Question about Sony Audio Players & Recorders
Sony TC 330 reel to reel tape recorder. Tape will rewind and fast-forward but will not play. I think a new drive belt might be needed. How do I check?
  • Jeremy Brown
    Jeremy Brown Mar 01, 2013
    Check to be sure the pause button is disengaged.
  • David clark
    David clark Sep 18, 2017
    The elbow joint on the capstan drive pulley is most likely stuck, lubricate and work it loose, worked on mine"
REEL TO REEL RECORDER SONY TC 330 - on back side of the set voltage selector knobe is lost,so how can i fix it ?
Posted on Apr 17, 2011
Sony taperecorder TC-355 will only run in fast forward. when trying to play in any speed tape moder went into fast forward and would not play tape.
If the speed-controlled roller is not closing to pinch the tape when PLAY is selected, the recorder will play in a fast mode. You will need Isopropyl alcohol, contact cleaner, Q-tips a screwdriver needle-nose pliers and a steady hand to clean every moving part in that Reel-To-Reel and then lightly lubricate the moving parts.
While you are in there I would change the belts as well. Or send it to a qualified repair shop and pay $ 125.00 to $ 200.00 for same thing to be done. Take your time, it's just a big puzzle, make sure you video or document everything you remove so it goes back together correctly. Good Luck!
Nov 11, 2016 | Sony Audio Players & Recorders
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
What is the reason the tape won't play on sa-ak95
It may be the tape(s) themselves. Pre-recorded cassette tapes are usually no problem for most players, but many user-recorded tapes were of the C90 or C120 variety. These cassettes use much thinner tape in order to get the recording time. This can cause the tape, after many starts and stops and partial fast-forwards and rewinds to get tight on the reels. This will cause the tape sensor to think that the tape is at the end of the reel when it is not. Sometimes rewinding from end-to-end will help, but not always,
Nov 07, 2014 | Microwave Ovens
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
My tape plays but it rewinds and fast forwards extremely slowly or sometimes not at all. Could it be a drive belt problem if it plays tapes?
tapes themselves sometimes get tight. also...a weak belt could cause this. I have sometimes taken tapes apart and rewound them by hand, but tapping the tape fast and gently can loosen them but you'll have to open the tape protective cover or the reels wont turn
Nov 09, 2011 | Televison & Video
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
I have a sony TC 530. Fast fwd and rewind work
You need to replace the motor run capacitor. It's a small aluminum can looking thing with three wires right next to the motor; they often leak paraffin wax into the bottom of the case when they overheat. Whether or not yours has leaked it's easy to replace if you can use a soldering iron. Search eBay for a Sony reel to reel 1.5uf 250VAC motor run capacitor - they're less than $15 and come with detailed instructions.
Please wait Image not available
Jun 14, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
''squeaks'' in reel to reel tape recorder
brakes need adjusting on the reel hubs
Apr 08, 2009 | Audio Players & Recorders
721 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
