Question about Xerox Office Equipment & Supplies
I have a very old, but working, copier Xerox XC1040. It is blinking "H." What do I need to do?
  • 1,110 Answers
To reset the H3 or H4 condition on your Xerox XC1040 copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
If this solution works for you then please leave a positive feedback and testimonial for me.
Thanks,
WheatlandServices
Posted on Oct 15, 2010
I have a xerox xc1040 copier. The paper jam light is stuck on (it is the red light in the center of the display). I have gone through the entire sequence of recommended steps in the Xerox PDF files for...
Sounds more like the drum life chip has expired. Either replace the drum unit or the chip .
I can't remember if the xc1040 has a chip, or if its the one with the gears on front that has to drop a flag in order to reset the drum count.
Either way, I believe replacing the drum unit is the solution to your problem.
Dec 13, 2010 | Office Equipment & Supplies
My xerox xc1040 keep streaking across the page, this is the second cartrige and is a few years old. This machine has not been used very much for its age. I take the cartrige out and shake it around, wipe...
You are going to need a new drum unit. This is the cartridge that is located right next to your toner cartridge. What is happening is the drum bleaning blade has gone bad and is not cleaning the drum properly. You can have these rebuilt but with parts and labor they usually end up costing more than just replacing the whole unit yourself. You can find them on the internet for around $125.00. Make sure if you order one that it is the whole unit not just the drum. For example a drum alone is around $40 - $50 VS the $125 for the cartridge.
Good Luck and Thank You for using Fixya.
Nov 12, 2010 | Xerox XDL-33D Black and White Copier
Getting code H3 on Xerox XC1040 ????
H3= High Fuser Temperature. The fuser 126K07390 is bad and needs to be replaced.
Whit
Item, Inc.
Oct 05, 2010 | Xerox Office Equipment & Supplies
Xerox XC1040 that keeps jamming
sounds like the fixing unit needs to be replaced, give a call to any copier dealer that services lexmark and see what it'll cost for a replacement fuser, with that info you'll be able to tell if you want to fix or trash it.
Apr 13, 2010 | Office Equipment & Supplies
I need to replace the fuser gear on a XC1040
You have to remove that small cover on the bottom of the frame. It has 2 phillips screws to remove it. it is the cover about 3 inches high that runs around the lower front part of the machine.
Once you do that, you only have to remove one screw , unplug the heat rod and lift the fuser up and out. It really is pretty easy.
Mar 08, 2010 | Xerox Office Equipment & Supplies
I have a Xerox xc1040 that works fine most fo the
Yes these problm occurs frequently xc1040 . you ned to adjust the paper tray properly. then shake the bunch of papers so that the paper which are sticked are freed.
Jun 16, 2009 | Office Equipment & Supplies
Paper jam on Xerox XC1040
Sounds like the fuser gear (the long rollers where the paper exits that get hot) is broken. It is on the upper roller. Precision roller.com sells this gear.
Mar 12, 2009 | Xerox Office Equipment & Supplies
My copier ( xerox xc1040 ) hit a power surge . It
i speak a littlebeat english.
H4
00
Low Temp
you cant erease this code
in panel control
press (clear ) (exposure select key) (clear) (exposure select key) (14) & (start key)
14: Resets H3, H4,
Feb 28, 2009 | Xerox Office Equipment & Supplies
H2 Blinking on the panel
Error code means that:
H2 Thermistor Open
Part #
Xerox Workcentre Pro 16FX, Xerox Workcentre XD100, Xerox Workcentre XD102, Xerox Workcentre XD103F, Xerox Workcentre XD104, Xerox Workcentre XD105F, Xerox Workcentre XD120F, Xerox XC1020, Xerox XC1040, Xerox XC820
Mfr Part #: RDTCT0128FCZZ
Mfr Part #: CTHM-0019DS52, CTHM-0019FC52
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
Replace Fuser Gear Xerox XC1040 Copier
Call a tech!. You first remove fuser assy from machine. One green screw to loosen and then you figure the trick out to get it out. Then once its out remove cover 2 screws I believe. Remove the lamp gently, you can do this with out unscrewing anything. Then remove the little clip on end of heat roller, simple spread clip and replace gear. It takes a tech about 10 min.
Feb 13, 2008 | Office Equipment & Supplies
554 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
