Question about Compaq Presario Notebook
My internal speakers have stopped working. also my headphones/external speakers stopped working. NB In 'control panel/sound' I was able to play back sound clip on Conexant HD-Audio SmartAMC HD2 but although the other two speakers show as working (Bluetooth AV Audio) (Bluetooth SCO Audio) no playback sound could be heard either with external speakers plugged into headset socket or through internal speakers
  • 47 Answers
Remove the sound drivers then install the latest drivers
2. check if the corret sound out put is selected in sound option in control manger
Posted on Oct 15, 2010
Toshiba laptop Internal speakers loss of sound while playing games and watching videos .Sound first 10-15min then no sound.only way to get sound back by going into sound settings and disable speake
Could be an audio driver issue. Does the sound work okay if you plug in external speakers or headphones? If problem persists with headphones/external speaker
Boot into safe mode (F8 on windows restart)
Select Safe Mode
When windows loads (it will take longer than usual).
Control Panel > System Properties> Device Manager > Delete/ Uninstall your audio drivers, reboot your machine - audio should work now.
Apr 17, 2014 | Toshiba Computers & Internet
Cant get to play music without headphoes
Most modern computers come with internal speakers already installed, especially laptop computers.
These speakers may be sufficient if you are performing typical computer tasks, but when you play computer games, listen to music or watch movies on your computer, you may want louder and more vibrant sound.
You can achieve this by installing external speakers or headphones. These can be connected to your computer through the speaker or USB ports included on your computer.
Plug in the speakers or headphones.
If the speakers or headphones use a stereo plug, insert the plug into the speaker/headphone port normally located on the side or front of your computer.
This port is often color-coded green. If the equipment is connected using USB, locate a free USB port.
Some external speakers will also need to be plugged into a power outlet in the wall or your surge protector.
This may be all you need to do to get the speakers or headphones to work. If they do not, continue to the next step.
Open the audio settings on your computer.
From the Windows Start menu, open the Control Panel. Here you will find audio and sound settings.
Click the heading to see your sound and audio options.
Choose "Manage audio devices" in Windows 7.
Find your Playback device.
In the Playback tab, you can select your speakers and set them as the default for your system.
If you do not see your speakers or headphones, they have not been installed properly. Disconnect and reconnect them to see if it corrects the problem.
Configure your settings.
Select your device from the list and click "Configure" to test your settings.
You can adjust the volume by using the volume slider on your computer's task bar or using external controls on the speakers or headphones.
Install speakers
http://www.liutilities.com/how-to/install-speakers-to-a-computer/
Aug 05, 2013 | Acer Computers & Internet
Gateway Internal Speakers Stopped Working
click on Start / Control Panel / Sounds And Audio Devices
look at Speaker Settings / Advanced -- be sure it is set to your internal speakers.
the tabs across the top; go to Audio. -- be sure it is set to your sound card. For example, mine is "SoundMax Digital Audio" ... If there is another device you use that plugs into your USB, it could have stuck on "USB Codex". If it is, just put it on "NameOfSound Card" ...
Good luck, Don't be afraid to look all around inside the Sounds And Audio Devices box. And is this helped, please take a sec to rate me. Thanks!
Don
Mar 18, 2012 | Gateway Computers & Internet
Dv6000 no sound from internal speakers
If the stereo jack works, then there is no problem with the sound card or its drivers. Your speakers have played their last, most likely some internal wiring broken as speakers themselves rarely just quit.
Jan 12, 2012 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
The headphone and external speakers don't work on my acer but the internal speakers are fine
check if you plugged them in the proper port the green one is proper for speaker.
Mar 31, 2011 | Acer Aspire One A150-1006 Notebook
Adding remote control activated ''mute'' to TV headphone jack
Generally when the head phone jack is inserted the speakers will get disconnected automatically.
If you are going to use external amplifier you can try the AV sockets. Opening the TV you may require the special screw drivers some times.
Jul 07, 2010 | Televison & Video
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
No sound at all
Go to the system preferences from by clicking the Apple->system preferences menu. check the mute option is on or not. Also check the other options
Jul 03, 2009 | Apple Mac/iMac&iPod Speakers-(Bondie-Blue)...
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
Compaq Presario Notebook Logo
241 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
