At side of heater x3 knobs. Top two understand but bottom one not sure if a termostat or twenty four clock for model delonghi hc0430ts electric heater
  • 20 Answers
Thermostat.
Posted on Oct 15, 2010
How to set the clock
Press the B.Boost button (all the way to the right of the button cluster along the bottom of the receiver) for at least a second until the menu is displayed. Press the top and bottom sides of the control knob to select CLCK. Press the center of the control knob for at least a second (the clock display will blink). Then use the top and bottom sides of the control knob to set the hours and the left and right sides of the control knob to set the minutes. Then press the B.Boost button to exit the clock adjustment mode.
The owner's manual for the KDC-138 is available here: http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kdcmp238.pdf .
I hope this helps.
Mar 29, 2011 | Kenwood KDC-138 FM / AM Receiver
How Do I Set My Clock on My Kenwood KDC-MP208?
1:- Select Clock Adjustment mode Press the top or bottom side of the Control knob. Select the "ClK ADJ"/ "ClCK" display. 2:- Enter Clock Adjust mode. Press the centre of the Control knob for at least 1 second. The clock display blinks. 3:- Adjust the hours. Press the top or bottom side of the Control knob. Adjust the minutes Press the right or left side of the Control knob. 4:- Exit Clock adjustment mode, Press the [B.BOOST] button.
Now whats the time, Gotta get my tea.
Regards, Dave
Mar 20, 2011 | Kenwood KDC-MP208 Car CD/ MP3 Player
Set the clock on KDC-138 car stero
hi if you click on this link it will bring up the instruction manual for your model. as well as the 238.
setting the clock is on page 10
hope i have helped, please dont forget to rate.
Jan 12, 2011 | Kenwood KDC-138 FM / AM Receiver
Set clock on kdc-mp208
Here's the owners manual for your KDS-MP20, from the kenwood-usa site:
http://kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kdcmp238.pdf
The following is found on pages 10 and 11 of the manual:
1. Enter Menu mode
Press the [B.BOOST] button for at least 1 second.
"MENU" is displayed
2. Select the menu item
"CLK ADJ" can only be performed when in Standby Mode
Manual Clock Adjustment
1. Select Clock Adjustment Mode
2. Press the center of the Control knob for at least 1 second
-the clock display blinks
3. Adjust the hours
Adjust the minutes
Press the left or right side of the Control knob.
4. Exit Clock adjustment mode
I hope that helps.
Mar 27, 2010 | Kenwood KDC-MP208 Car CD/ MP3 Player
Clean the filter : Lasko Model #5812
First make sure heater is unplugged. Next, on the side of the heater locate two holes (see image) these are what's keeping everything in front together. unscrewing these and genty pulling sides out lwill release the top filter and front where control knob is and bottom filter where the heated air comes out. Clean filter & re assemble.
Nov 30, 2009 | Lasko 5812 Heater
De Dietrich Oven - Clock tripping back to 00:00 means I cant turn
The part that needs replacing is the clock timer.
FIRST: ISOLATE THE CIRCUIT.
The front fascia is held on by three clips. Take off the two knobs and gently pry away the fascia fron the left, right and top centre.
The clock timer is held in by four plastic push clips at the top and bottom about 1cm in from the end. Push them in and pull the timer out.
There are now three wires on push clips attached at the back.
Do not take the colours for granted. On my oven just repaired the Live was Black and the Neutral was Red! The black marked 'C' is the input. The side by the trip switch is the output. The Red goes on the other side.
When the timer trips it causes the circuit between the input and output to break.
You have two options now:
Read the serial number of the timer and try and order it (expensive), swap the cables over.
Carefully run an electrical cable between the push clips on both black cables making sure you leave no exposed wire. Your timer and clock however will never work, the oven just does not care about it anymore.
Note: I am not an oven engineer, I am an electrical engineer in another field and have tested voltages and current and believe this to be safe. I have done this on my own oven.
Sep 12, 2009 | De Dietrich DOC310 Electric Single Oven
I need six knobs for a 1950 Frigidaire model RM-45
I have the same model stove for sale. here is my number 678-644-2161 samantha
Jul 23, 2009 | Ovens
I need to reset my Delonghi radiator. it overheated
Unscrew the four screws holding the front faceplate on (two are on the bottom of the radiator). From the bottom end gently pry up the faceplate, it will stay attached at the top end near the temperature selector. Look inside and you will see a black bridge like piece of metal with a plastic and metal thing stuck to it's center with two wires leading into it. It's basically a connection that melts when high temperatures are reached, therefore it must be replaced (pictured). You can bypass this by prying the metal bridge out, removing the wires leads from the switch and connecting them using a wire nut. BE AWARE THAT THIS WILL OVERRIDE THE HIGH TEMPERATURE SHUT OFF MECHANISM, so don't use it for drying off your coat again._361.jpg
Feb 08, 2009 | DeLonghi 6707E Oil Filled Radiator Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
