Question about Elna 2007 Mechanical Sewing Machine
Elna 2002 Sewing Machine
I just inherited an Elna 2002 Sewing Machine. I do not have a manual wth it. I am trying to find out how to use the Bobbin Winder. Can you tell me how or where I can find an online manual?
Thanks,
legalgirl5@yahoo.com
  • Anonymous Mar 17, 2014
    Lost sewing machine manual and when i go online to try and find one to download I cannot find the correct one, there seems to only be one related download that isnt the manual only a 2 page leaflet if anyone knows where I can get a new manual download for free pdf that would be amazinngg Ive looked online non stop and cant seem to find one! Even if I pay! The only thing that comes up is the 2page leaflet. Help! thanks :)
  • 323 Answers
Can't get a manual for you but here's how to wind a bobbin.
Guide your thread from the spool holder to the bobbin thread tension device on the top left side of the machine.(That's the round assembly that is about 1/2 inch in diameter with a screw in the center of it.) Pull the thread in the front and wrap it to the back and continue towards the bobbin winder on the right side top. Wrap thread around the bobbin, place the bobbin on the spindle sticking up. Release the handwheel(either by pulling out on the center of the wheel or twisting on the center of the wheel). Press on the foot control. It should stop winding when it is full.
To thread the machine
all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way. Flat side to the back and it threads front to back
Sewman7
Posted on Jun 19, 2008
The bobbin winder on my Elna Carina will not turn when I try to wind the bobbin. Is this something I can work with or do I need to take it to my repair shop where it will not be a quick return.
You can always check on a standalone bobbin winder (like the Sidewinder) available at most fabric stores like JoAnn's or online for ~$30. It's always nice to have anyway because it saves wear-n-tear on your machine and can be used without unthreading your machine. Just be sure to confirm that your machine's bobbins will work as some do not, ie some Singer models...
Simplicity Sidewinder Portable Bobbin Winder
Feb 01, 2017 | Elna Sewing Machines
My elna 7000 sewing machine does not want to wind the cotton
Not sure of the particular bobbin winding problem you are experiencing. However, frequently the bobbin winder "tire" becomes worn and needs to be replaced.
Elna 7000 Parts
What is the correct way to wind and insert bobbin in elna machine
Jul 20, 2016 | Elna Sewing Machines
Problem with ELNA 6200
That symbol indicates the bobbin winder is engaged. disengage the bobbin winder, all should be good. If not the micro switch that indicates the bobbin winder is engaged (when it's not) may need adjust or replacement. See a tech
Feb 11, 2014 | Elna Sewing Machines
Elna 6200 stuck in bobbin mode but sticking
Is the bobbin winder spindle on top of machine pushed over to the right in winding position? Move it back to left to change back to sewing mode.
Nov 30, 2013 | Elna Sewing Machines
Elna lotus tsp
I would really suggest having the machines bobbin winder checked at a sewing machine repair shop..
Jul 10, 2013 | Sewing Machines
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
Bobbin winder stopped working
Either the winder rubber has worn down, or there may be some residue on the winder rubber, ot the winder may have seized through lack of oil which is quite common in that case it will need to be replaced
Mar 21, 2010 | Sewing Machines
Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Jul 29, 2008 | Elna Heirloom Edition 6005
Bobbin winder is stuck
It seems that the bobbin winder sensor needs adjusting and is best done by a service technician with the appropriate service manual to ensure correct parameters are achieved..........to locate your nearest Elna dealer, try ElnaUSA .....here
Feb 16, 2008 | Elna Quilter's Dream 6003Q
Elna 2007 Mechanical Sewing Machine Logo
778 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
