Question about Motorola Mobility S9 Headphones
Music problem having difficulties using my motorola S9 bluetooth head phone in to my sony ericson 800i
I dont know how to download music on the motorola s9
can u help me please
Posted on Jul 12, 2008
S9 doesn't play music
does your laptop have a2dp bluetooth profile
this profile is needed to play music
Sep 15, 2009 | Motorola Mobility S9 Headphones
How do I connect my motorola bluetooh headset S9 to my LG Vu920?
When using your S9 for the first time, follow these
steps to pair (connect) to your Phone:
Important: If you are pairing separate Bluetooth
devices for handsfree calls and streaming music, it is
recommended that you pair your S9 with your
handsfree device (phone) first.
1 Ensure the Bluetooth feature is enabled (turned
on) in your phone.
2 Turn on your S9 by pressing and holding (|) button
until the indicator light flashes three times in
blue.
After a few moments, the indicator light will be
steadily lit in blue to indicate your S9 is in pairing
mode.
3 From your device, perform a Bluetooth device
discovery/search. .
When pairing your S9, use
the following steps to perform a device discovery
from your phone:
After accessing the Settings Menu, go to bluetooth.
to add a new device, tap [New].
1. Tap [New] key to search the device that can be connected and which is
within range.
The phone lists Bluetooth devices it
finds.
b Select Motorola S9.
c Select OK or Yes to pair your S9 with
your phone.
d Enter the passkey: 0000
e Select OK.
When your S9 successfully pairs and connects to
your device, the indicator light displays blue with
10 quick purple flashes. If wearing your S9, you
will also hear an audio tone indicating successful
pairing and connection to your device.
4 To verify your S9 has successfully established a
handsfree calling connection with your phone,
dial a phone number you want to call and press
the Send key on your phone.
When successfully connected, you hear ringing
on your S9. A Bluetooth Handsfree Phone (HFP)
connection is now established with your phone
Jul 13, 2009 | LG Vu CU920 Cellular Phone
Motorola motorokr doesn't work
The mic stopped working on my S9 after 2 weeks and removing the BT device and repairing did the trick...try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). .
Mar 27, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Cannot get S9 to connect to phone or computer
From Falvey86: Hold the headset start button for about 10 to 20 seconds, the lights will start flashing red and blue, then the search for Bluetooth devices from phone and it will appear as: S9. press "connect", a window will appear, place the password "0000", that should do the trick!!!!
Feb 27, 2009 | Motorola Mobility S9 Headphones
Pairing Motorola S9 headset with PC
i have try this before i couldnt do it untill i tryed using the same bluetooth brand as my head phones worked straight away
Jan 25, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Don't know how to work the music
http://direct.motorola.com/ens/s9/S9_User_Guide.pdf
this is the user guide this should anyser your question on how to use it
it helped me i got a s9 with no instruction manual
Nov 05, 2008 | Motorola Mobility S9 Headphones
IS MOTO RAZR S9HEADPHONE WORKS WITH MOTO RAZR V3I
If your phone supports the A2DP bluetooth protocol, music you play on the phone will be heard in both ears of the S9 headset.
Voice calls are always in one ear only.
May 24, 2008 | Motorola Mobility S9 Headphones
Motorola S9 and Blackberry 8830
To stream music to the S9 the phone needs to support stereo bluetooth or in other words A2DP. The Blackberry 8830 unfortunately doesn't support this and only supports regular mono bluetooth. This is why no music is heard from the S9.
Dec 19, 2007 | LG Prada KE850 Cellular Phone
Bluetooth headset won't play music
hello,
All the bluetooth wireless headset are only capable of making/receiving voice calls.
Y?
its a bluetooth software which is installed on ur cell phone. it is not capable of listing the music through the BT headset. BT 1.1 Software version only lets you listen to mono.
BT 1.2, Version playing music through a BT headset while music is playing on laptops.
and again we need to find out what BT software version is on the phone and if sony erricsson came out with better BT software for your needs.
hope this little information helps.
TY
Nov 29, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Pairing Problem
It may be that the phone does not play music through bluetooth and that it only plays through the earphones that come with the phone. The only way to find out is to read the documentation on the phone or try another bluetooth headset, really. The headset cannot be faulty as it pairs correctly and it works with calls. Bluetooth headsets are not really intended for playing music as it drastically reduces battery life.
Sep 07, 2007 | Sony Ericsson Universal Bluetooth...
Motorola Mobility S9 Headphones Logo
154 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Unlockingcom
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
