My set will turn on but only run for about a half a minute before shutting down.
  • 712 Answers
This is the problem of the T.V transformer. A simple replacement will solve the issue. It can be easily seen if you remove the back cover of your television. It looks like a small matchbox wound with copper coil all around it. It is not so expensive and available in all leading T.V or electrical shops.
Posted on Oct 15, 2010
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
Desa model tb103 wont stay lit.
at first i thought this was a bad flame rod but the fact that it burns on low and not on high tells me that it is not getting enough gas since it burns less gas on low. there will be a tap on the burner side of the regulator, take off the cap and turn the screw clockwise to increase the gas pressure. do this in small amounts until it corrects the problem. If you have or can get a manometer, the gas pressure should be set to @7 inches of water column
Dec 09, 2009 | Reddy Heater RLP100 Portable Forced Air...
PC shuts down. When you turn on the pc it shuts
try to change the source, that should solve the problem. But before try reset CMOS. (if you don`t know how to do it by jumper simple remove the battery from the mainboard for 5 minutes and then plug it back on..and after that turn on your computer and press F1 for default settings)
Oct 27, 2009 | E-Machines eMachines Desktop PC
Viewfinder fades out in sunny conditions and also I have the auto shutoff set for 10 minutes and it turns off in one minute.
All screens are hard to see in sunny conditions. Is the screen shutting off in one minute or is the camera shutting down in one minute? Does pressing the shutter button half-way turn it back on?
Sep 24, 2009 | Kodak EasyShare Z740 Digital Camera
Yamaha 6500 watt diesel runs but usually shuts
First thing to monitor is the fuel solenoid power. See if it is the thing that goess away to cause shutdown.
Tracing this back there is only a few things that control this: The battery, the low oil shutdown switch, and the run switch, and associated wiring.
If I were to ventture a guess, I would put money on the low oil shutdown switch.
Aug 24, 2009 | Taylor Skid Mount Diesel Generator Set 30...
Genarator runs short period of time & shut down
What type of motorhome & generator is it. Some generators will shut down (basically run out of gas) at 1/4-1/2 tank in motorhome as a feature, to allow you enough gas to get to a station, in case you forget. The fitting for fuel from tank, for generator is placed that way in tank. Is that not the case? Make sure you have at least 1/2 or more fuel in tank of motorhome just to be sure, as we found many that were supposed to be set about 1/4 tank, but were closer to half tank on motorhome.
Jul 20, 2009 | Electrical Supplies
When we shut off tv for the day the fan motor continues to run it does not turn off
the fan will continue to run after the power is shut down on a DLP television untill the set has cooled down . But it should shut off within a few minutes
May 23, 2009 | Televison & Video
Come on, boots up, then shuts down 5 - 10 minutes later.
check your power options make sure you don't have hibernation enabled, its in the system control panel. try booting from a linux live cd like Ubuntu which you can download for free. If it runs fine under linux, its a windows problem, if it keeps shutting down its a hardware problem. Could be bad ram, or CPU overheating.
May 09, 2009 | Computers & Internet
Monitor blacks out after running for about 25 mins
Ok based on just the monitor turning off Lets try this,,
FOR WINDOWS XP
1.) Right click on your desktop
2.) Choose properties
3.) Click on the screen saver tab
4.) Click power
5.) Set The POWER SCHEME to Home/Office Desk
6.) Set the Turn Off monitor to Never
7.) Set the Turn Off hard disk and system Stand By to never
8.) Click apply then ok
9.) Repeat steps 1 - 3
10.) Set the wait time to 30 minutes
11.) Click Ok
12. Shut down and restart your system and wait 30 minutes to see if the monitor will shut off if it doesnt then Your good to go
If it does Then disable the screen saver.. and wait half hour to see what happens
POST BACK HERE AND TELL ME YOUR RESULTS OF THE ABOVE SO WE CAN TRY SOMETHING ELSE
Jan 16, 2008 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
