Question about DeLonghi DC312T 14-Cup Coffee Maker
We have just purchased a delonghi coffee maker.icm2/4 there is no hole in the bottom of the coffee filter basket.should there be and how big should the hole be many thanks
SOURCE: My DeLonghi DCM485 coffee maker
The same thing happened to me....At least you got three years out of yours, I got three months.
Posted on Sep 11, 2008
SOURCE: coffee maker leaking from bottom
There is a hole that goes though the bottom of the water chamber side.
The unit will not leak when there is water in the water chamber. The only reason for water to come out the hole is condensation from making the water. There are no hoses in the water chamber area.
Posted on Jan 01, 2009
  • 3 Answers
SOURCE: Problems with handle alignment
I DON'T THINK YOU ARE GETTING A GOOD SEAL ON THE PORTAFILTER . YOU HAVE TO MAKE SURE THERE IS NO COFFEE AROUND THE EDGES AND EVRYTIME YOU ARE DONE BREWING RUN SOME WATER INTO A CUP WITHOUT THE PORTAFILTER IN PLACE .
Posted on Mar 17, 2009
ukvacfan
  • 328 Answers
SOURCE: RE: NEED MANUAL
Hi Visit this link and see if your machine is here. The possibility is that BAR 4 and BAR 14 could be one in the same machine:
http://www.delonghi.co.uk/pdf.php?key=Coffee%20Machines
Posted on Apr 12, 2009
mattofilms
  • 110 Answers
SOURCE: Hotter coffee
can also - press menu untill temp comes up - set to high.
(only low med and high)
Posted on Jul 02, 2009
Water is leaking from the side of the filter basket
The basket is probably not lined up any longer because of the pressure used to place the filter in the basket. Where you attach the basket to the machine, there are posts on the top and bottom. I had to put a small rubber rod behind the bottom post to make the top come back in line and that stopped the leak.
Sep 12, 2010 | DeLonghi Caffe Nabucco BCO70...
The water drips out excessively at the top, there is asecond hole where it comes out
When this happened to me, I found that the filter basket had worn and wasn't lining up to catch all the water from the bypass line. I used a small rubber rod behind the lower connector post (where it attaches the basket to the coffee maker) and that forced the top of the basket back far enough to catch all the water. I am using that until I can find a replacement basket.
Aug 05, 2010 | DeLonghi Caffe Nabucco BCO70...
Basket with coffee and filter overflows. Why?
Grounds might be too fine or not leveled before brewing, sprayhead might be dirty and clogged.
Jul 02, 2010 | Cecilware APT100WT Coffee Maker
Filter cone is full of hot water & thermo pot has about 5 - 6 cup
Te water fill lid is not closed or or the flow valve in the tank is plugged. Remove the basket and clear the hole in the bottom of it.. If new, return it to place of purchase.
Jun 22, 2009 | Black & Decker Programmable 8 Cup...
Making Coffee
Ok lift the lid and inside you will see a brew basket (it will have a hole in the bottem middle of it) If this unit has a mesh type filter basket you will not need paper filters! you put the coffee in the mesh basket the replace before brewing! if you do not have a mesh basket you will need a paper filter to put down in the coffee holder!(the one with the hole in the bottom!) add coffee and waeter and brew!
I hope this fixes ya up!
Please rate my response!
THANK YOU!
Jan 16, 2009 | Kenmore DCC-KE12 Coffee Maker
COFFEE GROUNDS COME THROUGH THE HOLES IN COFFEE BASKET. WHAT TYPE COFFE SHOULD I USE TO ELIMINATE THIS? IS THEIR A FILTER MADE FOR TJHIS URN
Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
Filter basket wont open..is there a secret?
You have to pull it open from the side. Then, lift out the filter and the basket.
Aug 09, 2008 | DeLonghi DC110T Coffee Maker
Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Mar 06, 2008 | DeLonghi EC140 Espresso Machine
DeLonghi DC312T 14-Cup Coffee Maker Logo
83 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
