Question about Husqvarna Lily 540 and 550
Husqvarna lily 540
Bobbin stuck on winder. cant get off
    Problem Solver:
  • 16 Answers
Bobbin wound too tight. remove thread first then pull off bobbin.
Posted on Jun 28, 2008
Downloadable lily 550 manual
I suggest you go to the website
LILY 550
and contact them, by email, telephone or letter
May 19, 2016 | Husqvarna Sewing Machines
How to remove top cover of lily 550
Make sure the presser foot is in the up position. This will open up the tension disks. It takes a lot of patience to remove imbedded thread. Use tweezers to grab the thread. Rock the handwheel backwards and forwards to help release the thread. If all that fails, have it cleaned by an authorized Husqvarna Viking dealer. You can find your nearest dealer at the viking website - http://www.huqvarnaviking.com/us
Jul 12, 2014 | Husqvarna Lily 540 and 550
Sounds like you need to remove some thread off the bobbin to get the pressure off. Sometimes if you wind too fast or you have a poor quality thread, the thread will stretch as it winds and causes to bobbin to compress onto the winder shaft.
Good Luck!
Jun 15, 2010 | Husqvarna Lily 540 and 550
Cant remember how to program names etc on my lily sewing machine
If still an issue, suggest you visit an authorized Husqvarna Viking dealer for assistance. They are usually eager to help. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Dec 07, 2009 | Husqvarna Lily 540 and 550
Sometimes when a bobbin is wound very fast the plastic gets hot and misshapen, and you can't remove it. Nothing for it but to break the bobbin - it's useless now anyway even if you could get it off in one piece. Pull off as much thread as you can and use pliers or something similar to break enough of the bobbin so it will come off. You need to take care not to let little broken pieces fall into the machine mechanism and take care not to yank too hard on the bobbin winder spindle. If all this scares you too much, take the machine to your dealer for help. And remember to slow the machine down a click or two when you wind bobbins! (It may be of some comfort to you to know that every user of plastic bobbins has done this at some time!)
Jul 21, 2009 | Husqvarna Viking 1
Bobbin does not wind all the way up
I have had this problem, easily fixed by twisting the rubber knob that is in contact with the spool to the left.
Feb 08, 2009 | Husqvarna Lily 540 and 550
Husqvarna Optima
Good luck.
Jul 23, 2008 | Husqvarna Lily 540 and 550
How do I reinsert the bobbin case...
Hi PaQuilter,
Right when you're in the middle of a project - ALWAYS when something goes wrong!
Have you tried turning the bobbin the other direction in the bobbin case? On some machines the direction the bobbin turns can really make a difference.
If you've tried that and still not working:
  1. Make sure the needle is fully up in the needle hole - loosen needle screw, push needle up as far as it will go and re-tighten screw. Drapes are heavy work and the vibration of the machine may have caused the needle to slip a bit.
  2. Re-thread machine from scratch - i.e. take thread completely out of thread path and start at the very first guide from the spool. The thread can sometimes pop out of one or more of the upper guides/paths and this can cause the problem with the bobbin thread.
  3. If the above doesn't cure the bobbin issue, your machine may be out of time and require a Husqvarna tech to look at it/fix it.
Hoping the problem is cured by the above and doesn't require a trip to the sewing machine doctor.
Happy sewing - good luck with the drapes,
Kim & Linnette
Jul 20, 2008 | Husqvarna Lily 540 and 550
Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
219 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
