Question about Siemens Computers & Internet
SIEMENS SE587 router on Windows XP is unable to connect to internet via ethernet cable - checked cabling etc - Online light is orange
  • 44 Answers
What internet service do you have?
Posted on Jun 02, 2008
NSN 1600, restored to factory settings, no internet access, internet light blinking fine, help
Some people find configuring Nokia Siemens Residential Router 1600 with BSNL is a little difficult. So I would like to present a tutorial to setup Internet connection with BSNL using Nokia Siemens Residential Router 1600. Just like other BSNL modem/ router models, we do not need any setup disc to configure Nokia Siemens Residential Router 1600. All we need is to follow some simple steps and adding some values. We can also setup wireless and wireless security from the web based setup page Configure Nokia Siemens Residential Router 1600 In order to configure Nokia Siemens Residential Router 1600 with BSNL follow the steps below.
1. Connect Nokia Siemens Residential Router 1600 to computer using Ethernet cable
2. Power on Nokia Siemens Residential Router 1600
3. Type 192.168.1.1 on address bar of Internet Explorer and press enter
USER Name: admin
Password : admin
Now you can access the web based setup page of Nokia Siemens Residential Router 1600.
Apr 09, 2013 | Computers & Internet
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Unable to connect to the internet using a linksys wireless adapter. Connects to the router but can't find the internet.
Isolate the issue by directly connecting the PC to the router via ethernet cable (if possible).
If you were able to get online while hardwired connected to the router, then check the IP address of the wireless network connection, check the wireless security if the network key matches.
If you cannot get online while hardwired to the router, then directly connect the computer to the modem.
If you were able to get online while directly connected to the modem, then the problem is the internet settings on the router. Check the WAN configuration, such as DHCP or PPPoE.
If you cannot get online when directly connected to the modem, then you will need to contact your Internet Service Provider.
Nov 07, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
I have a siemens gigaset se587 wireless router and a xbox360 network adapter it does not connect up to my network where am i going wrong I have connected it up using the ethernet cable and it works fine...
sorry to bother but i cant get xbox live to work with the ethernet cable, where did u plug the ethernet cable into? ive tried different places and none seem to be working
Oct 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Interconnect two remote sites
500m ethernet cable is at its max.
you can use 4 pair (8lines)telephone wire to semulate ethernet cable (unshield). you will pickup noise on the line.
only one unit can be the moderm to access the Internet the other has to be a router. (Lan port only). and you cansetup both to have wireless access.
Sep 22, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens gigaset se587 wlan dsl
HI
A flashing ADSL light on the router means its not getting constant broadband signals. Make sure it is connected to the adsl filter without any extensions and the filter should be directly connect to the main phone socket and not to an extension socket. Also check if the phone socket has 1 or more than 1 ports on it. If it has two port its most likely a SSFP socket which does not require a filter as it is inbuit.If all the connections are fine try changing da filter.
Sep 07, 2008 | Siemens (120-5830-001) Modem
I just recieved my Siemens Gigaset SE587 WLAN dsl router and i set it up but the only light coming on is the power light,is the router faulty or damaged?
Are all the cables connected correctly?
Are the DSL settings in?
If it's only the power light, and no WLAN, LAN, DSL or Internet lights on, it sounds like it may be faulty. Is it brand new or second hand?
Aug 22, 2008 | Siemens Computers & Internet
Wireless conections
Try the http://192.168.1.1 to access the router config page (needs Ethernet cable to be connected to the Router)
If config page still does not appear, then check your Internet Explorer settings> Security Level (not set to custom) If it is, then choose RESET ALL ZONES TO DEFAULT LEVEL and then try this address again. It worked for me.
Dec 26, 2007 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
185 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
