Question about Microwave Ovens
Keypad on the microwave doesn't work
The keypad doesn't respond
  • 1 more comment
  • myfunnyfarm Nov 13, 2008
    The keypad does not work. power comes on, and flashes to set to vent, but cant make any buttons work.
  • snik225 Feb 03, 2009
    The 2 on the keypad doesn't work, and hasn't worked for a couple of months now. The rest seem to be okay. I have tried doing the hard reset solution, and that didn't fix the problem. Would it be too late to try a blowdryer or something, since it has been like that for awhile now? I'm afraid to try to peel the cover off as suggested in the other solution to the problem.
  • Anonymous Mar 22, 2009
    The problem with my keypad is the green plastic/metal strip that comes from the keypad and connects to the circuit board is having issues. I can't find a replacement keypad.
Well if you find out that your microwave keypad is not working, like those numbers or letters are not working, there's a 16 or 8 plug cords wire attach to the keypad and the need to clean that with normal water temperture.than dry it for about 10-20 minutes.
I garintie you it will work.
Posted on May 13, 2009
A lot of times this is due to humidity/dirt/cocoroaches pu between the contacts, if you wipe your microwave surface with an spray atomizer earlier this is for sure the problem: humidity. Always avoid humidity in the keypad, wipe it with a barely soaked towell and never ever use a spray bottle. Long fix involves do nothing: Leave the microwave alone and unplug for few days, if it can receive some sun light better. YaFix involves courage: Peel (with a x-acto nkife) very slowly the keypad from one of this angles (I ussualy start from the bottom), peel very slowly and see if you are not about to broke any plastic sheets (are several inside), if you SEE humidity between those sheets whipe it inmediatly, go until almost all the keypad goes off, warning, in some point a piece of plastic sheet with black stripes may appear, be very gentle there, this are the contacts to the electronic part of the keypad, do not peel this part. Wipe humidity, reasemble. If you want to make this a little better get help warming the area with a hair dryer, the adhesive becomes more soft and also is very most easy to put back in place.
Posted on Dec 18, 2008
  • Microwave Ovens Master
  • 9,098 Answers
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If that doesn't work, then please reply back with your brand and model number so we can help you.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 05, 2008
3 Suggested Answers
  • 9098 Answers
SOURCE: Microwave - Keypad (Maytag MMV5156AAQ Over the Range )
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
Posted on Dec 26, 2008
SOURCE: Kenmore microwave - unresponsive keypad
Repaired the unresponsive keypad on my older Kenmore (model 721.68100): Unplug. Remove integral cover for top and sides which is held in place by 5 metal screws. The cover then slides toward the rear. Unplug two connectors to back of keypad and clean them (I used contact spray cleaner). Some of the components retain a charge even when unplugged.
Posted on Jul 11, 2010
Having an issue with the keypad - not responding
I would contact Samsung, they seem to be aware of the issue with the control panel failing on there otr model and are replacing them free of charge under there "epidemic warranty"
May 06, 2013 | Samsung 1.8 Cu. Ft. Over-the-Range...
LG touchpad doesn't work
use the common sense,logically, fix it. God bless you
a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Aug 02, 2012 | LG Microwave Ovens
Sharp Carousel Microwave - R1481 keypad doesn't work
No! I'am afraid not, the problem is in the keypad control board, the whole assembly must be replaced, the part alone will cost around $100.00 or more depending on make and model.
Apr 16, 2012 | Sharp R410L Microwave Ovens
Ge jvm1540dn1cc the keypad its not responding and the please press clock it blinking
The probem is in the keypad or the microprocessor control board. I recommend a professioal to assess.
Mar 14, 2012 | GE SpaceMaker Microwave Ovens
GE Microwave Model: JVM1540DN1BB Keypad appears to work... but Microwave doesn't work
The problem is more than likely in the microprocessor control board, sometimes a bad relay, or poor solder points.
Mar 11, 2012 | Microwave Ovens
Can't use the microwave at all
you have either a bad keypad or control board.
If you have operation of some buttons and not others its the keypad. if you have no operation out of the buttons at all you have a bad control board.
If you turn your microwave on and it sets and the timer counts down you have a bad interlock switch..
please let me know exactly what your microwave does when you set the cook time
Jan 08, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave not working
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, your controller or keypad may have moisture on it.
Sep 08, 2008 | Panasonic Microwave Ovens
Sharp Carousel Model R9H84B
I've attached the portion of the manual which shows how to lock & unlock this model.
If that doesn't work, unplug the oven for one minute, plug it back in aga9in, then try again.
If it still doesn;t work, then your keypad has failed, and they are no longer available for these model, so the oven would have to be retired.
Good luck.
Jul 03, 2008 | Sharp R-230 Microwave Oven
LG LMVM2055SB over the range microwave keys not working
Is it possible someone may have sprayed cleaner directly onto the keypad area?
This causes moisture to get into the keypad and sometimes onto the control board.
This could mean that they control panel frame with keypad (membrane switch) would need to be replaced.
Can you give more details on the cleaning?
Nov 18, 2007 | Microwave Ovens
Microwave Ovens Logo
2,552 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
