Question about HP COLOR LASERJET CP 3505 N PRINTER
When I print, it tears up one strip down the paper and smears the ink
    Scholar:
  • 192 Answers
Howdy there!!! You have a small object in the paper intake well. If you ae able to get an air can, spray the air through the entire length of the well to attempt to dislodge the item. Q-tips with alcohol are great to use to get those pieces that get stuck in there as they stick to them and the alcohol dries quickly. If there is nothing to the naked eye, tip the printer on its side and lightly tap the back to attemp to dislodge that way too. I once had a printer in the ER at the hospital and a child put SMALL pieces of crayola in it, the heat melted the wax, of what a pleasure that was..... PLEASE let me know if this does not fix it, we can go further if needed. Take care... Guy Sutton
Posted on Oct 15, 2010
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
Ink from my deskjet 5650 smears off my glossy postcards.
Hello there jbaerpynes.
You must use HP branded glossy paper in this particular printer as recommended by the manufacturer. Because HP ink is much finer than most other inkjet printers, the ink sometimes does not set in properly on generic papers, especially glossy ones, and can smear right off.
Try new paper and get back to me. If you have any other questions, please don't hesitate to comment on my post. If I helped you, please give me a positive rating.
Thanks.
-Phil Traversa
Aug 19, 2009 | HP LaserJet 1300 Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
I turned my printer on and it said open door. clear cariage jam then press enter what is that?
Hi and welcome to FixYa,
with the indulgence of mackenzie123...
A 'Carriage Jam" error indicates that the holder of the ink cartridges (called carriage) which includes the print head cannot move or complete its sideways movement. Three (3) possibilities:
  • it is really jammed. Paper debris is blocking its path and therefore must be cleaned;
  • the guide rod / rail has lost / dried up its lubricant and therefore the carriage could not move easily. The guide rod/rail as the name implies is the provides the path of motion;
  • ink smears on the encoder strip. The encoder strip is the long narrow plastic with barcode like markings. This tells the carriage where it is. An ink smear would block the markings and confuses the carriage.
Hope that this be of initial help/idea. Good luck and thank you for using FixYa..
Apr 19, 2009 | HP PSC 2210 All-In-One InkJet Printer
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
Nov 24, 2008 | Xerox Phaser 8560DN Laser Printer
Black smear of ink at end of lines
Please load the printer with at least 10 sheets of plain paper then press the start button. This will dry or clean any ink found on the rollers.
Continue to run blank pages through the printer until no more ink is found on the paper, then attempt printing. If ink stains, streaks or smudges are still present, the printer may need service.
May 23, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Black line on back of page
It sounds like you have a black ink leak and it is smearing onto the paper when you print. I don't know any reasons for this except if you topped the black ink up yourself, and didn't re-block the hole you made. Then I guess the ink would gravity drip onto the paper tray while you weren't printing. Otherwise I would suggest changing the print head, but this might be expensive.
Dec 28, 2007 | Canon Pixma MP500 All-In-One InkJet...
Dell A940 smeared printing
Our Dell AIO A940 stopped printing black ink (it went throught the motions but he paper came out blank). Finally got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
Maybe it will work for you! Good luck!
Dec 11, 2007 | Dell A940 All-In-One InkJet Printer
HP COLOR LASERJET CP 3505 N PRINTER Logo
42 people viewed this question
Seeker5211
Seeker5211
