Question about MGE UPS Comet EXtreme 4.5kVA UPS System
Good day, i just received a 10KVA S31 comet MGE UPS from a client of mine. I tried to powered it up but not responding, the battery light is flashing and the fault light lit with a continuous beep. find below the parameters of the input power. L1 224 L2 229 L 234 Frequency 51.9Hz Battery voltage 247VDC. Please what else should i need to do in order to power up the UPS.
    New Friend:
Is zet a three phase chek
Posted on Aug 03, 2013
3 Suggested Answers
nilutpalsono
  • 238 Answers
SOURCE: My MGE Evolution 3000 ups will not deliver voltage
check the inverter ckt.
Posted on Aug 06, 2010
emissionwiz
  • 77499 Answers
SOURCE: i have the MGE ups
Hello
Fixya has not ability to supply parts directly for any device or product, we are a technical advice service only. That said I can recommend sites that may be able to supply the needed parts based on my parts locating abilities for my own replacement parts for electronics. I've owned and repaired on my own.
You can try this site first.
http://www.electromechanicalparts.com/bscA/linecard5/MGE-UPS-SYSTEMS.html
Here is a site that can supply most electronic components by cross over to generic parts.They will need to know the values of parts like Resistors and Capacitors to supply a replacement, they are very helpful in assisting you to obtain the information to order what you need.
http://www.mcmelectronics.com/category/Semiconductors-Component-Parts/0000001023
Posted on Jan 27, 2011
What batteries go in this unit how many 12? need a replacement
8.3 Battery Configurations
There are different configurations for different battery types and backup time. Here, the batteries from VISION and
YUASA are selected. The backup times ranges from 1hours to 4hours for 20KVA UPS and from 1hours to 2hours
for 30KVA UPS, because of limitation of CLA power rating.
UPS Backup
time Number of blocks Type of blocks Capacity(10H)
1h 1×24 6FM55SGX 52Ah
10kVA 2h 2×24 6FM45X 2×42Ah
4h 2×25 6FM75X 2×74.5Ah
1h 24 6FM75X 74.5Ah
15kVA 2h 3×24 6FM45X 3×42Ah
4h 3×25 6FM75X 3×74.5Ah
1h 1×25 6FM90X 90Ah
20kVA 2h 3×25 6FM55X 3×52Ah
4h 2×26 6FM150X 2×144h
1h 2×25 6FM75X 2×74.5Ah
30kVA
2h 3×24 6FM100X 3×96Ah
Sheet. 4 the battery configuration with VISION battery
UPS Backup time Number of
(10H)
1h 2X24 NPL24-12 2X24AH
10kVA 2h 2×26 NPL38-12 2×35.3AH
4h 2×26 NPL65-12 2×60.5Ah
1h 1×27 NPL65-12 60.5Ah
15kVA 2h 2×24 NPL65-12 2×60.5Ah
4h 3×26 NPL65-12 3×60.5Ah
1h 1×27 NPL100-12 92Ah
20kVA 2h 2×24 NPL100-12 2×92Ah
4h 4×26 NPL65-12 4×60.5h
1h 3X24 NPL65-12 3×60.5Ah
30kVA
Mar 30, 2014 | MGE Galaxy 3000 UPS System
Battery wiring diagram for an MGE comet 50kva
who are you, what is your job why you always have questions regarding old UPS systems.
Dec 04, 2013 | MGE Computers & Internet
MGE COMET S31
very old system anyhow what is your question?
Jul 30, 2013 | MGE Pulsar Ellipse 800 (89363) UPS System
Its not starts properly,my batteries are in good condition
Normally if this UPS is in working condition and the batteries are also good, you should be able to start the UPS by just using the battery cabinet. As soon as power is applied the fan must run and the 4 yellow led for battery/load should lit up. If it is completely dead, then a qualified technician will have to check the internal circuit. It has one main board on which all power components are mounted and a separate control board. Generally there is a 80/100 A than goes opened. I hope you can give us more information if the UPS is completely dead or the led comes up
Feb 21, 2011 | MGE Comet EXtreme 12kVA (891012-21) UPS...
My comet s11 is not giving back up on batteries while there is no indication for batteries side.
The battery should charge as you use the ups. If they don't then its likely the battery/s have failed. Lead acid batteries do not like being left discharged for any length of time. In a motor vehicle the battery gets a bit of shaking around, but in an ups they don't. If not used and left discharged, the plates quickly sulfate up reducing their efficiency to nearly zero. Test and replace any battery that cannot support a test load. Use a battery discharge tester, a bright 12v light or a 12v soldering iron or similar load for testing your batteries.
Apr 14, 2010 | MGE UPS Comet EXtreme 4.5kVA UPS System
Mge pulsar 3000 does not power up
MGE Pulsar 3000 is an online UPS. try to check the battery first if its ok. coz for an online UPS it will need to have a good working UPS battery to trigger the switching relays to on the online UPS unlike backups UPS that can be turn on without any batteries
Aug 13, 2009 | MGE UPS Pulsar Evolution 3000 UPS System
MGE UPS Comet EXtreme 4.5kVA UPS System Logo
341 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
