Question about Citrix Computers & Internet
Citrix Access Essentials problem. Users can log into Web Interface but cannot launch programs. When I try to run the Quick Start the following error message appears: The licensing task counld not be created due to the following exception: The 'CitrixLicensing' service could not be found. An Alert appears under Licensing "Activate your Access Essentials Servers" but when I click on Licensing nothing happens
    Master:
  • 456 Answers
Try one of these 2 things
1) Uninstall and reinstall Citrix licensing
2) Verify the path to the licensing server is correct (this is located in the licence console, if i remember correctly, the info is in the left hand pane at the bottom of console)
Posted on Apr 29, 2014
2 Suggested Answers
Protocol16
  • 13 Answers
SOURCE: error code 0xc004f058
This typically happens after the computer has gone through changes, such as a motherboard replacement. Depending on the version of Windows that's installed (OEM vs Retail), you may or may not be able to reactivate Windows.
Your best bet is to call Microsoft and go through the reactivation process.
1. Click Start, and in the Search box type: slui.exe 4
2. Press ENTER on your Keyboard
3. Select your Country.
4. Take the Phone Activation option, and hold on for a real person.
Last time I did this, it took about 15 minutes. Be sure to have paper handy to write down your activation code (it's looong).
Posted on Oct 24, 2009
Could not connect to MySQL
Hi;
You can start/stop the mysql service on the server by logging into the server as root from the command line interface and run the following command/s.
service mysql stop
service mysql start
service mysql restart
You can also use the following if the above does not work fine.
Fix Toolbox for MySQL
https://www.fixtoolbox.com/repairtoolformysql.html
Jul 07, 2016 | Wolfgang Schmuck MySQL
How to remove error 0x80010108
Go to Start, run, type "sfc/scannow" within the command and follow the on-screen steps to go. This will automatically check and replace the missing, broken, corrupt system files. See if this fixes the problem.
If not, the problem generally lies with Windows Live Essentials. Goto the Control Panel, Add and Remove programs or Programs and Features: then locate and remove/uninstall Windows Live Essentials.
How do uninstall one or more Windows Essentials programs Windows Help
Reinstall it @ Windows Essentials Download Windows Live Essentials .
Sep 17, 2014 | Acer Aspire Computers & Internet
Netbank login
This problem may be caused by a number of reasons. However, the following are the most common:
The users credentials (the username and password) are not correct.
The user account may not have the right to log on to the computer interactively (the "Log On Locally" right). In some scenarios, the user account requires "Log On Locally" right.
Check the username and the password of the user to make sure that they are correct.
If this is correct, be sure the user has the "log on locally" right granted to it.
To verify user rights, do the following:
1. Open the Local Security Policy tool from the Administrative Tools folder.
2. Click Local Policies, click User Rights Assignment, and then click the Log On Locally user right.
If the user account or group that the user belongs to is not listed, then add it.
See the Internet Information Services 5.0 documentation for more information about authentication.
This documentation can be found at the following URL example:
http://localhost/IISHelp
or
The Web server (running the Web site) thinks that the HTTP data stream sent by the client (e.g. your Web browser or our Check Up Down robot) was correct, but access to the URL resource requires user authentication 1) which has not yet been provided or 2) which has been provided but failed authorization tests.
This is commonly known as "HTTP Basic Authentication".
The actual authentication request expected from the client is defined in the HTTP protocol as the WWW-Authenticate header field. (Last updated: March 2012).
Generally this error message means you need to log on (enter a valid user ID and password) somewhere first.
If you have just entered these and then immediately see a 401 error, it means that one or both of your user ID and password were invalid for whatever reason (entered incorrectly, user ID suspended etc.).
Fixing 401 errors - general
Each Web Server manages user authentication in its own way.
A security officer (e.g. a Web Master) at the site typically decides which users are allowed to access the URL.
This person then uses Web server software to set up those users and their passwords.
So if you need to access the URL (or you forgot your user ID or password), only the security officer at that site can help you.
Refer any security issues direct to them.
If you think that the URL Web page *should* be accessible to all and sundry on the Internet, then a 401 message indicates a deeper problem.
The first thing you can do is check your URL via a Web browser.
This browser should be running on a computer to which you have never previously identified yourself in any way, and you should avoid authentication (passwords etc.) that you have used previously.
Ideally all this should be done over a completely different Internet connection to any you have used before (e.g. a different ISP dial-up connection). In short, you are trying to get the same behaviour a total stranger would get if they surfed the Internet to the Web page.
