Sir in my canon ir 3300 machine when paper pick form caseette no.1 the paper is not pick uped and sound like kad........means one of the gear is not smoothly runing and paper is jammed . so plz sir solve my problem thank you.
  • 1,219 Answers
the problem is in paper pick-up assembly, in paper cassete lifting clamp. The lifting clamp is damadged and can't turn the gear wich lift's the paper plate in drawer.You need to remove whole pick up assy and replace the clamp. The klank-klank sound is charachteristic for these problem.
Firstly you need the parts cataloq and service manual.
emma.servis@gmail.com
Best regards!
Posted on Oct 15, 2010
There is no paper but till machine show paper jammed at left side
ensure that there is no any sensor being blocked in connection to any rotating gear that aids paper movement
Feb 26, 2015 | Canon IR 3300 Digital Copier
E000003-0000
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Thanks
Apr 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
DEAR SIR I HAVE PURCHASED IR 3300 RC MACHINE . I HAVE 2 PROBLEMS. 1. IT ALWAYS DISPLAYS REPLACE THE WASTE TONER . BUT THE WATER TONER CONTAINER IS EMPTY. THE REP SAYS THER IS A PROBLEM IN SENSOR ....
regarding your first problem:
The waste toner container box neck must be always clean, because on the neck are two round dents, where optical sensor reads status. The permanent solution is to disconnect the sensor, his wires are above waste box ( white connector ).After disconnecting the sensor be sure to empty box every 60 000 to 100 000 copies.
Now the second problem:
Do you mean that paper cant be picked up? Does other paper sizes comes trough?
For start clean the pick up roller wich is locate inside the right door ( on top of the door ) in some cases covered with plastic cover.
Note: when you putt the paper in bypass, be sure to select correct paper size, paper type and from where to pull paper( bypass ).
If you want service manual write on emma.servis@gmail.com
Hope that helps!
Aug 30, 2010 | Canon imageRUNNER 2200
ERROR CODE e000602-0003 HOW TO CLEAR THE ERRROR APPEARING ON THE SCREEN OF CANON IR 6000
This is HDD related problem, try : turn off copier pres 1 and 9 (hold it ) then turn on the copier. That initalizes the hdd defragmentation. if does not help, you need to change the hdd and "fill" it with system software.
Apr 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Not getting dry prints using canon 3300 xerox machine
1) is it canon ir 3300 machine?
2) if it is what does it mean NOT DRY completely?
#) My ques is that you need to eplace fixing film
Jan 30, 2010 | Canon imageRUNNER 2270 Copier
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Jan 12, 2010 | Canon imageRUNNER C3200 Copier
Canon IR 3300 model - Paper Load Liver problem in second tray
The tuck tuck sound is sound of paper pick up claw in pick up mechanism of second paper drower.The case is that the pick up clow is worn out and may be broken, so you need to replace it.To replace it you must remove complete pick up unit from the right side of copier, if you are not service technician do not do it by yourself it could be complicated if you do not know exact schedulle of parts and what does it doing.
Nov 12, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Need a hard disk recovery software for canon ir3300
hi i am form India i have canon ir 3300 i am getting error for E602-003 pls no technician
Jul 08, 2009 | Canon Office Equipment & Supplies
70 people viewed this question
k24674
jasbo
jasbo
