Question about Ovens
Leisure rangemaster 110 fan oven element replaced but still does not get hot
    President:
  • 1,140 Answers
There are 3 possibilities:
Faulty thermostat
Faulty wiring
Faulty oven control switch
Thermostats fail more often in the closed position which means your oven will overheat so I'd test the wiring first. You'll need an Ohm meter to do this. TURN THE POWER OFF FIRST, expose the element and switch then trace the wires from the live and neutral terminals on the element back to the switch. If you can't trace them, make a note of their colours (at the element end) and test for continuity/resistance with wires of the same diameter and colour at the switch. You should get a reading of zero ohms if you have good continuity.
The easiest way to check the switch is visually. Make a note of the wiring colours and their positions on the switch terminals, disconnect them and remove the switch. See if anything looks broken or the
Some thermostats can be disassembled and inspected, but I don't recommend it unless you know what you're doing. The gap between the thermostat switch contacts needs to be precise or the oven wont heat to the correct temperate.
If you can establish that the wiring and switch are OK, try replacing the thermostat.
Posted on Oct 15, 2010
  • Ovens Master
  • 12,061 Answers
In this case then, you have a fault with either the thermistor, and/or the actual control switch, itself.
http://kitchen.manualsonline.com/manuals/mfg/rangemaster/professional_110_dual_fuel_u1_216_02.html
Your user manual is above.
To repair you would need a service manual, and a meter, to troubleshoot and test the circuit, and order the correct parts number in this manual.
Otherwise it maybe best to call a repairman, and get it looked at by a professional, in case it is something more?
My leisure 101 fan oven is not heating up the fan is coming on but not getting hot
Probable element has failed. Replace the element after testing it of course.
May 06, 2017 | Ovens
My leisure GRB6CVK electric oven(main oven) has stop heating up. Fan and light works but no heat. Help pls. Any thoughts. Sheryl
Unplug stove and take wires off element. test for continuity on the poles. Also check wire ends.
May 24, 2014 | Ovens
Diplomat ADP 5520 Stainless Steel Range not getting hot enough
The circular element that the fan sits behind heats the oven. Ensure the thermocouple is back in the right place. Too near the element and the oven will stay cool.
Circular elements can be pricey and fitting should cost no more than an hours labour.
http://www.espares.co.uk/search?SearchTerm=ADP5520%20element
Jun 23, 2017 | Ovens
Neff oven element glows white
It sounds like the wrong replacement element for the power it is getting. If you are using a 220Volt stove, the element MUST be for that voltage and NOT for 110 Volts.
Jan 23, 2013 | Neff U1721 Double circotherm Electric Oven
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
FAN OVEN NOT WORKING
power went off to the house now cant reset fan oven on hotpoint bs21
May 23, 2008 | Ovens
SMEG Oven won't heat up
This is late response but this fault is your fan element. You have two of them, if heating slower than usual, it is only one that has failed. When replacing one, it is recommended the other one be replaced. Tripping the circuit breaker is the symptom. These elements 2100 Watt each are anywhere between $70 to $110.
Service Tech.
Dec 10, 2007 | Ovens
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Ovens Logo
284 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