If this type of browser check indicates no authority problems, then it is possible that the Web server (or surrounding systems) have been configured to disallow certain patterns of HTTP traffic. In other words, HTTP communication from a well known Web browser is allowed, but automated communication from other systems is rejected with an 401 error code.
This is unusual, but may indicate a very defensive security policy around the Web server.
Feb 28, 2014 | Computers & Internet
I receive the error 'Network Initialization Failed: Permission Denied' when trying to launch Magicard ID software
Hi There,
This error happens when the user does not have read / write access to a file called PDOXUSRS.NET. Earlier versions of Magicard ID (before V3.02) stored this file on the root of the C: drive. If running on Windows Vista, the file cannot be accessed. The last version released (V3.05) in 2008 will run on Vista (32 bit only). If you are running V3.05 already, and still see this error, search for 'PDOXUSRS.NET'. It is probably in 'C:\Program Files\Magicard-ID\data'. Check the permissions on the file you must have read / write access to it. Try logging on as local admin. ensure any users who run Magicard ID have read / write permissions to this file. Magicard ID V3.05 can be found here;
http://www.magicardonline.net
NOTE! You will need to enter your printer's serial number in the QuickSearch box.
Hope this helps,
MC.
Sep 22, 2011 | Magicard Pro ID Badging Software Printer
C++ error is appears
Error "Microsoft Visual C++ Runtime Error..." appears on launch
Problem:
When launching PDF Converter Professional 4, a Visual C++ error may occur which refers to autoupdate.exe.
Cause:
This issue may occur if there is a conflict with the Auto Update tool.
Solution:
In order to resolve this issue, we recommend using either of the following solutions:
Option 1 - Edit the system registry
  1. Click on Start > Run.
  2. Type "regedit".
  3. Navigate to HKEY_CURRENT_USER\Software\ScanSoft\PDF Professional 4.0\Config\
  4. Click on AllowWebUpdateOnInit = 1
  5. Change the 1 to a 0 (zero).
  6. Navigate to HKEY_LOCAL_MACHINE\Software\ScanSoft\PDF Professional 4.0\Config\
  7. Click on AllowWebUpdateOnInit = 1
  8. Change the 1 to a 0 (zero).
Option 2 - Disable automatic updates.
  1. Disconnect the network connections by doing the following:
    1. Click on Start > Control Panel > Network Connections.
    2. Choose each, right-click and chose "Disable".
  2. Try to launch the program.
  3. Disable the automatic update by clicking Help > Nuance on the Web and uncheck the Automatic Web Update entry.
Jul 21, 2011 | Computers & Internet
HD infected, run external anti-virus, still logs off instantly
Restart the laptop and tap F8 to get into safe mode and click on administrator. Go to the control panel > users > and create another user, log off administrator and reboot. When system reboots, it will give you a choice of which user to log to, pick the new one and run internal scans with the programs below. Download and install....run their updates and perfrom a quick check only. With CCleaner, run cleaner and then registry fix.
http://www.filehippo.com/download_malwarebytes_anti_malware/
http://www.filehippo.com/download_ccleaner/
Jan 05, 2010 | Dell Inspiron 6400 Notebook
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
Perform the following procedure:
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Chapter 2 Setting Up the Network Interface Card
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Event 534 - The user has not been granted the requested logon typ
I am sorry, but I can only suggest that you contact WTS and Citrix, I do not have the access needed to be able to assist you with login failures.
Ryan Frame
Creative Energy Associates Technical Center
Aug 13, 2009 | Microsoft Windows XP Professional With...
Not able to install Citrix GoToMeeting
Hi!
I am a Vista user and did have the same issue, so here what I did in order not to have this annoying error (I am not sure what action specifically did the trick):
1) Did it via Firefox (make sure you have the latest one);
2) Go to java.com and install the latest java update;
3) Go to gotomeeting.com->Login->re-install software->download manually and save g2m_download.exe file;
4) Now do Unblock and Apply in g2m_download.exe file property General tab;
5) Then Vista users need to disable UAC, I suppose this is the same as "Uncheck the “Protect my computer …”" (Go to "Control Panel" and type "UAC" into the search box. This will bring up the link: "Turn User Account Control (UAC) on or off." Click it. Uncheck the box next to "Use UAC to help protect my computer" then click OK. Restart.);
6) After restart right click on g2m_download.exe and "run as administrator".
Thats it!
Jan 16, 2009 | Citrix GoToMeeting
Computers & Internet Logo
496 people viewed this question
Top Citrix Computers & Internet Experts
xxxxxx xxx
alibaba69
Are you a Citrix Computer and Internet Expert? Answer questions, earn points and help others
