Question about Flotec 3.4 Hp Floodmate Submersible Sump Pump
The float won't activate the pump when the water is higher than the drains.
  • 35 Answers
Its possible you need a new float switch. You can remove the float switch and try running the pump without it. This will determine if its the switch or the pump itself.
Posted on Oct 17, 2010
Pump won't shut-ff
Hi Ron...
Check your float switch....sometimes they can get stuck to cause this problem of not shutting down after draining the orginal water.
Take the float switch and move it up and down...this may help to clear the stuck switch inside of the float
Bud
Apr 24, 2013 | Utilitech 1/3-HP Cast-Iron 95 GPM Sewage...
I have sasui mobile type ari condition uni. there is a problem with water coming out from back side. water not going though drain line. cooling dosent have problem.
Check the elevation of your a/c unit. The elevation at the back should be lower than the front. Test by pouring water from the cooling coil and check if the water you pour goes to the condensate drain line. If water does not comes out, check if it has a small drain pump and a float switch to activate the drain pump. The float switch that does not actuate if water level rises may be the reason why water does not comes out of the drain line.
Sep 09, 2011 | Heating & Cooling
Gu1200xlkb0, water left in tub after wash. Checked hose for clog. Drain pump working. Drain loop check valve functioning.
Hello & Welcome to FixYa
If the drain pump is taken apart and cleaned completely then the problem can be with the float switch. You have to take out the bottom front panel out and then clean the drain filter pump assembly completely. Please get back to me if you have any other questions.
Kevin
Jun 28, 2011 | Whirlpool Dishwashers
Hello I have a Bosch dishwasher model no:
Hello Zub,
It's most likely a fault with the control module or the drain pump. Please follow these instructions to detemine the likely cause of the fault and, therefore, what to do next:
1. Turn the programme selector to any wash cycle but don't press start.
2. Open the door and pull out the lower rack
3. If the washer is dry, pour roughly a pint of water into the sump in the bottom of the washer
4. Locate the float (the mushroom) and lift it . . .
When the float is fully lifted (about 3/4 of an inch) the drain pump should start and drain any water from the washer. This activates the anti-flood safety feature and the pump should continue to run as long as the float is lifted. The power supply to the drain pump bypasses the controller so this is the best way to determine if the drain pump is faulty.
If the water drains when you lift the float . . .
The drain pump is working but it's not receiving the signal to start from the controller during a wash cycle. It may be a wiring problem, but more likely that your control module will likely need to be repaired or replaced. These cost about £100 - if you replace it yourself.
If you can hear the pump humming but water does not drain when you lift the float . . .
There may be a blockage somewhere or the pump impeller may have jammed or broken away from the driveshaft. Try lifting and dropping the float rapidly about 10-20 times. Repeated stop/start signals to the pump motor can free a stuck impeller.
If nothing happens when you lift the float . . .
There is either no power to the pump motor or, more likely, the pump motor has failed. You will need to test the motor to determine whether or not it needs to be replaced. You will need a Torx T20 screwdriver or screwdriver bit to remove the kickplate under the door and an ohm / multi-meter to test the motor.
The drain pump motor should give a resistance reading of between 110 and 260 ohms across the live/hot and neutral/common terminals if the motor is good. In most cases, the reading is about 160-170 ohms.
I'd suggest testing the drain pump using the float as detailed above, then let me know the results. I'm happy to provide further assistance once the likely cause of the fault has been determined.
Hope this helps.
Regards,
BElectric
Apr 10, 2011 | Bosch Dishwashers
Meile G653 SCVI dishwasher will not drain
I tried the one below on this site (ie run briefly without the non return valve in place, didn't see objects but perhaps loosened something). So I hope it can help you. Best wishes.
Best Solutionposted on Mar 02, 2010
noavatar_s.gif taurustech
Rank: Guru miele.gif dishwashers_small.png Expert
Rating: 92%, 65 votes
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Apr 03, 2010 | Dishwashers
My bosch dishwasher will not fill with water. I have manually filled it but it just pumps it out when I switch it on.
the unit is going into drain mode. check your hose for leaks. when water leks in the base of the unit the float switch is activated and the unit will stay in drain mode until the water is removed. check float by removing side panel and look into bottom base for water.
Feb 25, 2010 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Feb 22, 2010 | Miele 24 in. G653 SCVi Plus Built-In...
Sump pump float adjustment
This really depends entirely on you. the higher the water level the less frequently it will run. most motors use more power to start than they do to run so starting less should save you money.
Nov 16, 2009 | Zoeller 10-0034 Switch-Mate Pump Float...
Will not fill. Drain pump runs all the time.
Sounds like flood switch has been activated. They have a float in the base of machine, which will activate drain pump if a leak has occurred. Unplug from power- remove right hand side panel, check to see if any water in base. If so, leak has occurred. Clear water from base and test run to locate leak
Aug 08, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Motor sounds when the dishwasher is turned to the on position but the dishwasher won't turn on.
Sounds like the drain pump is on. Pour in some water, and see if it drains out. On the LG they have a float switch on the left side, it could be stuck up causing the drain to activate.
Other units have a float switch on the bottom floor and there could be water or the float could be warped.
Sgt 48
Jun 06, 2008 | Dishwashers
Flotec 3.4 Hp Floodmate Submersible Sump Pump Logo
240 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
