Question about Casio Protrek Triple Sensor PRG50T7VDR WW Watch for Men
My prg50 the comp not function rigth now - Casio Protrek Triple Sensor PRG50T7VDR WW Watch for Men
Set date & time
mcdevito75 here, Generally you need to operate 2 buttons, to set the functions, try pressing the MODE button see the display flashing, press MODE again to see each function, when at the function you want to adjust, press SET, press MODE again to move onto next function, once all functions are set, press MODE for staedy display. If this fails, look for a small watch repair shop in your area for help.
Feb 11, 2011 | Casio G-Shock GW500A-1V Wrist Watch
Touch function is not working
I had the same issue. After installing the battery and trying to calibrate several times... to no avail.I tried pressing the T button, keeping it pressed down and then install the battery. It give you a mode or function setting ( I'm not sure what it means). i then press the T button and it cycles through these mode setting. I synchronized the hands and then was able to get the: altimeter, compass, meteo, date and time working. The temp, chrono still doesn't work.
I think getting all the functions to work, depends on the mode setting... but i don't know the correct setting.
Jun 30, 2010 | Tissot T-Touch T33759851
Altitude auto rec function
I cannot delete my memory of alti function
Jun 20, 2010 | Casio PRG-40T-7 Pathfinder
I have model 2271 PAG 40 it seems to be stuck in some kind of display mode. switching from comp to baro to alt.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please
Mar 22, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
Need instructions for mens Slazenger competitor, comp 2 watch. It has no product numbers on the watch.
need help to reset time on 13605 digital watch any help would be great
Oct 17, 2009 | Watches
Lost maual to amw-700 casio watch
advance the mode 6 times to H S mode and push left upper button till the digital time flashing, then push rigth doun or up buttons to advance, please read manuals
Nov 05, 2008 | Casio AMW700B 1AV Pathfinder Watch
Display and all functions other than time have ceased to function
I had this problem after the battery was replaced at a jewellers. It turns out they had used the wrong battery as it only lasted a week.
May 16, 2008 | Tissot T-Touch T33759851
Pathfinder watch ??
that old of a watch would need to be sent in. Send it into repairs and they will send you an estimate on what it would cost to fix it. Give them a call at 800-706-2534 option 2.
Mar 07, 2008 | Casio Triple Sensor Pathfinder PRG60-1AV...
My old field watch is showing an err (error) and the internal klight wont work
I changed the battery in my PRT 50 but Alt and Baro still not working the light and Compass however is??
Oct 27, 2007 | Watches
Casio Protrek Triple Sensor PRG50T7VDR WW Watch for Men Logo
77 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
