Question about Samsung LT-P227W 22 in. HD-Ready LCD Television
Change the vertical frequency to 60HZ on Samsung LT-P 227W
I moved recently to Europe and I can't watch anything on my Samsung LT-P 227W TV, it does not have vhold. I need to change the frequency to 50HZ, any idea how?
  • 2,326 Answers
I'm sorry to say that this LCD is for Standard NTSC, HD-ready, PC-ready only and will not work in Europe unless you can get some NTSC signal. There is not way to change the internal settings because you will also need to change the tuner and many other parts. At this point the cheaper solution will be to buy a multisystem LCD that will work with PAL and NTSC signals.
Posted on Jun 02, 2008
What is the frame output ic
Hello
Frame output IC means nothing, but the VERTICAL OUTPUT IC. Every TV will have it, which will scan picture vertically at 50 or 60 Hz. [1 HZ means one frame per second. Normally TVs will have 50Hz, 60Hz and 100Hz vertical frequency]. As vertical frequency rat increases, the picture fliker wil decrease. High level high-cost TVs will have 100Hz or even more frequency will be used for vetical scanning.
In the case of computer monitors, the vertical frequency will vary from 60Hz to 120hz. You can see its picture stability, at this high frequency.
The IC [Integrated Circuit Chip], which generates the vertical frequency and outputs it called the vertical output [frame output] IC. OK
Wish you a Proseperous and Happy 2012.
Gopakumar G, Trivandrum City, Kerala State, South India.
Dec 29, 2011 | Televison & Video
Is the Samsung Ln46a530 dual voltage ie (110 America - 240 Europe)
The tv power supply board is not the problems,that can add a transformer to solved it easily.The problems are US and Europe uses a difference tv signal frequencies.The US,Canada and Mexico are using a NTSC signal frequencies.Europe,Asia,Middle East and Africa are using PAL signal frequencies.U must have a tv that call REGIONS free tv to work in Europe and US same time.If u just have a standard LCD or a Plasma HD tv buy it in the US for example will not work in Europe
Jun 09, 2011 | Samsung LN46A530 46 in. LCD HDTV
How do you adjust the vertical hold on this TV?
Modern TV's haven't got a vertical hold control like in the old days. The TV system now uses a system of counting. For instance;
UK is 625line which is 15.625KHz line frequency. Divide it down by the correct amount and we get 50Hz frame frequency. There is no need for external controls. That is how copycode on video works. Supply 620 lines and in the end that is not divisable to give 50Hz so video cannot be copied as TV shows the wrong speed frame and will cause no colour and picture disturbance.
Likewise the same rule applies to USA 60Hz system.
Mar 02, 2011 | Samsung DLP HL-P5663W 56" TV
I moved to Europe with my Samsung Dryer, however, can make it work as power frequecies here are different 50Hz versus 60hz. How can I change the Power Source Frequency on a Samsung dryer. I am sure that it...
I have the same problem and i was thinking of changing the board 50-60 euros max. Also i have service manual with steps to put the machine in service mode but never found out how to reset power frequency sensors. If you need service manual dbenz@abv.bg
Oct 21, 2010 | Samsung DV328AE Electric Dryer
Will a TV made for Europe perform OK in the USA using a step-up transformer ??? Are the channel frequencies the same ??
NOT unless it is a DUAL frequency Standard, as Europe is PAL & SECAM, USA is NTSC. Also the HERTZ is different too 50Hz Europe, 60Hz USA, so really NO. IF it would work, it would have an international power supply, meaning it was usable any where in the world. and also it would have a multi tuner. Otherwise it will NOT go.
Mar 15, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Moving objects extremely blurry in SAMSUNG LCD-football, golf,etc
This is a problem that will pretty much just be there on this TV. I know it has an awesome picture...as long as nothing moves. You can try putting it in "Game Mode" in the user menu and that usually takes care of it but you didn't buy the 120/240 Hz tv to watch it in 60Hz. I would say exchange it, and in my opinion buy a good plasma :)
Jul 08, 2009 | Samsung LN55B650 55 in. LCD HDTV
Samsung LCD TV series 5 240Vac, 50Hz will it work with 60Hz?
no only the voltage is critical.the only point is you have to select right counrty and tv sound and picture system on setup menu!
Jun 11, 2009 | Samsung LT-P227W 22 in. HD-Ready LCD...
Akai tv
Please check the Broadcast System setting of the TV. It should be in the correct setting. If you are in the USA, it should be NTSC and Vertical frequency 60 cycles, if you are in Europe, then it should be PAL (I, or B/G) with 50 cycles Vertical frequency. Once you have made the correct selection, the problem should resolve.
Jan 30, 2008 | Televison & Video
Green shadows in dark scenes
You should contact Service Center to resolve this issue.
Jan 22, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
Samsung WS32Z429T
This looks like it could be a problem with leakage of the 60Hz vertical scan frequency into the picture this is also called 60Hz hum. What usually causes this is poor filtering on the power supply or decoupling capcitors in the vertical section have begun to malfunction. This problem is easy to fix if you have the equipment to isolate the problem, I would suggest that you take this set to a TV repair shop to have it analyzed and repaired.
Sep 22, 2007 | Samsung WS32Z308P 32" TV
Samsung LT-P227W 22 in. HD-Ready LCD Television Logo
697 people viewed this question
Henry  Thomas
Henry Thomas
