Question about Brother MFC 210C All-In-One InkJet Printer
My scanner is not working. How can I reset it?
    Scholar:
  • 192 Answers
Howdy there! Please do not hit me, but, to reset it, you just turn it off, but the key is a 12 minute kill time, that will reset the chip and allow for clearing of the problem, if it does not, please write right back and we can tackle it further, but this should do the trick.... take care.... Guy
Posted on Oct 15, 2010
Radioshack pro 67 need to factory reset
I'm not all that familiar with the unit, but found these instructions for you at the link below. REMEMBER: you are going to erase EVERYTHING when you do this. Quoting manual:
RESETTING THE SCANNER If the scanner's display locks up or does not work properly after you connect power, you might need to reset the scanner. Caution: This procedure clears all the information you have programmed into the scanner. Before you reset the scanner, try turning it off and on to see if it begins working properly. 1. Turn off the scanner. 2. While you hold down the 2 and 9 keys, turn on the scanner." (End of quote)
Click on the link below and choose "Troubleshooting" from the menu.
RadioShack PRO 67 Scanner 200 0512
Jul 15, 2014 | Radio Communications
How to reset my Uniden BC75XLT Bearcat Scanner .
Resetting the Scanner
If the scanner's display locks up or stops operating properly,
CAUTION: This procedure clears all the information
you have stored in the scanner. Before you reset
the scanner, try turning it off and back on to see if
it begins working properly. Reset the scanner only
when you are sure it is not working properly.
2. While holding down 2, 9, and Hold, turn on the scanner.
It takes about 3 seconds to initialize and CLEAr appears.
Jul 08, 2014 | Uniden Bearcat BC75XLT Police Scanner
Can,t get scanner off all channels locked mode
Please try this!!
You may need a soft or hard reset. Here's some reading and instructions.
Please use this first!
resetting your scanner
1. Turn off your scanner, and then turn it on again.
2. Insert a pointed object into the reset hole on the back
of the scanner. Then, gently press and release the reset
button. Pressing reset does not clear the scanner's
working memory or the V-Scanner folders.
If this doesn't work here's step two! CAUTION. THIS WILL ERASE EVERYTHING, but it MAY Fix the Problem!!
Initializing your scanner clears all information stored in your
scanner's working memory. Initialize your scanner only when
you are sure it is not working properly. V-Scanner memory is
not affected when you initialize the scanner.
1. Turn off the scanner, and turn it on again. First, the DSP
boot version, and then Welcome To Digital Trunking appears.
2. Press 0. The following messages appear on the display:
System Tests
Select Test
Exits if no
Key Press
3. Press 1. The following messages appear on the display:
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
4. Press ENT. The following messages appear on the display:
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
5. Do not turn off your scanner until the initialization is
complete. When the initialization is complete, M000 and
Bank 0 Ch 00 appear on the display.
Hope this works.. Happy Scanning
Nov 20, 2012 | Radio Shack Pro-96 Scanner
I have a radio shack pro96 i can not reboot it to restall the v scannfolder what can i do i have tryed everything to wipe it clean
Sounds like the motherboard is corrupted. Please try these steps again. Thanks!! Happy Scanning!!
I need to ask you this. Normally one bank can't be closed.
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Apr 11, 2011 | Radio Shack Pro-2096 Base Scanner
I have A radio shack PRO-2096 and have not been able to use it in over A year. it reads all channels locked out. I can't unlock it.can someone please help me?
Please try this!!
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Jun 23, 2010 | Radio Shack Pro-2096 Base Scanner
After I enter a frequencie the enter button doesnt work to enter
If all else fails, you can RESET or INITIALIZE the scannerto bring it back to normal operation.
To RESET:
- Power the scanner OFF
- Power the scanner back ON
- Insert a pointed object (paper clip, penpoint, etc.) into the RESET hole on the back of the scanner
- Gently press and then release the RESET button inside the hole.
NOTE: RESET will NOT erase the data that you've programmed into the scanner.
If RESET doesn't clear the problem, you can carry out the more drastic INITIALIZE process.
- Press 0 then 1 while "Welcome to Dual Trunking" is displayed.
- "Initializing Please Wait" will appear for about 2 seconds.
DO NOT power the scanner OFF until the INITIALIZE process is complete (M000 and Bank 0 Ch 00 appear on the display). The INITIALIZE procedure will reset the scanner to original factory settings and erase all data that you have programmed.
BillB
Feb 19, 2010 | Radio Shack Pro-95 Handheld Scanner
IT WON'T BUDGE. IT READS ALL CHANNELS LOCKED OUT. PLEASE HELP
System Tests
Select Test
Exits if no
Key Press
Factory Init
Erase Memory
ENTER if Yes
CL to EXIT
Initializing
Clr Main Mem
V-Scan is OK
Please Wait
Hope this works happy scanning!!
Jan 12, 2010 | Radio Shack Pro-2096 Base Scanner
I have a uniden ubc73xlt handheld scanner,can't program channels, keeps saying locked out, have tried to unlock as per instructions but not unlocking.
Try a master rest:
properly, you might need to reset the scanner.
you have stored in the scanner. Before you reset the
working properly. Reset the scanner only when you
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
Feb 22, 2009 | Uniden BC72XLT Handheld Scanner
Radio Shack PRO-91 scanner keypad doesn't work
Try a master reset. You will lose all of your current programming but it resets the unit back to its original state when you purchased it. here are the directions from page 53 in your manual.
and CLEAr appears.
elijam1
http://www.scannermaster.com/?Click=37131
Dec 25, 2008 | Uniden BC72XLT Handheld Scanner
Resetting dosen't work as per the manual
Turn the scanner off,remove the batteries,pull the power cord out of the scanner,push and hold the 2, 9 and hold buttons.While holding the buttons in, plug the power cord back into the scanner.This will reset the scanner to default settings.
Jan 04, 2008 | Uniden BC370CRS Base Scanner
Brother MFC 210C All-In-One InkJet Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
