Question about Kodak Easyshare M580 Digital Camera
I take 10 or 12 pictures then get internal memory full. Put in 4gb card and happens. What did I do worng?
    Brigadier General:
  • 11,967 Answers
Your camera is not writing to the card because you used the internal memory. You must format the internal memory while your card is out of the camera to completely erase it. Then, your card should work.
Posted on Oct 15, 2010
Gobii smartphone I can't save anything to the SD
The SD card you can use to put music on or pictures. You can't use it to save Apps or run apps. Apps and messages must be in the internal memory. And with 4Gb the internal memory is full before you know.
Sep 11, 2014 | Computers & Internet
Internal memory full
Internal memory is full after you shot only a few pictures Actualy you only have 11 Megabyte free for pictures. If you want to make more pictures, you have to insert a SD memory card. Make sure you buy a SD and not a SDHC or SDXC card, because nothing in the manual says your camera is compatible with these bigger cards.
If you happen to have a SDHC card you are free to try if it works, but don't buy one unless you are sure it works.
Jan 20, 2014 | Kodak EasyShare C913 Digital Camera
I just got a samsung sensory pleasure nv3 i put a 4 gb memory card in it and it says memory full but the card is empty
Hi
Try formatting the SD card before using it.Also,check the storage destination of the pictures,could be they're storing on your camera and not in the memory card.Make the SD card the default storage device.
Hope it helps.
Feb 20, 2012 | Samsung NV3 Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
I have a 4GB SD card in my camera, but it will only hold 30 pictures. I'm thinking it is something with the settings, but not sure how to change it. any suggestions?
When you take the card out, can you still view the 30 pictures? If so, these are on the internal memory of the camera which is very small. Your 4GB card should hold hundreds of pictures. If you want to save the 30 pictures, you need to go into the menu and find "copy" and copy the internal memory to a memory card. Then, remove the card, go back into the menu and find "format"...follow the on-screen instructions and erase the internal memory. Put your card back in and it should work properly.
Jan 23, 2011 | Canon PowerShot SD1100 IS Digital Camera
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
My camera says the pictures upload onto my computer but then nothing happens after that....the pictures dont upload what is the problem?
Internal Memory: 32MB
SD Card / SDHC Card (Up to 4GB support)
Possible that internal memory is empty and your are transfered zero file. Switch to external SD memory in your camera menu should take care of the problem. Get the SD card reader is your easiest option. just copy and paste the photos to my picture in your computer.
Apr 05, 2010 | General Electric A835 Digital Camera
How do I get it off internal memory so that the pictures I take go onto my memory card?
usually its automatic when you put in the memory card. if this doesnt happen try going thru your cameras menu options and reformatting the memory card and see if this helps.. another thing to do is wait until the internal memory is full and it will automatically start using the memroy card
Mar 09, 2010 | Kodak EasyShare Z885 Digital Camera
I have inserted my 4GB memory card into the slot as indicated. I still can take only 23 shots before it says the memory is full. What dit I do wrong?
Sounds like you're taking pictures in the internal memory. Try this, remove the card and try to play back pictures on your camera. If they play back, then they're on the internal memory. You can transfer them to your computer if you want to save them. Then, go into the menu and find "format"...follow the on-screen instructions. Download any pictures from the memory card and then, format it in the camera.
Dec 24, 2009 | Canon PowerShot A480 Digital Camera
My samsung s1030
An 8gb memory card to too large for your camera. It can't handle the large space on an 8gb memory card. If I'm not mistaken the s1030 can only go up to a 2gb memory card.
Jun 10, 2008 | Samsung S1030 Digital Camera
Kodak Easyshare M580 Digital Camera Logo
151 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
