of refrigerator?
Hay Lola , your drain hose is clogged open the back panel and blowdry all the ice until the water drains good luck APPLIANCES R EN
Mar 14, 2013 | Magic Chef Refrigerators
Why is water pooling in bottom of fridge under veggie drawer.? Also freezing ice cubes in back part of cube drawer
Just above the veg drawers at the back is a channel that collects water when the fridge defrosts. It has a hole to drain the water which is blocked and the water is pooling under the drawers. Clear the hole with a drinking straw.
May 15, 2012 | GE Refrigerators
A while back the refrigerator was freezing everything even though it was set on low. Even the veggies in the veggies drawers would freeze. Now, it stopped doing that but once in a while it will start...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 26, 2011 | Magic Chef CTB1722 Top Freezer...
Water collects on the bottom shelf and does not drain into the defrost pan. It leaks out on to the floor. If I remove the round plug on the bottom shelf, it then drains into the defrost pan. Should I...
the drain nozzle or hose has blocked...a algae can grow in the drain system...push a flexible wire or plastic down the drain system or just sprinkle a little draino or a little chlorine into the drain collector so it will kill the algae.
Jul 24, 2010 | Magic Chef Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Aug 02, 2009 | Refrigerators
Water collecting under veggie drawers on bottom
check to see if defrost hose is clogged under veggie drawers
Aug 02, 2009 | Kenmore Refrigerators
Magic Chef CTF2125 Top Freezer Refrigerator Logo
137 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
