Question about D-Link DWL-G700AP 802.11g/b Wireless Access Point
How can I install the DWL-G700AP when on the installation CD there is no quick-install for mac?
  • D-Link Master
  • 7,733 Answers
Give a try at D-Link - TechSupport FAQ.
Posted on Oct 15, 2010
Hi i have a d-link dwl-g700ap and i cant acces the wifi from my garmin-asus a50 nuvifone , i know its not the phone because i can connect on everyother network . please help
Go to your management software inside the access point. Default IP address is 192.168.0.50. If you changed it, go to that address with a browser. Default login with "Admin" without a password. If you set up a different administrator id and password then login with those credentials.
Go to the "Advanced" tab. The setting on the MAC address settings are important here. Hopefully you know how to get the MAC address of the phone. I don' have the same phone so I can't tell you how to get it. Ensure that you have entered in the phone's MAC address and any other devices that you connect wirelessly to. If you have registered the MAC address under the second radio button or you have the first radio button clicked, you have a WEP or other password issue. Many public access point don't filter any MAC address and don't require passwords. When setting up at home, you do have to at least these up.
Hope this helps.
Aug 06, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
Can I use the dwl-g700ap as a repeater?
Yes, the DWL-G700AP can be setup as an AP or a repeater as long as your current wifi router is also 802.11g/b.
You can find instructions here: http://www.docstoc.com/docs/2583739/How-do-I-configure-repeater-mode-on-DWL-G700AP
Regards, Chris
May 18, 2011 | D-Link DWL-G700AP 802.11g/b Wireless...
I have the d-link G700AP wireless access point that works well with my thinkpad laptop. I want to know if I can connect to a wireless printer soon to be purchased
You should be able to connect to a wireless printer. Before trying to connect it just read the instructions supplied with the printer and do a dummy run without turning anything on so you have an idea what you should be doing.
Make sure you're installing the right drivers for your version of windows, if not on the disc, download them from the manufacturers website.
Nov 30, 2010 | D-Link DWL-G700AP 802.11g/b Wireless...
I can't hard reset my DWL-G700AP even though i press the button longer than 5 seconds. the device doesn't reboot. what seems to be the cause?
do one thing pull out the power cable from the device after then same time put the power and press the reset button on same time press up to 10 sec after then press one or two time then you get it
Apr 14, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Installation problem
problem in the firewall ,ip address, proxy server, and antivirus if there all then change it disable the firewall, proxy server, any antivirus and check the ip address is give right or wrong
Feb 15, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
I receive excellent signal from DLink dwl-g700AP but can't browse
On this tip you can find an easy check list let me know if you need more help
Feb 02, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
Unable to update firmware
Your router latest Firmware I can see on D-link website is 1.02
If you are referring to German web site page showing a dwl-g700ap_fw_revB_v213b06.zip file be sure to follow the instruction to UNZIP the web_dwlg700ap_v200_r11_0408.bin file:
DWL-G700ap Firmware Update
- Browser starten
- Konfiguration des DWL-700ap aufrufen (Standard IP 192.168.0.50)
- oben auf Tools
- links auf Firmware
- auf den Knopf Durchsuchen klicken
- die Firmware Datei (web_dwlg700ap_v200_r11_0408.bin) auswählen
- auf Apply klicken
Wenn die Firmware installiert und der DWL-700ap dann neu gestartet ist klicken Sie oben auf Tools/System/Restore to Factory Default.
Danach ist die Firmware übernommen.
If you did not unzip the bin file router cannot run it as firmware update
More over be sure to run the update via LAN cable connection (no WLAN)
Jan 24, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
But the DWL-G700AP...
Is this access piont connected to a router? Can you get online through the router? If you can go online through the router also check the status of your wireless connection. Make sure its connected and it's getting a valid ip address.
Aug 22, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
DHCP option is disabled when LAN IP is Dynamic on DWL-G700AP
that is right the access point does not have a dhcp server. that will give an ip address to all of your computers or device connected to it wireless. If you have a modem with a dhcp server there will be no problem with the IP but if the modem does not you must have a router and now an access point.
Aug 07, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Factory reset dwl g700ap
Bill,
I have here the steps on how to reset your device.
To perform a reset, please follow steps below:
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Jun 05, 2008 | D-Link Air Xpert DWL 7000AP (DWL-7000AP)...
D-Link DWL-G700AP 802.11g/b Wireless Access Point Logo
511 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
