Question about Kitchen Ranges
Precision scientific 818 low temperature illuminated incubator
I need instructions for a janoel 12 egg incubator please i have lost mine
Here are instructions from another website along with various links to download manuals and lead you to other forums talking about egg incubators:
Operating steps:
1. Put the mesh with the rail(big mesh)(fig.1) into the incubator.
2. Put the moveable egg tray (fig.2) on the mesh with rail, please do it within the rail.
3. Put the egg tray grille ( fig.3) into moveable egg tray according to size of egg for incubation.
4. Put the hatching egg into moveable egg tray(fig.5) for incubation, pay attention that after each egg is put into the grille, there should be 5mm clearance at least for convenient turning of hatching egg, inject 100ml water into the base after the hatching egg is put, check once for every two days so that the incubator is not short of water. Every water injection shall not be more than 100ml, take down the date of placing hatching egg so as to well control the hatching time. It's best to place the incubator on 60-100cm for convenient insertion of link rod.
5. When closing the cover(fig.7) , the link rod must insert the shifting slot of moveable egg tray, so that the egg tray can shift normally.( in other words, the cercley thingy coming out of the top with a rod in it has to be attached to the egg tray by putting the rod into the egg turner square hole to make sure that the incubator turns the eggs well)
6. Switch on the power supply after closing the cover, and set temperature according to push-button instruction and incubation technology. If the user has no time to care about the temperature, the temperature can be set at 38'c from the first day of hatching, and it can be set as 37.5 - 37.8C since the following day of hatching.
7. It moves to hatching tray 3 days earlier than incubation period for other poultry
8. It usually takes 3-4 days less than the number of incubation days for egg tray replacement, replace the egg tray once one or two hatching eggs are seen hatched, take all of the hatching eggs off from the incubator firstly, then take the moveable egg tray with mesh with rail out, check the water level, then put the hatching mesh( fig. 10) and egg tray in and put the hatching egg on the egg tray, shown as fig. 11.
9. After closing the cover and switching on the power supply, the hatching situation can be observed.
This was originally posted here: Janoel 12 incubator help
Best wishes,
Joe
Aug 25, 2016 | Hard Computers & Internet
I have 2006 Chevy impala 3.5l and it's slightly overheating and I just recently changed the water pump and thermostat but it didn't change, and when I turn my heater on the air flow is very low.
check the lower (suction) radiator hose that it cannot collapse, they usually have a metal coil inside to prevent this. If you left this out when installing the water pump it could be the cause..What temperature is the gauge reading? You could have been running too cool before and now that the new thermostat is in its up to normal temperature.
Low airflow through the heater is a separate issue and can be caused by leaves in the ductwork, a blend door not opening/closing fully, clogged heater core (are you a smoker?) Good luck.
Edit: I had another thought on this.. the cooling system needs bled carefully, air in the system can cause symptoms like you describe, look for a bleeder screw on top of the engine somewhere and make sure to let the air out of the system.
Jun 27, 2015 | Cars & Trucks
Why does my oven reach temperature then fail to maintain it
For a more precise answer I need more information like is it light illuminates when the failure is occurred. If the light illuminates then is faulty oven thermostat. If the light does not illuminates then is faulty main temperature limiter.
Dado
Aug 04, 2014 | Electrolux EOB6630 Ultrafan Electric...
Why does my oven reach temperature go off and not come back on
Dado
Aug 04, 2014 | Electrolux Ovens
How to change temperature on sanyo MIR62
The user manual is on the "net" to be downloaded; try it.
May 19, 2014 | Sanyo Heated Only Incubator MIR-162
Where can i buy chicken's eggs incubator in South Africa?
we are specializing fully automatic chicken egg incubators form 88eggs, 176eggs, 264eggs, 352eggs, 440eggs, 528eggs, 880eggs, 1056eggs incubator our incubator fully computer control and 96% hatching rate also include hatcher we deliver country wide visit us www.chickenincubator.co.za
you will find all our incubators and sizes in our website
Aug 22, 2013 | Bird Inc Digital Egg Incubator Thermometer...
Can i convert a decimal calculated into scientific notation, cause sometimes important numbers are missed, because they are cut off, and not converted into sci. notation automatically
This has nothing to do with the SCI display mode. Your calculator can only display a certain number of digits. The screen is limited. The maximum number of decimals you can display is 9.
By going into SETUP 1:FSE you can choose the display type FIX, SCI, ENG, NORM1, NORM2, then set the number of decimal digits.
Be it as it may, if a number is too large or too small it will be displayed in SCIentific format.
Note: Not all digits are important, only the first ones are. That is why in science one introduces the notion of significant digits. It depends on the precision of all the numbers involved in the calculation. NO RESULT can be more precise than the least precise number involved in its calculation.
Mar 02, 2011 | Sharp ELW535 Calculator
Internet network
can u be little more precise in your question
Dec 26, 2010 | Dopod 818 Pro Smartphone
2004 Saturn Ion - Parking brake will not go off. Precision Tune says "brake float switch broken - held in by piece of silicon. Pedal hard and functioning normal. Electrical problem relates to brake...
It's called Brake Fluid Level Switch Try a auto salvage yard > Couple of buck's
Brake System Indicator
The instrument panel cluster (IPC) illuminates the brake indicator when the following occurs:
• The body control module (BCM) detects that the park brake is engaged. The IPC receives a class 2 message from the BCM requesting illumination. If the vehicle is shifted out of park with the park brake engaged, the BCM activates an audible warning.
• The body control module (BCM) detects a low brake fluid condition (signal circuit is low). The IPC receives a class 2 message from the BCM requesting illumination.
• The IPC detects a low brake fluid condition (signal circuit is low).
• The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
Jul 08, 2017 | 2004 Saturn ION
How hot does this heat tape get up too?
Sounds like you are trying to hatch chickens. The heat tape is designed to keep pipes from freezing, and will not be warm enough for an incubator. Try a heating pad or electric blanket, or if you are really serious, you could just BUY an incubator
Oct 02, 2009 | Easy Heat Water Pipe Heating Cable
Kitchen Ranges Logo
499 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
