Question about i-mate JAM Pocket PC
Password lock syill locked - i-mate JAM Pocket PC
Tip
Polaroid LCD TV Parental lock/unlock
Program Lock
Input the default password of 1235, the submenu
of Parent will display if the password is correct.
(a) When changing the password, the changed
password will be updated after four digits are input.
The word "ok" appears after you input the same
number twice, if the two passwords are different the
word "Failure" will appear.
(b) When All Clear is selected, all programs are unlocked.
(c) After you exit from the Program Lock menu and switch to a locked channel, the picture and
sound will be locked unless you input the correct password. The channel will remain unlocked
until the TV is turned off. After the TV is turned on again, the password must be re-entered to
view the locked channels again.
(d) If your program is locked, input the correct password to enter the Auto Search submenu.
Operating Auto Search will cancel the locked status.
(e) The default password is always effective.
(f) Entering the default password allows you to go to the Program Lock menu, then change the
password while the default password is still effective. This branch menu cannot be entered if a
wrong password is keyed in, In this case, press MENU to return to the previous menu.
(g) There will be slight delays while using the Lock All and Clear All functions.
● Child Lock
In Child Lock On mode, the buttons on the TV do not work. A prompt "Panel buttons are being
locked" will be displayed. However, the remote control buttons will still function. When the TV is
on and the Child Lock is on, a prompt "Locked, power off after 6s" will appear. Use the remote
control to control the TV. Otherwise, the TV will automatically enter into Standby mode.
Having trouble with setting your Parental Controls (V-Chip)?
The factory preset password is 0000. This password must be used first before setting your own personal password. It is recommended that you keep your personal password in a safe place and away from children. In the event you loose your personal password the master password is 8202. The master password overrides all passwords. The master password can't be changed and should be kept in a safe place away from children.
on Aug 17, 2010 | Televison & Video
Samsung password reset
Im assuming its a samsung phone
Samsung cell phones come with many security features.
In addition to the common feature of preventing calls after a period of inactivity, some Samsung phones also allow you to prevent others' use of your phone's SIM chip and access to your files.
One password unlocks the various locks, except for two other passwords used for the SIM chip. The syntax of the menu items to click to reset a password differ somewhat between Samsung models but you can figure out roughly how to apply instructions for one phone to another.
Lock the phone from making calls by clicking "Start" or "Menu," "Security Settings" (or "More" and then "Security"), and "Phone Lock" or "Device Lock."
Change the password by clicking "Start" or "Menu," "Security Settings," and "Change Password." Then enter a new password.
Set the phone to work only with the current SIM chip by clicking "Menu," "Security Settings," and "SIM Lock."
Enter a new password when prompted.
Prevent unauthorized use of your SIM card by clicking "Menu," "Security Settings," and "PIN Lock." Type a new PIN when prompted.
Prohibit access to your files, messages and contact list by clicking "Menu," "Security Settings," and "Privacy Lock."
Enter the password from Step 1 when prompted to unlock access.
Reset the file lock/messages/contact password by resetting the phone lock password, as in
Step 1
Jul 25, 2013 | Google Chrome
HOW CAN RESET PHONE LOCK PASSWORD OF SAMSUNG GT-S5350
Dear Sir,
please help in below Difficulties i have forgot my Reset password so kindly Provide the Same..
IMEI N0 :- 35304504533577/301
Sent the Password on below ID Pvsproperty@gmail.com
Regards,
pankaj
Apr 28, 2012 | Cell Phones
I have a cmos lock on my ibm laotop
There is no such thing as a CMOS Lock. CMOS is a battery.
Maybe you have a BIOS Password lock? Or a Hard Drive Password Lock? Or A Windows Welcome Screen User Login Password Lock?
Apr 09, 2012 | IBM ThinkPad R51 Notebook
How to lock my pictures
Once you have jailbroken your iPhone. You'll got a Cydia icon on your SpringBoard.
  1. Launch the Cydia.
  2. Go to Search Tab and search for Lock Down and tap it.
  3. Tap Install button at Top-Right and then Confirm button at Top-Right to begin installation.
  4. After completion, go back to Springboard where you'll find a brand new icon i.e. LockDown.
lock-iphone-applications-lockdown-01-165x240.jpglock-iphone-applications-lockdown-02-165x240.jpglock-iphone-applications-lockdown-03-165x240.jpg
lock-iphone-applications-lockdown-04-165x240.jpglock-iphone-applications-lockdown-05-165x240.jpg
How to use LockDown
  • When you will run the Lockdown application for the first time, you will be asked to setup a Safety Code and a Password. This password will be used to unlock any locked application and to open Lockdown itself. Safety code is useful in case you forget your LockDown password.
