Question about LG LMVM1935 Convection/Microwave Oven
LG LMVM1935SB OVER COUNTER MICROWAVE
I HAVE THIS EXISTING MICROWAVE.  I AM IN THE MIDST OF A KITCHEN REMODEL AND WOULD LIKE TO USE THIS AS A COUNTER MICROWAVE.  IS THIS POSSIBLE?
THANK YOU FOR YOUR INPUT.
TLBOLIN
  • 100 Answers
The unit will work just fine on the counter, but obviously the lights underneath won't show and the exhaust fan won't be of much use.
Otherwise, it's perfectly ok!
Posted on Jul 06, 2008
Was removing a burned out bulb in my LG LMVM1935SB LG Microwave cooktop/oven. The bulb broke, and we had to finish getting the bulb out of the receptacle. The other light worked, but now apparently is...
When removing a bad bulb ALWAYS unplug the unit. If there is power going to the bulb and when you try to take the bad bulb out and the glass seperates from the bottom base the leads will short out and you will blow your main curcuit board. Then the entire board must be replaced. It will blow out a component on the board or blow a trace off of the back of the board. either way either baord repair or replacement will be needed. ALWAYS UNPLUG THE UNIT WHEN REPLACING A BULB!!!!
Sep 18, 2017 | LG LMVM2075 Microwave Oven
Nothing happens when plugged in
The main fuse in the microwave oven has probably blown, it usually goes when a part has failed.
May 07, 2012 | GE SpaceMaker Microwave Ovens
Broke glass turntable for LG microwave model lmVM1935SB I need to replace itt
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Jan 12, 2011 | Microwave Ovens
Tappan TMV151FS over range microwave starts to work and then dies
Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
Microwave oven controls don't respond and oven comes on by itself. lmvm1935sb
HI, this is a defective touch key pad. replace this key pad asap if possible.
Jun 20, 2009 | LG Microwave Ovens
LMVM1935SB - Over the Range LG - fan keeps coming on, beeping
The fan will come on if you are cooking below and the area gets hot.... is this when it happens? Sometimes random beep could be a power blip... not long enough for a reset of all things electrical
Apr 19, 2009 | LG LMVM1935 Convection/Microwave Oven
Flashing 88:88 display - no keypad response - no light
See if there is a hard reset for unit to restore it to factory default. Contact the manufacturer for the hidden code to accomplish this. Otherwise, it is ng.
Sep 02, 2017 | Sharp R-1500 Microwave Oven
LG LMVM1935SB Microwave won't heat anymore!
With these symptoms, I would suspect you have a bad magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
http://www.gallawa.com/microtech/xformer.html
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or
visit here. You can get warranty info & find a local authorized servicer.
L.G. / Goldstar owner's manuals can be downloaded here.
Nov 21, 2008 | Microwave Ovens
LG LMVM1935 Convection/Microwave Oven Logo
103 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
