Question about Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W low print speed
Instead of printing at some 20 ppm, as expected, my printer prints at about 1 page per 2-3 minutes...
How to correct?
Thank you.
jacques_savage@hotmail.com
    New Friend:
How to solve Konica PagePro 1380 MF Printer Copy and Printer speed is slower than normal ? How will i do for factory default setting?
Posted on Jan 14, 2013
    New Friend:
  • 48 Answers
Jacques,
Print speeds will vary based on a lot of factors. First thing to note is that your printer should have a first print time of about 20 seconds. This means the first page should take about 20 seconds before it starts printing and than will print at rated engine speed.
Secondly, depending on the type of paper and thickness your speed may slow down. Most printers will slow down for a thicker paper. In general the thicker the paper the more time it needs for the toner to fuse or melt to the paper.
The size of the paper will also greatly affect the speed too. Manufacturers spec their machines to letter size in the portrait orientation (the leading edge is the 11 inch or long side). In general for legal you will have a 15 to 20% reduction in speed and for 11 x 17 you can have as much as a 40% or more reduction in speed.
Print resolution may affect the speed. Usually most printers will print faster in a draft mode. This may also reduce the amount of toner used.
How do you connect to your printer? Different cables all have different speeds. For that matter is there an upgrade to the RAM? This could also change the speed of the print job. However these should not affect the final speed too much.
So to get the "rated" speed of your printer you will need to use standard letter paper with the long edge leading. Remember don't use thick paper and use a draft mode or lower resolution if possible to get the best speed.
I hope this helps.
Henry
Posted on Jun 03, 2008
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
Feb 16, 2014 | Konica Minolta PagePro 1350W Laser Printer
Konica minolta page pro with windows 7
I looked at the manufacturer's web-site:
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productname=1350W
and you are correct -- there are drivers for 2000/XP, and for 95/98, but nothing for Vista nor Windows 7.
Find an old computer running Windows 2000 or XP, and connect the printer to it, and "share" the printer across your home-network.
Apr 07, 2010 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
Feb 10, 2010 | Konica Minolta PagePro 1350W Laser Printer
My Konica Minolta magicolour 2500w won't print web pages any more
I believe it is a Windows problem and not a printer problem. Try to print from a different application, to see if it is working.
Jun 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
Pagepro 1350w prints with streaks on left side
Hello sir; Not thing you can use forever if lifetime is out you need to change otherwise the streak line not go away.
May 13, 2009 | Konica Minolta PagePro 1350W Laser Printer
After printing first page, the second page gets folded as envelope
Hello sir; It seems like registration roller clutch defect, replace it!
May 06, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W laser printer. Have
your carteidge OPC duram is faulty .
so change cartedige
Apr 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer won't print anymore
Go to printer faxes check and it might change the default setting and it might default Microsoft Office Document Image Writer. When you print make sure that you are printing to a right printer you can select the printer of your choice by clicking the down arrow. If you select the right printer and it did not print I suggest that uninstall the print driver to the control panel, add or remove and install a new printer driver. make sure set as a default.
Jan 27, 2009 | Konica Minolta PagePro 1350W Laser Printer
PagePro 1350W
Time has nothing to do with how long a toner cartridge will last. What is the page count on the cartridge?
Don't expect too much from it if it is the original cartridge that came with the printer as they have a very short fill.
Dec 05, 2007 | Konica Minolta PagePro 1350W Laser Printer
KONICA MINOLTA PagePro 1350W
the problem it might not be the printer. I encounter this problem before. the solution is uninstall the print driver to the control panel and re install the print driver using the cd print drive or you can download to konicaminolta web site..
Nov 21, 2007 | Konica Minolta PagePro 1350W Laser Printer
Konica Minolta PagePro 1350W Laser Printer Logo
227 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