  • Once you have setup the Password and safety code, you will see all your iPhone applications listed on next screen.
  • Select any application you want to lock, a Lock button will appear. By tapping that button your selected application will be locked and a little lock icon will appear next to that locked application.
  • Now if you close LockDown App and try to open you locked application (Mail app in this example), you will be prompted to enter the password to open it. Use your Lockdown password to open that App.
(Once you open the app, use it and when you close the app it will be automatically locked again. So no need to re-lock it in LockDown.)
lock-iphone-applications-lockdown-1-165x240.jpglock-iphone-applications-lockdown-15-165x240.jpglock-iphone-applications-lockdown-06-165x240.jpg
lock-iphone-applications-lockdown-07-165x240.jpglock-iphone-applications-lockdown-08-165x240.jpglock-iphone-applications-lockdown-09-165x240.jpg
Lets check other options in Lock Down.
  • Tap LockDown to launch it. This time you'll be asked to input the password to open LockDown. Do it.
  • Tapping any locked application in LockDown will prompt you if you want to Unlock it. Pressing the Unlock button will perform the unlock that App.
  • Locked Applications button at the top right quickly shows all the locked application only rather scrolling through all applications to locate locked ones.
  • Under Settings tab at Bottom, following options are available:Locking Options
    • Lock All Applications
    • Unlock All Applications
    • Lock This Application (ON/OFF)
    Password Management
    • Change Saftey Word
    • Change Password
    • Forgot Password
    Other Settings
    • Lockdown Dylib (If you turn it OFF, even if you open a locked application it will not prompt for password. So, it's helpful when you are using your iPhone by yourself. See the details in screenshot. )
    • Lock Icon Moving (When turned ON it do NOT let anyone to move any icon to preserve your arrangement of icons.)
    • Lock App Deletion (When turned ON it do NOT let anyone to delete any application without your permission.)
    • Enable Launch Button (When turned ON, Lockdown will show a launch button when you open a locked application and input password.)
lock-iphone-applications-lockdown-10-165x240.jpglock-iphone-applications-lockdown-11-165x240.jpglock-iphone-applications-lockdown-12-165x240.jpg
lock-iphone-applications-lockdown-13-165x240.jpglock-iphone-applications-lockdown-14-165x240.jpglock-iphone-applications-lockdown-16-165x240.jpg
I am using this great application since the day it's supported with iPhone OS 3.0. It's working like a charm and will keep it installed because of its usefulness and surely recommend it.
May 13, 2011 | AT&T Lands Phones
Lost phone password
*#7465625# = Check the locks *7465625*638*Code# = Enables Network lock #7465625*638*Code# = Disables Network lock *7465625*782*Code# = Enables Subset lock #7465625*782*Code# = Disables Subset lock *7465625*77*Code# = Enables SP lock #7465625*77*Code# = Disables SP lock *7465625*27*Code# = Enables CP lock #7465625*27*Code# = Disables CP lock *7465625*746*Code# = Enables SIM lock #7465625*746*Code# = Disables SIM lock *7465625*228# = Activa lock ON #7465625*228# = Activa lock OFF *7465625*28638# = Auto Network lock ON #7465625*28638# = Auto Network lock OFF *7465625*28782# = Auto subset lock ON #7465625*28782# = Auto subset lock OFF *7465625*2877# = Auto SP lock ON #7465625*2877# = Auto SP lock OFF *7465625*2827# = Auto CP lock ON #7465625*2827# = Auto CP lock OFF *7465625*28746# = Auto SIM lock ON #7465625*28746# = Auto SIM lock OFF
Jun 14, 2010 | Samsung SGH-A877 Impression Cell Phone
I have forgotten the lock code of my e66. now when i restarted the phone it asks me for lock code. can some one help
Nokia E66 I forgot password. When I restarting asking lock code.
How do I get password
Aug 06, 2009 | Nokia E66 Smartphone
i-mate JAM Pocket PC Logo
19 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
