Question about Samsung CLP 300 Laser Printer
Vista turns color to b/w...
....especially with the new software that Samsung recommended. During the day all inserts of color mode has resulted in that it turns back to b/w - later in the afternoon it just printed text and numbers....
Samsung has no idea what this is. It´s said that CLP-300 is "dedicated for Vista" (I wonder). The only recommendation I got was to turn to Microsoft "it´s their fault - not ours". Meanwhile my Canon ink-jet 4000 works perfect - from the same Windows Vista Ultimate.... gaaah. What to do????
  • Ian Bland Jul 02, 2008
    Printer attached to Windows XP machine. Printing from Vista machine across the network is greyscale. Driver options on Vista are constantly reset to Greyscale even after running the menu in supervisor mode and selecting colour. Close it, reopen it and bingo! Greyscale box is ticked. Printer works fine if directly attached to the Vista machine.
  • angiep83 Sep 03, 2008
    When I try to print in color, (using Vista) the page prints out in black and white, even when I click on it to print color. I know that the printer has the capability of printing in color, as when I first purchased it it printed a test page in color.
  • 4 Answers
Had the same problem and fixed it (Printing from Vista to an XP machine with CPL-300 attached)
Opened printers control panel and deleted CPL-300
Deleted Samsung folder in C:\Program Files\
Installed downloaded CPL-300 driver as a LOCAL device (and said NO to install as if printer was off)
Back in printer control panel right-clicked and added printer. Picked Local Printer and changed port to networked UNC printer name. ie \\XPpc\SamsungC
Printer showed up in Control panel and color is now default and any changes are SAVED!
Hope that works for everyone else!
Posted on Sep 12, 2008
This solution works temporarily. However you have to select the modfied profile every time you print.
Also this solution does not work when microsoft office 2007 for printing.
Posted on Aug 05, 2008
  • 74 Answers
Ianrbland: wHEN YOu choose color make sure to type a name in under Favroties, It should say untitlyed to begin with and after you close and open it will say defult, just choose color and type in a name such as Color and hit save as favortite
Posted on Jul 19, 2008
I'm not quite satisfied with color and black tone. What settings would you recommend.
You do not say what exact model of printer you are using so any answer will be generic rather than specific.
Poor colour and black tone can be as a result of various factors:
1. Poor paper quality that you are printing on.
2. Poor ink or toner quality being used.
3. Use of Ink / Toner saving modes or software.
4. Worn or damaged printer components such as the fuser roll on a laser printer and other similar consumables with a limited page use life.
5. Poor quality content being printed, i.e. low quality images being printed at too high a print resolution.
Dec 30, 2011 | Samsung Office Equipment & Supplies
I have HD samsung hm251hi and i change sata mode i bios to ATA to install windows XP in notebook dell inspiron n5010 so, i can't install windows XP so what can i do?
Windows XP comes without drivers for SATA controllers in AHCI mode (some BIOS call it "enhanced" or "native" mode). Please double check if you really set your BIOS to ATA emulation mode (sometimes called "legacy" mode), this actually should do the trick.
However, AHCI mode has some advantages resulting in small but noticeable better performance boost. Windows 7 and Vista support it out-of-the-Box, actually I'd consider installing Win 7 instead of XP, unless you really need XP due to company policies or (very) old software that runs on XP only.
For Windows XP there is a rather unconvenient method availabe:
  1. You will need a 3.5" floppy disk drive connected to your laptop, if you do not have one, you may be able to borrow it from somebody you know, or ask a local shop for help. You'll need the drive for XP installation only, so buying one just for this purpose may be too much. --- Note, the procedure is not supported by XP for other media, like CD.
  2. Put the driver software for your SATA controller on a floppy disk - the N5010 uses an Intel chip set, so check here for drivers suitable for "F6 during Windows Setup" method. The floppy needs to hold the files IAAHCI.INF, IAAHCI.CAT, IASTOR.INF, IASTOR.CAT, IASTOR.SYS, and TXTSETUP.OEM.
