I have a SB5120, it was working fine and all of a sudden it just started losing connection. The connection come back and continues and than drops off again. Sometimes it stay up for days and than just stop working. The Cable Service is working fine. Any ideas?
Sounds like the signal level drops too much.
Connect the modem in the first cable from outside (without splitters).
Check the fitting (must be clean and shine, the copper wire).
You could have too much drops with your cable installation. You need to put an amplifier.
Or try to eliminate some splitters and renew the fittings.
I hope you are observing the following:-
Recharging only when the batteries are almost
completely empty.
Continuously recharging or continuously using
as a corded razor will reduce life of batteries
Charge only when the indicator in charge meter starts blinking.
It appears that your batteries are gone. Hope you
have replaced the batteries with the new ones. Use a good brand
You should get the tablet, and then get some tape, and then move around the wire, and then when it turns on, tape it onto the tablet, and then it should work intill you take off the tape.
This can be a problem with the firmware of the router, so the first thing that you can do to correct this problem is to do a firmware upgrade on the router and that should correct the problem......
the sb5120 does not have a reset button- you just unplug the power cord and plug it back in to reboot it, it is a modem not a router. click start-run- type: cmd and click ok then a black box will come up and type in: ipconfig and press enter and that should give you your ipaddress of your router if you are connected through a router
1st thing to do is have the system tested for the code that caused the check engine light to come, you may also have a fuel pump starting to fail or many other things, the check engine light may be the key. How many wiles on the car?
Check for a vaild gateway address on router,start.run.cmd> type in ipconfig.if you dont have a valid ip or gatway. try a powercycle,turn off modem and then router,wait about 10-20 sec and plug modem back in. check your ip and gateway check for a connection, if that dont work call netgear to see if u have a defaulted router, or take it back for new one if u still have a recicpt.
