Question about Standard Horizon Chart Plotter CP180 GPS Receiver
My CP has stopped displaying the charts. The
My CP has stopped displaying the charts. The system test indicates CARD NOT PRESENT, with the card inserted.
I've got a dc7800 Small Form Factor system. After less than a second, a blue window"smart card authentication" and below that, "smart card reader not present".
"System Options Not Set" normally means that the battery that maintains those options has gone dead. That's usually a 2025 coin cell on the motherboard.
I would replace that first thing, then set the BIOS options. Usually, there's another message that comes up, "Press F1 to continue, F10 for setup". F1 will let you system boot, most likely, but doesn't set the options. F10 (or whatever it says) will get you to where you can set the options.
Nov 09, 2015 | Computers & Internet
Sabrent CP-4PTU USB 3.0 4 - Port PCI Express card. p&p installed and computer stops after Win 8.1 logo and rotating dots stop.
did you install the software first,? I know you said it's plug and play, But it also says for Win 7 xp and other operating systems,.
Did you look on web site for drivers?? if not this is the driver listed for your item,.
http://www.sabrent.com/drivers/CP-4PTU/CP-4PTU.zip
Or you can read about your item here..
http://www.sabrent.com/category/controller-cards/CP-4PTU/
Install the driver then shut down system and install your card and reboot the system. Good luck
Sep 15, 2015 | Computers & Internet
P5PE-VM with Win7 has no display on PCI video cards-EVGA 2600 or EVGA gt 220. Both cards ran fine with Win XP. What do I need to do?
Hello here is the mainboards homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Are you running 32 or 64 bit system ???
Make sure the video driver supports windows 7, 32 or 64 bit.
The video card can sure run fine on windows xp but not in windows 7 as it is a totaly different system.
The mainboard has a 1 x AGP 8X slot.
So now you maybe has to find a video card that supports windows 7
Try also to download a manual.
Good luck
Dec 04, 2012 | ASUS P5PE-VM Motherboard
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
WIll not read the compact flash card after update of Internet Explorer. It displays a box saying to insert a disk in the drive and the flash card is inserted.
Please try the following: 1. Check if the LED indicator in your Card Reader is blinking. 2. Unplug the flash card and put in back again. 3. Check if the PC can detect your card. 4. If it can't detect it yet use other flash card and put it in the card reader. Check if it is working. If yes - you might need to buy another flash card. It might be defective. If not - check your card reader. If you have other card reader please try to repeat the process. 5. Update antivirus and run deep system scan. A malware or virus could be present in your system.
Thanks. Let me know if you need further assistance.
Apr 22, 2010 | Dell Computers & Internet
The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Sep 27, 2009 | Raymarine A65 Combo GPS...
What is the problem i reformat already my computer i install all the drivers when i it welcome to windows it always hang... it stop in a blue blank screen.. opening of the windows... what solution can u...
You have told that blue screen comes only if you connect your nvidia display/graphics card. Usually Blue screen comes if there is some problem with the hardware or due to incompactible hardware drivers. Remove the nvidia card from you system. Reinstall your system and then install all the drivers present in your motherboard cd. After that go to nvidia website, download the latest driver for your nvidia display/graphics card driver. Now connect your nvidia hardware back to your motherboard. Before that clean the dust particles present in the motherboard connecting terminals, if any. Now boot your system into safe mode. Restart your system into normal mode, install the latest driver downloaded for your nvidia hardware. Now everything should work fine. If you get bluescreen again, remove the card from system, restart into safe mode, uninstall the driver. Check the hardware in someother system, to detect wheather the problem is with your nvidia card or not. I hope this will help you out.
Aug 23, 2009 | Computers & Internet
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
2003 F-250 instrument cluster...
it sounds like you are getting a surge of voltage from your alternator/generator. Very strange.
the dealer can run a diagnostic test & pull fault codes or you can try this. If this helps, please report back & rate as fixya. Thanks. I am curious what you find as root cause. Good luck.
Instrument Cluster Self-Diagnostic Mode
To enter the instrument cluster self diagnostic mode with the engine off, depress and hold the odometer reset button. Turn the ignition switch to the RUN position and hold until the gauges sweep (within five to eight seconds). Depress the reset button once to advance to each stage of the self-test.
Turn the ignition to the OFF position to exit the instrument cluster self-diagnostic mode. If no DTCs related to the concern are retrieved, proceed to the Symptom Chart to continue diagnostics.
Instrument Cluster Self-Diagnostic Mode Odometer display Description GAGE Carries out gauge sweep of all gauges, then displays the present gauge values. Also carries out the check sum test on ROM and EEPROM. All segments illuminated. Illuminates all odometer segments. bulb Illuminates all micro-controlled lamps and LEDs. r #### Returns to normal operation of all micro-controlled lamps and LEDs and displays hexadecimal value for ROM level (used when requesting assistance from the hotline). nr#### Displays hexidecimal ROM level and type as stored in non-volatile memory (NVM). EE ## Displays hexadecimal value for EE level (used when requesting assistance from the hotline). dt #### Displays hexadecimal code for the final manufacturing date. ###C Gas engines display last temperature gauge input value from SCP, temperature gauge will indicate present temperature. Diesel engine displays present temperature analog/digital input in decimal as a ratio, temperature gauge will indicate present temperature. dtc #### Displays a 16 bit DTC in hexidecimal format. DTCs displayed are those detected in continuous operation not during self-test. EnG Displays English speed value being input, speedometer will indicate present speed. m Displays metric speed value being input, speedometer will indicate present speed. tAc Displays the tachometer value being input to the instrument cluster. Tachometer will indicate present rpm. FUEL Displays the present analog/digital fuel level being input to the instrument cluster as a ratio. OIL Displays the last analog/digital reading of the oil pressure switch contact resistance, oil gauge will indicate present level. br Displays the brake fluid level in an analog/digital ratio value. bAt ##.# Displays present battery analog/digital voltage. rhEo Displays present hexadecimal pulse width modulation (PWM) dimming input. rhi, rhS, rho Alternating 1 second display of pulse width modulation (PWM) input duty cycle, SCP hexidecimal dimming step, output driver counts in hexadecimal. Cr RUN/START sense circuit check. PA, Pb, PC, and Pd Displays 8-bit hexadecimal value for the Port A, B, C, and D readings (used when requesting information from the hotline). PE0-PE7 Displays 8-bit hexadecimal value for the Port E0-Port E7 in analog/digital readings
Jan 26, 2009 | 2003 Ford F250 Super Duty Crew Cab
EPSON RX600 PRINTER
Below is a chart of memory card capacities that have been tested by Epson. Testing was done before the products were released.
Please use this chart as a general guide line.
MEMORY CARD TYPE MAXIMUM CAPACITY TESTED
Compact Flash 4 GB
Secure Digital 1 GB
Sony Memory Stick 1 GB
MagicGate Memory Stick 128 MB
xD Picture Card 512 MB
Smart Media 128 MB
Any size of card other than that which is indicated above may work, but is not supported or guaranteed.
sorry for this one :(
Apr 18, 2008 | Epson Stylus Photo RX600 All-In-One InkJet...
Standard Horizon Chart Plotter CP180 GPS Receiver Logo
Top Standard Horizon GPS Experts
Steve
Steve
Mister Danger
Are you a Standard Horizon GPS Expert? Answer questions, earn points and help others