  3. While installing Windows XP, a message "Press F6 if you need to install a third party SCSI or RAID driver" briefly appears, press the F6 key now.
  4. Insert the floppy disk into the drive, and follow the on-screen instructions to pre-load the driver.
The remainder of the installation should proceed as normal.
Oct 17, 2010 | Computers & Internet
Black screen
probably your hardware requirements are not good enough to run vista you should try installing windows xp that will helps you
Apr 19, 2010 | Microsoft Windows Vista Home Premium with...
Automatic update is not completing and is keeping me from logging
Dear Friend,
I strongly Recommend you to TURN OFF automatic Updates if YOU ARE USING NOT GENUINE COPY.....This will block your System after updater...
  • Computer might Infected Virus
  • Scan with good Anti virus
  • Uninstall any Newly installed untrusted Software/Softwares
You are done....you may feel Free contact.....
Is this Helped you...
thanks for Using FixYa
Apr 01, 2010 | Acer Aspire 5315 Notebook
I have just got a samsung jet but can not put the soft wear on to my pc
to install your software to your pc, NPS, try to follow these steps. please take note that you don't need to connect your phone first during installation. if your phone is connected to your pc, disconnect it.
for xp operating system:
1. insert the cd to your computer...
2. enable autoplay for your cd / dvd rom drive
3. select appropriate language
4. select ''install pc suite''
5. once finished, select the finish tab
for vista operating system,
>>do the same as the above steps, if ask to run as administrator select yes.
>>after installation, uncheck run pc studio automatically after finish.
>>select install usb driver
>>click yes if prompted to run as administrator,
>>after installation, remove the cd, run NPS, and connect your phone.
>>if your phone can not be seen by NPS, do these,
on your NPS, click menu, select settings, select connection, check usb cable com1 or com 2 port select ok, and let your pc studio recognize your phone.
for windows seven, though the NPS doesn't support it right now. you can do the following tricks,
1. insert the cd, don't enable autoplay
2. browse your NPS cd, look for the setup for NPS..
3. once located, right click the setup.exe, select properties,
4. select compatibility,
5. check run in compatibility mode on win xp, win vista.
6. check run as administrator
>>during installation, if prompted that the installation was not successful it will give you an options, select install with recommended settings.
the trick also, if you can't install your samsung studio, you may do these...
on your phone, press menu,then select settings, select phone settings, scroll down and it will give you pc connections, select ask on connections, save and exit.
now, connect your phone to your computer, it will ask you what connection do you prefer, on your phone, press memory card, it will install your memory card as mass storage device, open it your my computer, you will see your memory card there, you can now, drag and drop files from your computer to your memory card.
there you go, hope this will help you so you can enjoy your jet.
regards...
Mar 08, 2010 | Samsung Jet S8000 Cell Phone
I have a problem with my TOSHIBA DP8070 coper. i get error message: IQC service call recommended " the print quality is very poor
this happens during automatic color calibration, more than likely you need new color developer installed by a technician. turn machine on holding the 0&8 buttons to enter service mode type 4546 and 0 then start and 556 and 0 (start) 557 and 0 (start), then hold interrupt it will beep 5 times and shut down, this will turn off the calibration and allow you to make copies but will not improve quality.
Aug 06, 2009 | Office Equipment & Supplies
I can not get my Samsung printer drivers loaded for VISTA sp2
this time you are going to find MANUALLY your vista driver of your printer, go to device manager and update driver using an inserted CD of your printer... and even your going to update your VISTA its not reason...
Jun 19, 2009 | Samsung CLP-315W Laser Color Printer
Pictures are red during the day.
U might need to change the mode in which u are taking the pics. Try setting it to Auto mode.
Mar 18, 2008 | Samsung Digimax D53 Digital Camera
Samsung CLP 300 Laser Printer Logo
97 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
