My goodmans micro 14651 wont switch on it stays on standby? any ideas
Did you get this working again I have the same problem with this model
Posted on Mar 07, 2014
Sansui SV-3715LCD, I switch off the unit at the wall socket, when I plugged it in the next day there was no power, not even the LED indicator light on the front of the LCD activates. I checked the plug...
Continue to check--every set has a standby power supply that powers the remote circuit to turn set on and it runs 7/24 if set is plugged in.
Never a good idea to turn set of by taking the AC away--it can cause micro problems(micro processor).
The standby will provide voltage to the micro (low like 3-5 volts) and if a mechanical relay is there it also supplies it.
if NOTHING try to isolate that area in the main supply as they usually combine the standby in with the main power supply.
You may need to search for a schematic with GOOGLE (good luck on that) but if total dead begin there.
Worst case if problem is in standby you may have got the eprom or the micro when this happened
If further questions I will try to help.
Mar 23, 2012 | Televison & Video
What subwoofer is compatible with goodmans 14651
Find out through google or somewhere else what the rms wattage per channel is on your amp...Then find a sub or pair of subs that can handle that wattage. Then you will be in business
Mar 14, 2012 | Car Audio & Video
We have a LD3266D Goodmans TV, since the switch over we have to tune the TV in everytime it's switched on, before the switch over the TV would auto tune and store the program's with no problem, any...
If you switch your tv of at the plug the software cant do the updates. Leave the tv in standby over night and that should work.
If you do leave it on standby but still losing channels contact goodmans as you may need an update of the software
Oct 28, 2011 | Goodmans 255NS 25" TV
Does anyone have latest codes for virgin media tv 5401
new codes 5a 01 .........cf 53 0c 33 79 61 71 85..................d2 f9 3f 22 cf a7 d6 c9
12 pm 10 oct working
Oct 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Goodmans model gtvl32w26hdf. Switched itself off. have changed fuse, with not difference. blue standby light comes on, using remote press standby blue light goes off, screen remains black.
Good Day SIr, sound to me like your switching power supply is not working properly, there is an IC that controls the switching action of your power supply, this MAY be the reason why it stays off. locate the IC at the power supply section, replace it then test. There is also a possibility of open low value resistors near the switching transistor (very hard to locate). hope this helps.
Sep 23, 2009 | Televison & Video
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Aug 11, 2009 | Sony BRAVIA KDL-40V3000 Television
Tv not turning on from standby goodmans lcd 32"
problem is with power board, it seems a problem that is endemic to these sets, you can sometimes manage to reset by unplugging set for 30 mins repowering and sometimes it will come back on otherwise look at replacing board
Jul 23, 2008 | Televison & Video
Blower starts ans stops
May be a short in the wiring or a bad control board.
Jul 07, 2008 | Goodman CLQ36AR49 Air Conditioner
Goodmans ld3250hd
Sounds to me you will need a new micro controller, a friend had exactly the same problem
Dec 02, 2007 | Televison & Video
143 people viewed this question
 Grubhead
Grubhead
